Page 1 of 3 1 2 3
Race car trailer tires #1411772
03/30/13 10:39 PM
03/30/13 10:39 PM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
well its time for new rubber on the car trailer and I am looking for real world experience. Who has used carlisle trailer tires? I can get a 10 ply for 125 each, 12 ply for 160 each, or a chinese brand called Gladiator that has a 14 ply for 160 each. Anyone used these or have suggestions. I am hauling roughly 11-11.5k pounds. Thanks, Beep
Re: Race car trailer tires [Re: Bigbeep] #1411773
03/30/13 10:42 PM
03/30/13 10:42 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
The Chineese 14 ply tires are hit and miss. The ones that came on my trailer were decent. Had a warranty issue that cut a tire and could not match. So they gave me 4 new chineese 14 ply tires. They were junk.
Leon
Re: Race car trailer tires [Re: Bigbeep] #1411774
03/30/13 10:43 PM
03/30/13 10:43 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I run Goodyear marathon tires. Have had good luck with them. Never tried those brands.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Race car trailer tires [Re: 1967dartgt] #1411775
03/30/13 10:47 PM
03/30/13 10:47 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I just looked at my trailer. I've replaced one with a Carlisle 225/75-15 load D. The other 5 are Goodyear. All are dry cracked, One is coming apart. Good tread on all. I've got car tires far older that are not cracked at all? In our area the Carlisle's are $100. new ones Tuesday.
Doug
Re: Race car trailer tires [Re: Bigbeep] #1411776
03/30/13 10:49 PM
03/30/13 10:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
DONT waste your money on the Carlisle tires... total
JUNK.. I dont know the other brand... I run a Goodyear
Maration trailer tire.. pricey but good .. I have
more weight and never blew a tire... keep them at max
pressure and check the pressure every time you
go out
Re: Race car trailer tires [Re: MR_P_BODY] #1411777
03/30/13 11:11 PM
03/30/13 11:11 PM
Ripley
BryanRad Offline
BryanRad  Offline
Ripley
Save yourself the headache and buy Goodyears.
Re: Race car trailer tires [Re: MR_P_BODY] #1411778
03/30/13 11:14 PM
03/30/13 11:14 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
go out
I think the key is running your tires at MAX PSI
I think a lot of the tire probs guys have are from under inflation. When they are low on air and trailer is loaded they will get HOT and blow.
I have Triangle brand tires on my trailer and they are going on 9 yrs old never a problem. But they are always at 60psi before I hit the road.
Re: Race car trailer tires [Re: Bigbeep] #1411779
03/30/13 11:19 PM
03/30/13 11:19 PM
Franklin Furnace, OH
moparman1954 Offline
Yellowbullet has a new trailer forum. Check there they have a lot of posts on trailer tires.
Re: Race car trailer tires [Re: Bigbeep] #1411780
03/30/13 11:24 PM
03/30/13 11:24 PM
Silsbee,Tx
-Cuda Offline
-Cuda  Offline
Silsbee,Tx
Just bought some gladiators. Look nice but can't comment on longevity yet. www.treaddepot.com has free shipping through March.
Re: Race car trailer tires [Re: moparman1954] #1411781
03/30/13 11:31 PM
03/30/13 11:31 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Here is some very good info from an RV site. I did some research last year after a couple of blow-outs. 16 inch are way better than 15 inch. Get the highest ply that you can afford. If the tires call for 70 pounds run them 8-10 pounds higher. As said above HEAT is the biggest killer. Don't even listen to what the open trailer guys recommend. The weight on the inclosed trailer is WAY heavier than them and then we add quads, generators, tools, cupboards, and any other thing we can think of. I ran my old open trailers on junky mobile home 14.5 tires for years and never had a problem. I have 15 inch on my trailer so I went with the best Carlyle they had and in 4 years I will buy new tires and put these on Craigslist. http://www.rv.net/forum/index.cfm/fuseac...%7B%7D/sr/1.cfm
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Race car trailer tires [Re: pittsburghracer] #1411782
03/31/13 12:25 AM
03/31/13 12:25 AM
baldwinsville new york
a493demon Online content
a493demon  Online Content
this place has some good prices not sure on what brands they have .
http://www.easternmarine.com/Sale-Specials-Close-Outs/
Re: Race car trailer tires [Re: a493demon] #1411783
03/31/13 11:24 AM
03/31/13 11:24 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've actually had better luck with Carlisle than Goodyear. I have failed better than 50% of the Goodyear's I've run. The last two failures were Goodyear. Tires are always at max psi.
Doug
Re: Race car trailer tires [Re: dvw] #1411784
03/31/13 11:50 AM
03/31/13 11:50 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Doug
Few questions for you Doug.. what size rim, which
goodyear tire and was it a inclosed trailer what
were the ratings on each... the first inclosed trailer
I bought had the carlisle tires(15" rims)... they
(2 of them) didnt even last 1 season the new trailer
is a 16" rim HD axles and I went with the goodyear
marathon trailer tires and have never had an issues...
that trailer is MUCH heavier and I only have 2 axles
under it(I should have maybe put 3 under it) but I didnt...
