Spreadbore Intake/Square bore carb #1414592
04/04/13 07:28 PM
04/04/13 07:28 PM
Simi Valley, CA
MoparJ Offline OP
MoparJ  Offline OP
Simi Valley, CA
I am using my new 3310 Holley on top of my 2176 Performer intake. I am not running the steel adapter plate. Is it a must to run it, or is the manifold a dual pattern/accepts both types of carbs?
2016 Ram 1500 Crew Cab: 5.7, 65RFE, 4.56 gears with locker, Hemifever tuned, AFE intake, 87mm throttle body, JBA headers, 3" Flowmaster exhaust, split to dual 2.5" exits. 13.57 best ET so far.
Searching for new A or B Body Project!
Re: Spreadbore Intake/Square bore carb [Re: MoparJ] #1414593
04/04/13 07:32 PM
04/04/13 07:32 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
It should fit fine ... but use a good gasket.
Re: Spreadbore Intake/Square bore carb [Re: dOoC] #1414594
04/04/13 07:36 PM
04/04/13 07:36 PM
Simi Valley, CA
MoparJ Offline OP
MoparJ  Offline OP
Simi Valley, CA
Using the supplied Holley gasket from the carb box.
Re: Spreadbore Intake/Square bore carb [Re: MoparJ] #1414595
04/04/13 07:39 PM
04/04/13 07:39 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Get the thin plate that ede sells for using squarebore carbs on Spreadbore intakes
http://www.summitracing.com/parts/edl-2732
Orielly's had them last time I was in there.
Ede ships that intake with the plate for a reason...
Re: Spreadbore Intake/Square bore carb [Re: RobX4406] #1414596
04/04/13 10:55 PM
04/04/13 10:55 PM
scratchnfotraction Offline
best way to seal a squarebore holley to the eddy 2176 spredbore intake.
it does have both bolt patterns on the carb flange and the flat plate seals to the holley base gasket while a spredbore open gasket seals the plate to the intake flange.
I just swaped to spedbore carbs(Q-jet) on the squarebore RPM intake on the 440 truck and the LD4B intake on the 318 truck.
used the 3/4" open carb adaptor going this way.
