ID part..no such thing as a stupid question........ #1409145
03/26/13 09:05 AM
03/26/13 09:05 AM
near New Haven, CT
fireeng Offline OP
fireeng  Offline OP
near New Haven, CT
......just stupid people. That's me.
I developed a bang in my front end on my 71 challenger when I turn the wheel. I found this rubber bushing missing on the passenger side front of what I believe is the steering linkage?? Can someone give me the proper name for this so I can get what I need to fix it? and is this something a novice can do or do I need to bring it to my mechanic? I would like to replace all of them as they all look pretty worn.
Thanks again for any help, moparts always carries me when I need it.
2016 Diesel Ram 3500 Mason Dump
1971 Challenger
2013 Jeep Wrangler
1979 Dodge Ram Power Wagon 400 Mini Pumper
My other car is a Fire Truck.
Re: ID part..no such thing as a stupid question........ [Re: fireeng] #1409146
03/26/13 09:26 AM
03/26/13 09:26 AM
Tennessee
meep_meep Offline
meep_meep  Offline
Tennessee
well, what you have circled there are the inner tie rod end(on the left)...and the idler arm...
Re: ID part..no such thing as a stupid question........ [Re: meep_meep] #1409147
03/26/13 09:29 AM
03/26/13 09:29 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
And it is tapered and if tight,there won't be any banging,it is not a bushing,it's a seal!
Re: ID part..no such thing as a stupid question........ [Re: fireeng] #1409148
03/26/13 09:32 AM
03/26/13 09:32 AM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
The bottom bar with the 2 holes on each end is the Centerlink.
Looks like its not tight or possably the Ideler Arm is wore out.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: ID part..no such thing as a stupid question........ [Re: fireeng] #1409149
03/26/13 09:33 AM
03/26/13 09:33 AM
Maud,Tx
maud Offline
maud  Offline
Maud,Tx
That is an idler arm. It is usually the first item on the front end to wear out. I would check for wear on all of the components as follows. Get someone in the drivers seat, have them turn the steering wheel back and forth, not enough to turn the wheels, just enough to move the slack in the steering. If the idler arm is bad it will move up and down. Also look at the4 tie rod ends for slop. Also look at the pitman arm, it looks like the idler are except it is bolted to the steering box. You'll have to jack up the car to check the ball joints. Grab the top and bottom of the front tires and try to move them in and out while someone looks for movement of the joints.
Re: ID part..no such thing as a stupid question........ [Re: fireeng] #1409150
03/26/13 09:54 AM
03/26/13 09:54 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
You can also get some generic individual boots from parts stores in those "help" products etc.
Re: ID part..no such thing as a stupid question........ [Re: buildanother] #1409151
03/26/13 10:53 AM
03/26/13 10:53 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
A missing boot is not going to cause that to bang around , the arm itself is either bad or it was never tightened properly to begin with. Since this is something new that occurred and has not been an ongoing issue I'll go with the part is bad .
Re: ID part..no such thing as a stupid question........ [Re: JohnRR] #1409152
03/26/13 11:01 AM
03/26/13 11:01 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
dont rule out wheel berings.
Re: ID part..no such thing as a stupid question........ [Re: bonefish] #1409153
03/26/13 11:27 AM
03/26/13 11:27 AM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
Just because the dust boot is missing, this won't make the noise you discribed. I would have someone move the steering while you crawl under, and get a look at the parts in question. Look for exsessive movement, loose fasteners, or something worn out.
Good luck.
Re: ID part..no such thing as a stupid question........ [Re: bigblock340power] #1409154
03/26/13 01:18 PM
03/26/13 01:18 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
I would also avoid driving the car until the cause is determined. Having the idler arm fail completely would ruin your day, and perhaps the car.
Changing the idler arm is not that big a deal. The proper idler arm puller is available for loan at any Autozone, and the rest of the tools you probably already have. If the idler (and/or any other steering/suspension parts: tie rod ends, control arm bushings, etc.) is shot, the car will probably need an alignment after the new parts are installed.
