Getting ready for sub-connectors #1411609
03/30/13 07:31 PM
03/30/13 07:31 PM
Georgia
72440CUDA Offline OP
Georgia
Well, I've had these prototype US Car Tool subframe connectors sitting in in my garage since they hit the market (6-7 years ago?)
I'm finally ready to install them. I have my interior gutted, except for the dash and a seat so I can still drive it.
I just got back from the body shop and had them put the car on a lift and tram-gauge it to make sure everything is square and level. Everything is good.
They are letting me do the work at their shop on a weekend, so that will save me on the labor
My question is, since the car is pretty much at full weight and won't be on a rotisserie... is it better to weld these in with the car on a lift (suspension drooped), or to have the weight on the tires up on a lifted frame rack?
This will be my first installment of chassis rigidity.
Re: Getting ready for sub-connectors [Re: 72440CUDA] #1411610
03/30/13 07:43 PM
03/30/13 07:43 PM
E. Okla line
m88mark Offline
m88mark  Offline
E. Okla line
4 post lift, on tires.
Mark
Re: Getting ready for sub-connectors [Re: m88mark] #1411611
03/30/13 09:14 PM
03/30/13 09:14 PM
Beeton Ontario. Canada
BigSugar Offline
BigSugar  Offline
I would level the chassis left to right and unload the bulk of suspension and engine weight, with more stands.
support the chassis at eight points. front crossmember, rear crossmember and at the forward section of the chassis and the rear.
The chassis is the foundation of the suspension , Subframe connectors and Torque boxes are to beef up the foundation.
If you Chassis or Unibody is under load from the suspension it may not be true and square, Losts of Mopars rubnning around with bad rear leafs and misadjusted torsion bars.
While your under thee gusset your steering box with a little triangular piece of heavy gauge, and if your up to it add the reinforcing plate to the underside of your LCA (Mancni , Firm Feel)
Ron
Re: Getting ready for sub-connectors [Re: BigSugar] #1411612
03/30/13 09:27 PM
03/30/13 09:27 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
I bought a set of those too and quickly gave up on them and sold them. Too much work to fit them to the floor IMO. I then made my own from 1X2 square tubing cost be $10!
Re: Getting ready for sub-connectors [Re: 72440CUDA] #1411613
04/01/13 12:13 PM
04/01/13 12:13 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
If your car is complete, assembled, and in driving condition, install them with the weight on the four tires to maintain the intergity of all the panel alignment.
If its apart and under construction, square it up and make it as flat and plumb as possibe by using up to 9 jackstands to loacte everything.
There is a reason competition cars are welded up on a chassis plate, but, the vast majority of us do not need that much precision in the foundation of our classics that are only weekend cruisers.
Re: Getting ready for sub-connectors [Re: TC@HP2] #1411614
04/01/13 01:56 PM
04/01/13 01:56 PM
Georgia
Georgia
This is sort of what I was thinking
Re: Getting ready for sub-connectors [Re: brads70] #1411615
04/27/13 10:35 PM
04/27/13 10:35 PM
Texas
shart70rt Offline
shart70rt  Offline
Texas
I finally got mine in, but ridiculous amount of grinding and cutting on them was necessary to make them fit. Poor product in my opinion.
70 Go Mango Charger RT
White Vinyl Top
18 Spline 4 speed
Lakewood Scatter Shield/ Centerforce DF Clutch, Hydraulic bearing
505 Stroker, dual 600's, hyd roller cam - 525 hp, 640 torque
Re: Getting ready for sub-connectors [Re: brads70] #1411616
04/28/13 04:23 PM
04/28/13 04:23 PM
indy
E
edco440 Offline
edco440  Offline
E
indy
Exactly the same scenario with me. I sold mine off and am going to use 1X2 Square tubing,, welded on my Bend-Pak 16 HDX
Re: Getting ready for sub-connectors [Re: shart70rt] #1411617
05/02/13 12:19 PM
05/02/13 12:19 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
agreed,these cars tolerances are all over the place,its actualy a miracle that anything fits them as intended from time to time
Re: Getting ready for sub-connectors [Re: 1Fast340] #1411618
05/03/13 08:35 AM
05/03/13 08:35 AM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
Much easier to weld with the suspension hanging. As long as the car is well supported I've never had an issue. In theory it would be nice to weld on a four post, but I don't know how you would get to the outside to weld properly.
That said I am wrapping up an A body is car tool install. Frame connectors take 3 hrs per side of prep for welding, plus R and R carpet, etc.
Re: Getting ready for sub-connectors [Re: BergmanAutoCraft] #1411619
05/03/13 12:03 PM
05/03/13 12:03 PM
Georgia
Georgia
I've been contacted by a member from US Car Tool. They said there have been improvements to their design and that I can send mine back in exchange for their updated (better fitting) model
I'm tempted to go with the full kit
Re: Getting ready for sub-connectors [Re: 72440CUDA] #1411620
05/03/13 08:40 PM
05/03/13 08:40 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I made my own out of 2x3 tube. Total install time was a few hours per side.
Re: Getting ready for sub-connectors [Re: DaytonaTurbo] #1411621
05/07/13 09:55 PM
05/07/13 09:55 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
Getting ready for a hotchkis sale
