DOT 5 #1412028
03/31/13 10:48 AM
03/31/13 10:48 AM
Canton, Ohio
Crazy68Dart Offline OP
Canton, Ohio
Experiences bad/good? Thinking of using it for the Dart. Have had lot of experience with MC's going bad and trashing the firewall paint.
I know it requires some finesse when bleeding.
383, Hemi 4-Speed, AlterKtion, D60
Re: DOT 5 [Re: Crazy68Dart] #1412029
03/31/13 10:57 AM
03/31/13 10:57 AM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
A few customers with classic vettes have dot 5. The pedal tends to be a bit more spongy. You should clean the system out thoroughly.
Re: DOT 5 [Re: MPerry] #1412030
03/31/13 11:30 AM
03/31/13 11:30 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
i have it in 2 of my cars with no problems what so ever. i do hear old wives tales about it on this board a lot though.
Re: DOT 5 [Re: 65rbdodge] #1412031
03/31/13 12:10 PM
03/31/13 12:10 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Been using it in my muscle cars for 15+ years. Really use it because I am messy and it doesn't hurt the paint.
I have had few problems with it, but it sometimes does not work well with older brake parts. I only use it with all new or reman'ed pieces.
Master, again and still
Re: DOT 5 [Re: DaveRS23] #1412032
03/31/13 12:18 PM
03/31/13 12:18 PM
Crofton, MD
bri440 Offline
bri440  Offline
Crofton, MD
I've used it for at least five years. Rebuilt the brake system on a 71 Challenger - stock rebuild. To me it seems like it takes longer to get the air our of the system. After thoroughly bleeding the system, I still had a soft pedal. A week later I cracked the bleeds on the front calibers for a second, then everything was good. Can't tell a difference between DOT-5 and DOT-3.
Re: DOT 5 [Re: 65rbdodge] #1412033
03/31/13 12:34 PM
03/31/13 12:34 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I use it it my car and no problems at all.We also use it in the postal vehicles at work and no problems there either.
Nautilus Racing-
Re: DOT 5 [Re: Chris2581] #1412034
03/31/13 01:41 PM
03/31/13 01:41 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
.We also use it in the postal vehicles at work and no problems there either. [/quote
Why?
Re: DOT 5 [Re: jcc] #1412035
03/31/13 01:50 PM
03/31/13 01:50 PM
Canton, Ohio
Canton, Ohio
I've been researching it, most have had good luck with it from the various boards I have been snooping around. I've read that it is "thicker" and can trap micro bubbles if to aggressive when bleeding. Been using the gravity method for a while, so I'll start there.
The majority of the brake system is brand new/rebuilt, lines, MC, rear calipers, etc. The fronts had DOT 3 in them, but it has been a few years and I drained them good. I'll make sure to do a good bleed and get everything out.
I do still need to use DOT 3 in the throw out master cylinder, so hopefully that does not give me issues.
Thanks!
Re: DOT 5 [Re: jcc] #1412036
03/31/13 07:38 PM
03/31/13 07:38 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Why?
I will assume for no possibility of paint damage,and since we get it from a U.S. Govt supplier,it's cheaper.
Nautilus Racing-
Re: DOT 5 [Re: Crazy68Dart] #1412037
04/01/13 04:52 PM
04/01/13 04:52 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
I use it in my Road Runner. Pedal is hard as a rock and stops really good. If I hadn't, the leaky master cylinder cover would have destroyed the paint on the inner fenders.
Re: DOT 5 [Re: torkrules] #1412038
04/01/13 07:47 PM
04/01/13 07:47 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
I have it in 2 of my cars and had no problems at all.Bleed fine with my Mityvac.
Re: DOT 5 [Re: 5carguy] #1412039
04/01/13 10:51 PM
04/01/13 10:51 PM
Shippensburg, PA
GardnersGotCudas Offline
Shippensburg, PA
it is the best
Re: DOT 5 [Re: GardnersGotCudas] #1412040
04/01/13 11:15 PM
04/01/13 11:15 PM
Canton, Ohio
Canton, Ohio
I'm sold.. thanks guys.
Not sure how much it matters, any particular brand you guys are using?
Re: DOT 5 [Re: Crazy68Dart] #1412041
04/01/13 11:55 PM
04/01/13 11:55 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I got mine at Car Quest. I think it was thier house brand. $25 a quart.
Re: DOT 5 [Re: Crazy68Dart] #1412042
04/02/13 12:12 AM
04/02/13 12:12 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Rick Ehrenberg convinced me to use it after a ride in his '69 Roadrunner 32 years ago! Good enough for E-Berg, good enough for me!
Re: DOT 5 [Re: Sunroofcuda] #1412043
04/02/13 12:34 AM
04/02/13 12:34 AM
E. Okla line
m88mark Offline
m88mark  Offline
E. Okla line
Military went to silicone fluid almost 40 years ago. All I use cars & bikes.
Mark
Re: DOT 5 [Re: Crazy68Dart] #1412044
04/03/13 12:48 PM
04/03/13 12:48 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Has been in 100% of my vehicles since 1978. Ditto US military since mid-'70s. Ends stuck caliper pistons forever.
A guy on eBay (occasionally) sells mil-spec surplus gallons dirt cheap. Shelf life is near infinity.
It is virtually all made by Dow Corning no matter what the label says.
Rick
Re: DOT 5 [Re: Rick_Ehrenberg] #1412045
04/03/13 08:19 PM
04/03/13 08:19 PM
Canton, Ohio
Canton, Ohio
Thanks again guys. I got a box of stuff from Summit today, DOT 5 was in there too.
Re: DOT 5 [Re: Crazy68Dart] #1412046
04/03/13 08:51 PM
04/03/13 08:51 PM
None
71rm23 Offline
71rm23  Offline
None
Looked for some at a local parts store....the kid looked at me like I was talking a foreign language..
Re: DOT 5 [Re: 71rm23] #1412047
04/03/13 09:02 PM
04/03/13 09:02 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
OK, so if it's so great...what are the reasons to NOT use it?
for those who say to not use DOT 5....why?
if it's nothing but pros and positives...why isn't everyone using it? what are the urban legends regarding DOT 5 fluid?
**Photobucket sucks**
