Mystery part #1412460
03/31/13 09:53 PM
03/31/13 09:53 PM
Warrenton, VA
RoadRunnerJD Offline OP
Warrenton, VA
I found this in a box of parts that came with my 69 Barracuda fastback but have no clue where it goes? The car has a/c. It's pointed on 0ne end and has a white ball on the other end and the rod is encased in a plastic sleeve.
Re: Mystery part [Re: RoadRunnerJD] #1412461
04/01/13 03:03 PM
04/01/13 03:03 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
Wing wang handle for the foo-foo valve.
Do I get a prize?
It takes gasoline to interest me.
Re: Mystery part [Re: VL21] #1412462
04/01/13 03:06 PM
04/01/13 03:06 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Hip replacement for a skinny person
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Mystery part [Re: 71TA] #1412463
04/02/13 07:46 AM
04/02/13 07:46 AM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
Xylophone mallet for a T-rex
Re: Mystery part [Re: RoadRunnerJD] #1412464
04/02/13 11:14 AM
04/02/13 11:14 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
American Standard bathroom sink stopper valve arm??
Re: Mystery part [Re: A12] #1412465
04/02/13 11:21 AM
04/02/13 11:21 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Re: Mystery part [Re: A12] #1412466
04/02/13 12:42 PM
04/02/13 12:42 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Only you !!!!!!!!
Re: Mystery part [Re: 62maxwgn] #1412467
04/02/13 07:05 PM
04/02/13 07:05 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Only you !!!!!!!!
When you live in a 150+ year old farm house you run into or need to replace these things every so often... Bill I'm sure you've been down that road
Re: Mystery part [Re: A12] #1412468
04/03/13 07:55 PM
04/03/13 07:55 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Only you !!!!!!!!
When you live in a 150+ year old farm house you run into or need to replace these things every so often... Bill I'm sure you've been do that road
Wow I just rebuilt two drain stoppers yesterday!
Except I was tired of the spring clips popping off the end of the shafts. So I used 5/16 vac line cut into 3/8 lengths and ended that problem
(btw this has to be the most extreme threadjack in Moparts history )
Re: Mystery part [Re: A990] #1412469
04/04/13 11:08 AM
04/04/13 11:08 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Wow, good idea, those springs are a pain!
You can learn some good things on the craziest threads.....
Joe
Re: Mystery part [Re: A990] #1412470
04/04/13 11:31 AM
04/04/13 11:31 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Only you !!!!!!!!
Re: Mystery part [Re: jlatessa] #1412471
04/05/13 03:47 AM
04/05/13 03:47 AM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Joe
And we still don't know what the posted part actually is so there's still time for more tips-n-tricks.
I can't afford this. mark
Re: Mystery part [Re: RoadRunnerJD] #1412472
04/14/13 08:45 AM
04/14/13 08:45 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Inland shifter reverse interlock?
