Re: 1971 b body 14x6 wheels ?
[Re: ryangtogtx]
#140613
10/29/08 08:48 PM
10/29/08 08:48 PM
Posts: 874 El Cerrito, by San Francisco
last426
I didn't ask about trim rings. I have gone round and round about these rims, correct part number, phantom part number, should be part number, could be part number, and on and on. When I got the car I talked with Frank Balderson (sp), a great guy by the way, and he helped with the broadcast sheet. He also explained how, on May 1, Mopar changed from body color wheels to black and that was why mine (5/3/71) had black. I never asked the original owner but I bet that is why he switched to ralleys. Thanks, everyone, for the help. Kim
[Re: last426]
#140616
10/29/08 09:23 PM
10/29/08 09:23 PM
Posts: 1,178 MN
ryangtogtx
MN
I didn't ask about trim rings. I have gone round and round about these rims, correct part number, phantom part number, should be part number, could be part number, and on and on. When I got the car I talked with Frank Balderson (sp), a great guy by the way, and he helped with the broadcast sheet. He also explained how, on May 1, Mopar changed from body color wheels to black and that was why mine (5/3/71) had black. I never asked the original owner buy I bet that is why he switched to ralleys. Thanks, everyone, for the help. Kim
Sorry, I confused your question with someone else. Your broadcast clearly states the 2944329 (29) wheel which, according to GG, is correct for either B or E body in 71, while in the same book it states that 2944327 (27) is for b body only. Eric (Butterscotch71) and I have discussed this and I think either one is acceptable. On a side note, these wheels were also found on later year cars as well. Although they may have different part numbers on them, they are physically the same (14x6 JJ). Here is a picture that shows a 2944329 on the left ('71 b or e) and a 3580060 on the right ('72-'74 b body).
[Re: ryangtogtx]
#140617
10/29/08 09:37 PM
10/29/08 09:37 PM
last426
The car is almost totally original -- heck, the original owner even game me the original light bulbs that came with it. I owe it to the car to get the closest to correct wheels that I can. And to top it off, I am still unsure about the exact part number I am looking for. So it goes, Kim.
[Re: ryangtogtx]
#140619
10/29/08 11:35 PM
10/29/08 11:35 PM
last426
Kim, I'm not sure why you are confused about your wheels. If your broadcast sheet lists code 29 (which is the code for part number 2944329) then wouldn't that be the correct wheel?
I looked for the email but can't find it. Suffice to say that I have gone around this issue in depth twice. If I remember correctly, it was left with the 2944329 not being a real part number (I think it was called phantom but I could be wrong) and there were not any actual wheels that had that number. Rather the real number was something else and on and on and on. I think the person was here who told me this. But if you have a wheel with that number, then that is great and solves the riddle. So, I will be looking for a good set of 2944329s.
[Re: last426]
#140622
10/30/08 07:47 AM
10/30/08 07:47 AM
Posts: 1,652 Calgary, Alberta Canada
m46rat
The guy who mentioned the 29 number as "phantom" was Bill Rolik here on this board. Ryan, if you have a 29 rim could you please post a good picture of it, ie, the part number and valve stem hole area? If not, then can we assume that the only 14x6.0 wheels are 27's, ones with out part numbers(made by Kelsey Hayes) and ones with part number 2944 242, used as spares in the trunks of cars with 6.0 rims on them. Have I missed anything?
[Re: m46rat]
#140623
10/30/08 09:09 AM
10/30/08 09:09 AM
Posts: 2,901 New Jersey Bada Bing
bremotorsports
The SERVICE part number (in the parts catalog, and for sale over the counter) for the 14 X 6 wheels is 3420978. This covers B-Body and E-Body applications. I have on hand right now more than a dozen NOS 3420978 wheels, NONE OF WHICH are stamped 2944329 (engineering number). In fact, they have no numbers. I did have two NOS 3420978 (with 2944327 engineering number) B-Body wheels last year, which were sold to Eric Manuel (I know others who have had ORIGINAL, PRODUCTION 327's on hand). The ORIGINAL WHEELS on my 71 340 Cuda convertible, which theoretically should have 2944329 (engineering number)stamped on them, are BLANK. Based on the fact I have never seen or even heard of a 329 wheel in existence anywhere, it still falls into the "phantom" category.
Bill Rolik
P.S. Ryan, I will second Dwight's request: If you say you have a 329 wheel, let's see it!
[Re: bremotorsports]
#140624
10/30/08 09:20 AM
10/30/08 09:20 AM
m46rat
Bill: I would add that all the blank 14x6.0's are all made by Kelsey Hayes and are stamped in a small type of font. The 327 wheels(I have several) are made by some other wheel company and have a much larger font to the numbers stamped on either side of the valve stem. I think(I will have to check tonight) that the Kelsey Hayes wheels have a 6.0 stamped to the right of the valve stem after the day code stamping. The 327 rims have no 6.0 but have a pentastar stamped instead. Other than that the rims are identical. Also, I would state this, that the 327 rim was avaiable as far back as Aug of 1969(I have one) and at that time, like all other wheels, had NO PART NUMBER stamped above the valve stem. Because of this, I would say that this rim was obviously NOT a 71 B Body rim only. It was used for 70 production cars as well. Bill, can you comment on the 2944 242 spare tire 6.0 rim?
[Re: m46rat]
#140625
10/30/08 10:45 AM
10/30/08 10:45 AM
Posts: 1,178 MN
ryangtogtx
MN
I will gladly take better pictures of the wheels I have. Specifically the purple one (which I bought on eBay several years ago as a single wheel). The pics will have to wait until after the weekend of Nov. 8 though since they are in storage at my dad's house. Thanks for all of the great input on these wheels. It's a very perplexing question. My next question is why would they code a broadcast sheet with a code which is supposedly the last two digits of a part number when in fact it is only an engineering number as opposed to the actual part number??
#140626
11/01/08 09:24 PM
11/01/08 09:24 PM
Posts: 3,334 home of the Buckeyes
Butterscotch71
Lost Title
Lost Title
Bill Rolik
Actually you sold me the NOS 27 wheels last year. Still trying to piece together a complete set of good wheels for my 71 runner
addict:to devote or surrender (oneself) to something habitually or obsessively ....hmmmm
[Re: ryangtogtx]
#140630
11/10/08 10:59 AM
11/10/08 10:59 AM
bremotorsports
Ryan,
When you are able to take photos of the numbers on the "329" wheel, you may also want to compare both the 329 and 327 wheels for the following:
Offset Wheel Thickness (i.e., gauge of steel) Vendor Markings Wheel Style (JJ vs. whatever)
There has to be SOME reason (even with Chrysler's sometimes bizarre thinking) as to why there are multiple wheels for what should be similar applications.
Bill Rolik
