Re: T/A hood warped how to fix
[Re: ThermoQuad]
#1408708
03/26/13 11:15 AM
03/26/13 11:15 AM
Posts: 142 NJ
70_FJ6_RR
NJ
This works...
Wait for a hot sunny day Park car in sun for a couple of hours Block up hood with small blocks in the front corners Place a clean towel on the affected area Place a big block cylinder head on the towel and go away for the rest of the day. Put car back in garage and leave cyl head on hood till the next day or so.
Repeat if necessary, the bow will disappear..,and never return
Propane torch???? Are you kidding me??? As always be careful with some of the advice given here
Yeah, I would be careful with the advice given here! You have more control with a propane torch and heating the area you want to straighten, than you do the sun heating the entire hood with the weight of a cylinder head, possibly to warp the center of the hood. On here, you'll get advice, and that's all it is. Like I said, it takes talent. Spend a few minutes on the phone with some fiberglass companies, or find a good local body guy.
[Re: dOoC]
#1408710
03/30/13 10:07 AM
03/30/13 10:07 AM
Posts: 18,157 Mass
DAYCLONA
Mass
ProPain torches, heat guns ..... whata' buncha' guyz ..... .... WHAT you need to do it make a jig on what the correct contour of the hood is supposed to be and then SLICE UP the bracing on the hood .... then put the hood into the jig and then GLASS OVER the bracing .....
Then find some lighter hood springs ...THAT is what has caused the problems in the first place (other than the hood not having proper bracing for the application) ...
What's with giving away the proper answer/advice here Doc? ....seriously that's what's needed in this case.
bricks, cylinder heads, torches ...what next?,....I suppose a brush and roller for paint perhaps?
