Exchange Flowmasters for Walkers on 69 Coronet question #1407542
03/24/13 10:47 AM
03/24/13 10:47 AM
Northern NJ
68 Sat Offline OP
68 Sat  Offline OP
Northern NJ
I have a 69 Coronet 500 with a 318 with full 2 1/4" dual exhaust, x-pipe and flowmasters. They sound great but are a bit loud for me and I want to put something that is less noisy. Has anyone used the Walkers and will they accomplish my goal of a slighty less noisy ride? If so does anyone need a set of flowmasters cheap?
1963 Chrysler 300 Pace Setter Convertible 21K mile survivor 1969 Dodge Coronet 500 1956 Desoto Hemi 1955 Chrysler C300
Re: Exchange Flowmasters for Walkers on 69 Coronet question [Re: 68 Sat] #1407543
03/24/13 12:26 PM
03/24/13 12:26 PM
Kenosha, Wi
GOLDMYN Offline
GOLDMYN  Offline
Kenosha, Wi
WOW! Is that your storage garage? Who does your floors? and by the way, nice car. I'd be proud to own that!
Semper Fi
Re: Exchange Flowmasters for Walkers on 69 Coronet question [Re: 68 Sat] #1407544
03/24/13 01:29 PM
03/24/13 01:29 PM
MO, USA
Tom Hand Offline
Tom Hand  Offline
MO, USA
Dynomax 17747s are 2.25" in and out, offset in, center out, 20" long case and will fit right on IF you have the stock muffler configuration pipes on it.
These will outflow the mufflers you have plus they will be significantly quieter at all speeds.
Tom
Re: Exchange Flowmasters for Walkers on 69 Coronet question [Re: Tom Hand] #1407545
03/24/13 02:11 PM
03/24/13 02:11 PM
Detroit
Kidsixpack Offline
Kidsixpack  Offline
Detroit
I went from Flowmaster to Walkers on my Bee and they are great! Down right quiet until you hit it hard!
KID
Re: Exchange Flowmasters for Walkers on 69 Coronet question [Re: Kidsixpack] #1407546
03/24/13 03:25 PM
03/24/13 03:25 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Save some moeny and put on a pair of resonators, that will mellow out the noise and make it so you dont have to replace the existing mufflers. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Exchange Flowmasters for Walkers on 69 Coronet question [Re: Tom Hand] #1407547
03/24/13 04:12 PM
03/24/13 04:12 PM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
Tom
I love my Dynomaz super turbos.
Re: Exchange Flowmasters for Walkers on 69 Coronet question [Re: wally426ci] #1407548
03/24/13 05:11 PM
03/24/13 05:11 PM
Northern NJ
68 Sat Offline OP
68 Sat  Offline OP
Northern NJ
Not my garage but a friends. Thanks for all the input. The flow masters are 13" and the walkers are 22" Long. Otherwise the switch should be seem less.
Re: Exchange Flowmasters for Walkers on 69 Coronet question [Re: 68 Sat] #1407549
03/24/13 07:57 PM
03/24/13 07:57 PM
Central NC
gch Offline
gch  Offline
Central NC
A longer muffler will always be quiter.I love my hemi super turbos.Nice and mellow for an old fart like me.
Re: Exchange Flowmasters for Walkers on 69 Coronet question [Re: astjp2] #1407550
03/24/13 08:01 PM
03/24/13 08:01 PM
X2, add some glasspacks alongside the rear leafs. Get ones that dont neck down at the nipples
Re: Exchange Flowmasters for Walkers on 69 Coronet question [Re: 68 Sat] #1407551
03/24/13 08:05 PM
03/24/13 08:05 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
You may want to stay away from a muffler with a center inlet or outlet, depending the muffler's design. A straight through muffler like a dynomax ultra flow, well you're fine there. A dynomax super turbo muffler like this one, if you follow the path of the exhaust you can see all the exhaust has to cross over and under the center tube at one point. Now if there's lots of room in the case, you're okay, but if there's not, you're giving up flow. Maybe not a big deal for a 318 but I would keep it in mind anyway.
Re: Exchange Flowmasters for Walkers on 69 Coronet question [Re: DaytonaTurbo] #1407552
03/26/13 12:09 PM
03/26/13 12:09 PM
East Central Illinois
jeff57 Offline
jeff57  Offline
magnaflow #11225. will fit right in with no change to pipes and they breathe very good. no drone at highway speed either. jeff57 muffler shop owner
