idle mixture screws #1412535
03/31/13 10:28 PM
03/31/13 10:28 PM
wv
73bbroadrunner Offline OP
wv
why would only one idle mixture screw work? The one on the passenger side does nothing if turned all the way in it doesnt respond to anything. The drivers side will kill motor if turned all the way in and responds to fine adjustments like it should. Brand new 750 holly 4160.
Re: idle mixture screws [Re: 73bbroadrunner] #1412536
03/31/13 11:05 PM
03/31/13 11:05 PM
I'd open it up & go thru it checking metering block passages for blockages/gasket hole not punched etc.
Re: idle mixture screws [Re: 73bbroadrunner] #1412537
03/31/13 11:14 PM
03/31/13 11:14 PM
Nor-Cal
loaderpro Offline
loaderpro  Offline
Nor-Cal
Check to be sure the cork "0" ring has not deteriated in the idle screw bore, if thats not it then prob a swollen metering block gasket.
