Page 2 of 4 1 2 3 4
Re: 1971 b body 14x6 wheels ? [Re: ryangtogtx] #140611
10/29/08 06:45 PM
10/29/08 06:45 PM
El Cerrito, by San Francisco
last426 Offline
last426  Offline
Here it is. Kim
Re: 1971 b body 14x6 wheels ? [Re: last426] #140612
10/29/08 08:05 PM
10/29/08 08:05 PM
MN
ryangtogtx Offline
ryangtogtx  Offline
MN
Well Kim you're right. I learned something today. 14x6 is correct for your car painted black with aluminum hubcaps(red stripe w/ tri-angle). You were asking about trim rings, but where on the sheet does it list them? I couldn't tell under the wheel cover box 2 because of the crayon writing. If it's there is should read code 24 (trim ring 2944424) according to the GG book.
Re: 1971 b body 14x6 wheels ? [Re: ryangtogtx] #140613
10/29/08 08:48 PM
10/29/08 08:48 PM
last426 Offline
last426  Offline
I didn't ask about trim rings. I have gone round and round about these rims, correct part number, phantom part number, should be part number, could be part number, and on and on. When I got the car I talked with Frank Balderson (sp), a great guy by the way, and he helped with the broadcast sheet. He also explained how, on May 1, Mopar changed from body color wheels to black and that was why mine (5/3/71) had black. I never asked the original owner but I bet that is why he switched to ralleys. Thanks, everyone, for the help. Kim
Re: 1971 b body 14x6 wheels ? [Re: ryangtogtx] #140614
10/29/08 08:58 PM
10/29/08 08:58 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
The T93 tire code cinches it. G70x14 RWL Polyglas tires.
Re: 1971 b body 14x6 wheels ? [Re: m46rat] #140615
10/29/08 09:08 PM
10/29/08 09:08 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Great info. This is a favorite toggle.Thanks guys.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: 1971 b body 14x6 wheels ? [Re: last426] #140616
10/29/08 09:23 PM
10/29/08 09:23 PM
MN
ryangtogtx Offline
ryangtogtx  Offline
MN
I didn't ask about trim rings. I have gone round and round about these rims, correct part number, phantom part number, should be part number, could be part number, and on and on. When I got the car I talked with Frank Balderson (sp), a great guy by the way, and he helped with the broadcast sheet. He also explained how, on May 1, Mopar changed from body color wheels to black and that was why mine (5/3/71) had black. I never asked the original owner buy I bet that is why he switched to ralleys. Thanks, everyone, for the help. Kim
Sorry, I confused your question with someone else. Your broadcast clearly states the 2944329 (29) wheel which, according to GG, is correct for either B or E body in 71, while in the same book it states that 2944327 (27) is for b body only. Eric (Butterscotch71) and I have discussed this and I think either one is acceptable. On a side note, these wheels were also found on later year cars as well. Although they may have different part numbers on them, they are physically the same (14x6 JJ). Here is a picture that shows a 2944329 on the left ('71 b or e) and a 3580060 on the right ('72-'74 b body).
Re: 1971 b body 14x6 wheels ? [Re: ryangtogtx] #140617
10/29/08 09:37 PM
10/29/08 09:37 PM
last426 Offline
last426  Offline
The car is almost totally original -- heck, the original owner even game me the original light bulbs that came with it. I owe it to the car to get the closest to correct wheels that I can. And to top it off, I am still unsure about the exact part number I am looking for. So it goes, Kim.
Re: 1971 b body 14x6 wheels ? [Re: last426] #140618
10/29/08 09:57 PM
10/29/08 09:57 PM
MN
ryangtogtx Offline
ryangtogtx  Offline
MN
Kim, I'm not sure why you are confused about your wheels. If your broadcast sheet lists code 29 (which is the code for part number 2944329) then wouldn't that be the correct wheel? I think you have definitive proof. Eric is missing his broadcast sheet so we discussed the various reasons why different part numbers exist for the same part. It could have been a production date issue or maybe an assembly plant difference. Who knows for sure??? Regardless, both your broadcast and mine list 29 as the correct wheel. Your production date is May '71, mine is Dec. '70. The only difference is that yours were painted black and mine body color.
Re: 1971 b body 14x6 wheels ? [Re: ryangtogtx] #140619
10/29/08 11:35 PM
10/29/08 11:35 PM
last426 Offline
last426  Offline
I looked for the email but can't find it. Suffice to say that I have gone around this issue in depth twice. If I remember correctly, it was left with the 2944329 not being a real part number (I think it was called phantom but I could be wrong) and there were not any actual wheels that had that number. Rather the real number was something else and on and on and on. I think the person was here who told me this. But if you have a wheel with that number, then that is great and solves the riddle. So, I will be looking for a good set of 2944329s.
Re: 1971 b body 14x6 wheels ? [Re: last426] #140620
10/29/08 11:59 PM
10/29/08 11:59 PM
MN
ryangtogtx Offline
ryangtogtx  Offline
MN
Kim, as you know, these wheels must be the most difficult to find. I'm pretty sure I only have one 2944327 and one 2944329 out of the seven total 14x6 wheels I've been able to locate. All of them are identical physically. I used to be like you and only wanted a specific part number that would be correct for my car, but as time went on and I discovered how difficult it is to find them, I resigned myself to simply finding wheels that were correct in appearance since the part numbers are pretty much indistinguishable anyway. I wish you good luck in your quest.