I know I will never buy another carlisle ... JMO
Re: Race car trailer tires [Re: Bigbeep] #1411785
03/31/13 02:46 PM
03/31/13 02:46 PM
Ohio
Hemi Joe Offline
Hemi Joe  Offline
Ohio
Once again I will say it !!!! What we need is an American Made Trailer Tire Manufacturer !!!! In my opinion, those Chinese Made Tires Are JUNK !!!!! Had to replace 4 tires last year on my tri-axle enclosed 48' trailer. I keep a constant check on my tires and always check the tire pressure. We also need an American made steel rim - I believe that I have 3 bent rims on my trailer now, caused by the trailer sliding as you make a sharp turn..If made properly, their is nothing made as good as made in the USA - with American made materials!!!! CALL OR E_MAIL COMPANIES LIKE COOPER TIRE - and ask them to start making trailer tires again !!! I can't believe that the Dept. Of Highway Safety Allows those Junk Chinese Tires to be used in this country !!! HEMI JOE
Re: Race car trailer tires [Re: MR_P_BODY] #1411786
03/31/13 02:48 PM
03/31/13 02:48 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I have Carliles on my enclosed, they have been great for me. I picked up five so i had a good spare, havent needed it in four years. Good years are over priced junk
Re: Race car trailer tires [Re: Bigbeep] #1411787
03/31/13 03:28 PM
03/31/13 03:28 PM
Az
Crizila Offline
Crizila  Offline
Az
Actually had a blow out on my trailer on the way back from the MATS last weekend. They were top of the line tires with a load rating that well exceeded the load and they were less than 1 year old and probably under 3000 miles on them. We did run in to a stretch of pretty rough road on the way out and back. My suggestion: Buy a quality US brand. Make sure the load range exceeds your load and axle GVWR, but don't go overboard on it. Don't look at ply rating. It's just too confusing ( radials / bias ply, tread / sidewall, etc.) Stick with load range. I am meticulous about my trailer maintenance, and still had a blowout - and found one outer wheel bearing going south after I got home. I'm pretty sure my tire failure was due to a ply separation ( pot hole ). Other 3 tires were fine. The roads ( inter State ) suck. Inspect your trailer often and for sure before and after a long haul. Have a fresh ( new ) spare tire ready to go. Run max pressure for your load range tires. Make sure your trailer springs are not beat out. Minimal axle travel will dump big loads on the tires over rough roads and can cause internal sidewall damage and eventual ply separation - and failure. Finally, check wheel bearings at least once a year. Lots of play or a growl sound when you spin the tires is a sure indication a bearing is on the way out. My outer bearing failure appeared to be caused by high impact load.
Fastest 300
Re: Race car trailer tires [Re: Crizila] #1411788
03/31/13 05:10 PM
03/31/13 05:10 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
Another item absolutely essential to trailer readiness is to check lug nuts before every trip. Last spring we were going to a race and were on a divided 4 lane. All of a sudden the driver said "we just lost a wheel", I asked "a blowout"? He said no the whole wheel just crossed into the median. Pulled over and all 5 of the studs were sheered off. When we finally found the wheel it was obvious that the wheel had been rocking back and forth on the studs. The wheel holes were wallowed out extensively. I'm sure this came from not checking my lug nuts often enough.
Luckily we found a safe place to leave the trailer until I could get another hub. By sheer luck my nephew had a broke axle with the parts we needed. Was a bunch of miles but we were able to get the trailer home that night. I definitely ck them every time now!!!
Re: Race car trailer tires [Re: Blucuda413] #1411789
03/31/13 11:28 PM
03/31/13 11:28 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
I went to a Goodyear store about 3 years ago for tires and they sold me a set of Towmax E rated tires. Run them at 80lbs for 3 years now on my 28ft trailer and so far no problems
Russ
Re: Race car trailer tires [Re: max_maniac] #1411790
03/31/13 11:55 PM
03/31/13 11:55 PM
Arizona
Chris'sBarracuda Offline
Arizona
I went through this last year..
Finally bought Hercules Tires.. 235/85/16 F...
So far so good.. Been to Vegas 3 times since and all looked good after the MATS..
Time will tell.. We do keep them on wood with covers too.. Kind of important..
48' 5th wheel trailer 3 axle..
Chris..
Re: Race car trailer tires [Re: Bigbeep] #1411791
04/01/13 01:18 AM
04/01/13 01:18 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I have been looking at 16" wheel packages to replace my 15" rims/tires. It's hard finding 15" tires with the higher load ratings. Right now I have the Goodyear marathons, but broke a cord in one, slashed the sidewall on another, and now have a slow leak in another. The slashed one and slow leak is fome too much junk on the roads, but the broken cord? maybe I hit a pothole or other road construction?
Page 1 of 3 1 2 3
