Re: Mystery part
[Re: 62maxwgn]
#1412467
04/02/13 07:05 PM
04/02/13 07:05 PM
Posts: 21,474 N.E. OHIO, USA
A12
N.E. OHIO, USA
Only you !!!!!!!!
When you live in a 150+ year old farm house you run into or need to replace these things every so often... Bill I'm sure you've been down that road
Re: Mystery part
[Re: A12]
#1412468
04/03/13 07:55 PM
04/03/13 07:55 PM
Posts: 2,717 541 slobovia
A990
541 slobovia
Only you !!!!!!!!
When you live in a 150+ year old farm house you run into or need to replace these things every so often... Bill I'm sure you've been do that road
Wow I just rebuilt two drain stoppers yesterday!
Except I was tired of the spring clips popping off the end of the shafts. So I used 5/16 vac line cut into 3/8 lengths and ended that problem
(btw this has to be the most extreme threadjack in Moparts history )
Re: Mystery part
[Re: A990]
#1412469
04/04/13 11:08 AM
04/04/13 11:08 AM
Posts: 1,314 Ohio
jlatessa
Ohio
Wow, good idea, those springs are a pain! You can learn some good things on the craziest threads..... Joe
Re: Mystery part
[Re: A990]
#1412470
04/04/13 11:31 AM
04/04/13 11:31 AM
A12
N.E. OHIO, USA
Only you !!!!!!!!
Re: Mystery part
[Re: RoadRunnerJD]
#1412472
04/14/13 08:45 AM
04/14/13 08:45 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
I found this in a box of parts that came with my 69 Barracuda fastback but have no clue where it goes? The car has a/c. It's pointed on 0ne end and has a white ball on the other end and the rod is encased in a plastic sleeve.
Inland shifter reverse interlock?