Re: 1971 b body 14x6 wheels ? [Re: ryangtogtx] #140621
10/30/08 12:36 AM
10/30/08 12:36 AM
last426 Offline
last426  Offline
Thanks, till then the ralleys will have to do. Heck, I only drive about 80 miles a years anyway. Kim.
Re: 1971 b body 14x6 wheels ? [Re: last426] #140622
10/30/08 07:47 AM
10/30/08 07:47 AM
m46rat Offline
m46rat  Offline
The guy who mentioned the 29 number as "phantom" was Bill Rolik here on this board. Ryan, if you have a 29 rim could you please post a good picture of it, ie, the part number and valve stem hole area? If not, then can we assume that the only 14x6.0 wheels are 27's, ones with out part numbers(made by Kelsey Hayes) and ones with part number 2944 242, used as spares in the trunks of cars with 6.0 rims on them. Have I missed anything?
Re: 1971 b body 14x6 wheels ? [Re: m46rat] #140623
10/30/08 09:09 AM
10/30/08 09:09 AM
New Jersey Bada Bing
bremotorsports Online content
bremotorsports  Online Content
The SERVICE part number (in the parts catalog, and for sale over the counter) for the 14 X 6 wheels is 3420978. This covers B-Body and E-Body applications. I have on hand right now more than a dozen NOS 3420978 wheels, NONE OF WHICH are stamped 2944329 (engineering number). In fact, they have no numbers. I did have two NOS 3420978 (with 2944327 engineering number) B-Body wheels last year, which were sold to Eric Manuel (I know others who have had ORIGINAL, PRODUCTION 327's on hand). The ORIGINAL WHEELS on my 71 340 Cuda convertible, which theoretically should have 2944329 (engineering number)stamped on them, are BLANK. Based on the fact I have never seen or even heard of a 329 wheel in existence anywhere, it still falls into the "phantom" category.
Bill Rolik
P.S. Ryan, I will second Dwight's request: If you say you have a 329 wheel, let's see it!
Re: 1971 b body 14x6 wheels ? [Re: bremotorsports] #140624
10/30/08 09:20 AM
10/30/08 09:20 AM
m46rat Offline
m46rat  Offline
Bill: I would add that all the blank 14x6.0's are all made by Kelsey Hayes and are stamped in a small type of font. The 327 wheels(I have several) are made by some other wheel company and have a much larger font to the numbers stamped on either side of the valve stem. I think(I will have to check tonight) that the Kelsey Hayes wheels have a 6.0 stamped to the right of the valve stem after the day code stamping. The 327 rims have no 6.0 but have a pentastar stamped instead. Other than that the rims are identical. Also, I would state this, that the 327 rim was avaiable as far back as Aug of 1969(I have one) and at that time, like all other wheels, had NO PART NUMBER stamped above the valve stem. Because of this, I would say that this rim was obviously NOT a 71 B Body rim only. It was used for 70 production cars as well. Bill, can you comment on the 2944 242 spare tire 6.0 rim?
Re: 1971 b body 14x6 wheels ? [Re: m46rat] #140625
10/30/08 10:45 AM
10/30/08 10:45 AM
MN
ryangtogtx Offline
ryangtogtx  Offline
MN
I will gladly take better pictures of the wheels I have. Specifically the purple one (which I bought on eBay several years ago as a single wheel). The pics will have to wait until after the weekend of Nov. 8 though since they are in storage at my dad's house. Thanks for all of the great input on these wheels. It's a very perplexing question. My next question is why would they code a broadcast sheet with a code which is supposedly the last two digits of a part number when in fact it is only an engineering number as opposed to the actual part number??
Re: 1971 b body 14x6 wheels ? [Re: bremotorsports] #140626
11/01/08 09:24 PM
11/01/08 09:24 PM
home of the Buckeyes
Butterscotch71 Offline
Lost Title
Lost Title
Bill Rolik
Actually you sold me the NOS 27 wheels last year.
Still trying to piece together a complete set of good wheels for my 71 runner
addict:to devote or surrender (oneself) to something habitually or obsessively ....hmmmm
Re: 1971 b body 14x6 wheels ? [Re: Butterscotch71] #140627
11/01/08 09:51 PM
11/01/08 09:51 PM
m46rat Offline
m46rat  Offline
EL5 71: I have a couple of extra 327 rims, PM me if you want some details. Are the 327 rims you have actually dated in the 1971 production year?
Re: 1971 b body 14x6 wheels ? [Re: Butterscotch71] #140628
11/02/08 09:40 AM
11/02/08 09:40 AM
I have not seen any more 327 wheels since. The balance of my wheels are all blank NOS 3420978's.
Leave no stone unturned in your quest!
Bill Rolik
Re: 1971 b body 14x6 wheels ? [Re: bremotorsports] #140629
11/10/08 01:02 AM
11/10/08 01:02 AM
last426 Offline
last426  Offline
That settles it then. I need a good set of 3420978 steel wheels (1971 if possible) to put the mopar dog dishes on my hemi charger. Kim
Re: 1971 b body 14x6 wheels ? [Re: ryangtogtx] #140630
11/10/08 10:59 AM
11/10/08 10:59 AM
Ryan,
When you are able to take photos of the numbers on the "329" wheel, you may also want to compare both the 329 and 327 wheels for the following:
Offset
Wheel Thickness (i.e., gauge of steel)
Vendor Markings
Wheel Style (JJ vs. whatever)
There has to be SOME reason (even with Chrysler's sometimes bizarre thinking) as to why there are multiple wheels for what should be similar applications.
Bill Rolik
Page 2 of 4 1 2 3 4
