T/A hood warped how to fix #1408699
03/25/13 04:50 PM
03/25/13 04:50 PM
Warren, MI
Jerry Offline OP
Jerry  Offline OP
Warren, MI
i've got a fiberglass T/A hood for my 1973 challenger and i know i got it used. the hood is pretty warped on either side and doesn't line up with the fenders. i know the factory hoods had a lot of problems but is there anyway to address it? anyway to tweak to make it fit better? i'm at the point of getting rid of the hood hinges and installing 6 hood pins to try and align the hood better. so i'm looking for suggestions other than its fiberglass just live with it.
thanks
Jerry
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: T/A hood warped how to fix [Re: Jerry] #1408700
03/25/13 04:55 PM
03/25/13 04:55 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I know Troy fixed his by sitting it out in the hot summer sun with weights for days maybe week(s)? Then adding hidden steel reinforcements and glassing them back over.
Re: T/A hood warped how to fix [Re: Jerry] #1408701
03/25/13 05:39 PM
03/25/13 05:39 PM
NJ
70_FJ6_RR Offline
70_FJ6_RR  Offline
NJ
With the hood on the car and light weight hood springs on the hinges, remove the middle fender side rubber bumpers,not the front adjustable bumper, then heat the warped hood bottom area with a propane torch quickly and carefully, till it's hot to touch, then set the hood down with weights on a piece of plywood in the warped area till even and cool it with compressed air on the underside. It may take a few tries, depending on how high above the fender it is. It takes some talent, so if you're afraid, get a good fiberglass guy to help you. Another cheat would be to put shims under the middle areas of the fender to make up some difference of the warped hood. Goodluck!
Re: T/A hood warped how to fix [Re: 70_FJ6_RR] #1408702
03/25/13 06:47 PM
03/25/13 06:47 PM
Warren, MI
Jerry Offline OP
Jerry  Offline OP
Warren, MI
thanks for the info. thats kind of what i was thinking, but was afraid to try and really find out if i was right. would a heat gun work just as well or does it have to be propane? will it warp again sitting on the car?
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: T/A hood warped how to fix [Re: Jerry] #1408703
03/25/13 06:57 PM
03/25/13 06:57 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
My original AAR hood was warped. I just took off the springs and set it in the sun. It flattened right out. Try that before you start with the heat or weights.
Re: T/A hood warped how to fix [Re: Jerry] #1408704
03/25/13 07:47 PM
03/25/13 07:47 PM
NJ
70_FJ6_RR Offline
70_FJ6_RR  Offline
NJ
A powerful heat gun may work. If the car is going to be stored for a long period of time, I would remove the springs. If you're not worried about originality, you could glass in some aluminum square tube/stock or angle(trim to fit flange)on the inside length of the outer flange for strength. Fiberglass has a mind of its own.
Re: T/A hood warped how to fix [Re: 70_FJ6_RR] #1408705
03/25/13 08:04 PM
03/25/13 08:04 PM
BDW Offline
BDW  Offline
Try the heat gun first, they go to 1000F and shouldn't burn like a torch.
Re: T/A hood warped how to fix [Re: BDW] #1408706
03/26/13 06:50 AM
03/26/13 06:50 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
This works...
Wait for a hot sunny day
Park car in sun for a couple of hours
Block up hood with small blocks in the front corners
Place a clean towel on the affected area
Place a big block cylinder head on the towel and go away for the rest of the day.
Put car back in garage and leave cyl head on hood till the next day or so.
Repeat if necessary, the bow will disappear..,and never return
Propane torch???? Are you kidding me??? As always be careful with some of the advice given here
Re: T/A hood warped how to fix [Re: ThermoQuad] #1408707
03/26/13 09:51 AM
03/26/13 09:51 AM
Warren, MI
Jerry Offline OP
Jerry  Offline OP
Warren, MI
yeah i really wasn't crazy about the propane torch idea. apparently the fiberglass hood are soft enough to move in the sun so i'll wait until summer to address it. thanks for the tips. now i have to see if i still saved a cast iron big block cylinder head.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: T/A hood warped how to fix [Re: ThermoQuad] #1408708
03/26/13 11:15 AM
03/26/13 11:15 AM
NJ
70_FJ6_RR Offline
70_FJ6_RR  Offline
NJ
This works...
Yeah, I would be careful with the advice given here! You have more control with a propane torch and heating the area you want to straighten, than you do the sun heating the entire hood with the weight of a cylinder head, possibly to warp the center of the hood. On here, you'll get advice, and that's all it is. Like I said, it takes talent. Spend a few minutes on the phone with some fiberglass companies, or find a good local body guy.
Re: T/A hood warped how to fix [Re: Jerry] #1408709
03/26/13 12:55 PM
03/26/13 12:55 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
ProPain torches, heat guns ..... whata' buncha' guyz .....
.... WHAT you need to do it make a jig on what the correct contour of the hood is supposed to be and then SLICE UP the bracing on the hood .... then put the hood into the jig and then GLASS OVER the bracing .....
Then find some lighter hood springs ...THAT is what has caused the problems in the first place (other than the hood not having proper bracing for the application) ...
Re: T/A hood warped how to fix [Re: dOc !] #1408710
03/30/13 10:07 AM
03/30/13 10:07 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
What's with giving away the proper answer/advice here Doc? ....seriously that's what's needed in this case.
bricks, cylinder heads, torches ...what next?,....I suppose a brush and roller for paint perhaps?
