Page 3 of 3 1 2 3
Re: How common is a .055" OS 440 cylinder really too thin? [Re: Stanton] #1409856
03/28/13 10:23 PM
03/28/13 10:23 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
wow, 24 miles from mr big ears? Kenya dig it?
Re: How common is a .055" OS 440 cylinder really too thin? [Re: jyrki] #1409857
03/29/13 01:24 AM
03/29/13 01:24 AM
Nor-Cal
loaderpro Offline
loaderpro  Offline
Nor-Cal
My machinist tells me that .150 should would be his minimum, blower or otherwise. The weak spot in the chrysler blocks is in the webbing of the mains when you get into the 800 plus hp range.
Re: How common is a .055" OS 440 cylinder really too thin? [Re: BradH] #1409858
03/29/13 02:07 AM
03/29/13 02:07 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
The .060" is simply going back together w/ a ring & bearing job since it checked OK (no cracks, etc.)) at the last inspection. I'm just band-aiding it to get the car back on the road... more or less.
The pi$$er would be if the .055" block was tested and turned out to be too bleepin' thin. Other than the final decking, all of the rest of the machine work (bore & deck-hone, install aluminum main caps, etc.) is already done on it. Gawd, I'd hate to find out it's just a boat anchor... And I'd hate to blow it up, too.
It's not a boat anchor , sleeve the thin bores .
I have in my possession a .040 over 69 block that has 3, or 4, thin walls, on the pin side, that are around .090. If I were to do anything serious with it, after I buy it of course, I would sleeve the 4 cylinders .
Re: How common is a .055" OS 440 cylinder really too thin? [Re: 64Post] #1409859
03/29/13 05:18 AM
03/29/13 05:18 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
Why don't you sonic test your busted cylinder and share the results with us? That way we will know what not to do.
X2. Some empirical data would be swell...
I'm having the cylinders sonic checked, will publish the numbers once done.
Plynouth VIP '67 TT IC EFI
Re: How common is a .055" OS 440 cylinder really too thin? [Re: BradH] #1409860
03/29/13 09:54 AM
03/29/13 09:54 AM
NC
440Jim Offline
440Jim  Offline
NC
I know Jan Norris at Precision Engine Machine in Hyattsville has a sonic checker and he knows how to use it.
I haven't talked to him in many years since he ~2000, so give him a call and ask. Attached are the numbers prior to boring 0.033" on my 400 block (511 CID, 4.250" stroke). As you can see the thrust are pretty good, and the thinnest front/back was 0.139", so ~0.122" after boring.
301-779-5808
The really hard question is what is good enough. They can crack on any surface, so although the major and minor thrusts should be the thickest, the front and back sides shouldn't be 0.080" thin either.
The block you have used before is likely good since it hasn't cracked from all that prior use.
Re: How common is a .055" OS 440 cylinder really too thin? [Re: 440Jim] #1409861
03/29/13 11:06 AM
03/29/13 11:06 AM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Just got off the phone w/ C&C in Manassas and they want $175 to take only 4 readings per cylinder... Sounds really high to me, so I'm going to call some other folks (first anyone I can find in VA, then across the Potomac @ Performance Machine) to see what else I can find.
Re: How common is a .055" OS 440 cylinder really too thin? [Re: BradH] #1409862
03/29/13 11:43 AM
03/29/13 11:43 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Man, run away from that place...
IMO, minimum should be 3 readings per axis per cylinder... that's 12 per cylinder X 8. That's what I got for $75 back in Denver...
Re: How common is a .055" OS 440 cylinder really too thin? [Re: 64Post] #1409863
03/29/13 11:46 AM
03/29/13 11:46 AM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I just had 7 blocks done 70-75 each 12 reading a cy
Re: How common is a .055" OS 440 cylinder really too thin? [Re: BradH] #1409864
03/29/13 11:54 AM
03/29/13 11:54 AM
Central Pa. U.S.A.
Bigfury Offline
Bigfury  Offline
Central Pa. U.S.A.
Brad if your really interested,the machine shop near me will give ya a better deal than that.Also knowing your about three and a half hours away. I also have a couple of blocks to have checked,should get a quantity discount.Could most probably schedule over a weekend.Least I could do for all the help you've provided.
Re: How common is a .055" OS 440 cylinder really too thin? [Re: Bigfury] #1409865
03/29/13 01:04 PM
03/29/13 01:04 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
If your dragging it to Pa. bring it buy the shop,we will sonic test it for you N/C.
Re: How common is a .055" OS 440 cylinder really too thin? [Re: Stanton] #1409866
03/29/13 01:41 PM
03/29/13 01:41 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
The transducer has two "feet" and they are machined for a certain radius. Mine is ground on a 4" which I think is fairly common and according to Dakota it's accurrate for most bores from 3" to 5". Because they are set into ceramic and precision ground the curve is very specific, and the calculations the unit makes includes those curves and distances between the "feet". You will get false readings trying to read without both "feet" flat against the surface. So you either get the transducer you need, or test it incorrectly. They make a variety of transducer shapes too.
The cheaper units are not accurate enough to provide the insurance against failure. They aren't worth the shipping no matter where they'r emade or shipped from. Look for one that comes certified and that is calibrated off the piece you're testing because cast iron varies tremendously.
Re: How common is a .055" OS 440 cylinder really too thin? [Re: BradH] #1409867
03/29/13 02:31 PM
03/29/13 02:31 PM
NC
440Jim Offline
440Jim  Offline
NC
Yea, $175 sounds high.
But the details of what they are measuring is worth talking to each shop. They might only write down 4 readings per cylinder, but hopefully (check) they will run the probe down the cylinder and record the thinnest area they see on each of the 4 sides. I have also heard of shops that take a reading 1" down and 3" down or whatever.
Re: How common is a .055" OS 440 cylinder really too thin? [Re: BradH] #1409868
03/29/13 03:27 PM
03/29/13 03:27 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Loc: La Casa de Chaos!
Where the F&#@ is that?
According to MapQuest, I'm 24 miles northwest of the official residence of the President of the United States of America.
Dammit, I knew I should have looked you up when I was in North Bethesda
Rich H.
Esse Quam Videri
Page 3 of 3 1 2 3
