Engine to Transmission brace on 340/360 #1406005
03/21/13 08:57 AM
03/21/13 08:57 AM
WASHINGTON, PA
11secaarcuda Offline OP
WASHINGTON, PA
Is the engine to transmission brace that goes from the bellhousing to the drivers side of the engine different for 340 engines and 360 engines? I have a 78 360 block I am putting in my Cuda that originally had a 340 and now this brace seems to short.
67 Dart GT 340 4 speed
70 AAR Cuda 408 6 barrel
96 Indy Ram original owner
2011 Hemi Durango
Re: Engine to Transmission brace on 340/360 [Re: 11secaarcuda] #1406006
03/21/13 10:39 AM
03/21/13 10:39 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Personally wouldn't worry about it. Seen many put together with out and no evil effects. I personally have left them off many times on engines that have no way to put them on past headers etc and not had any problems. IMO they are overkill
Re: Engine to Transmission brace on 340/360 [Re: MoparforLife] #1406007
03/21/13 10:43 AM
03/21/13 10:43 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
In the late model trucks, magnum V8s have a brace on each side from the motor mount boss to the bell, but only on automatics. Manuals did not have them.
Must not be THAT critical?
**Photobucket sucks**
Re: Engine to Transmission brace on 340/360 [Re: 11secaarcuda] #1406008
03/21/13 11:10 AM
03/21/13 11:10 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I think they are all the same size and length for small blocks? If they fit why not use them? Look closer, I bet it fit's.
Re: Engine to Transmission brace on 340/360 [Re: Challenger 1] #1406009
03/21/13 11:27 AM
03/21/13 11:27 AM
BDW Online content
BDW  Online Content
Anyone have a pic of it installed? Never seen that, is it both sides on the old cars?
Thx
Re: Engine to Transmission brace on 340/360 [Re: BDW] #1406010
03/21/13 11:30 AM
03/21/13 11:30 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
For some reason I thought I read where the 360 has one mounting boss in a slightly different location then the 318/340.
Re: Engine to Transmission brace on 340/360 [Re: MoparforLife] #1406011
03/21/13 11:35 AM
03/21/13 11:35 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Evidently they were put there for a reason,doubt they (Chrysler) would have went to the expense otherwise .
Re: Engine to Transmission brace on 340/360 [Re: 62maxwgn] #1406012
03/21/13 02:06 PM
03/21/13 02:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The unsupported portion of the SB bellhousing extends further below the block than the BB does, that's why the braces are there...to support the lower part of the bellhousing.
Re: Engine to Transmission brace on 340/360 [Re: John_Kunkel] #1406013
03/21/13 03:49 PM
03/21/13 03:49 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
they moved the bolt hole sometime in the mid 70s and I think they did it again with the magnums.
Re: Engine to Transmission brace on 340/360 [Re: HotRodDave] #1406014
03/21/13 05:32 PM
03/21/13 05:32 PM
WASHINGTON, PA
WASHINGTON, PA
Thanks, it is a 1978 block. That must be my problem. Anybody got one?
2011 Hemi Durango
Re: Engine to Transmission brace on 340/360 [Re: Challenger 1] #1406015
03/21/13 10:13 PM
03/21/13 10:13 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
No, OP is correct. From my experiences, 318 and 340 are the same. But when I swapped my 318 out of the Barracuda for a 360, only one brace would fit the other was about an inch short IIRC. Can't remember off hand which side is short. The 360 block had the machined boss at the same location as the 318, but the boss was not drilled for a bolt at the 318/340 location. Don't know if this is true with all 360's or not (Mine is a '74 casting).
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Engine to Transmission brace on 340/360 [Re: BDW] #1823473
05/10/15 02:57 PM
05/10/15 02:57 PM
BDW Online content
BDW  Online Content
Thx
Still looking for a pic, wondering if I should add these.
Not clear on where they attach.
Re: Engine to Transmission brace on 340/360 [Re: GO_Fish] #1824111
05/11/15 01:16 PM
05/11/15 01:16 PM
same here (318 to 360), one fit one did not. I'd want em on there
Re: Engine to Transmission brace on 340/360 [Re: RapidRobert] #1825321
05/12/15 11:46 PM
05/12/15 11:46 PM
Central TX
roe Offline
roe  Offline
Central TX
If it's just barely too short what about using some grade 8 washers as spacers? I have headers on mine so it came off. Never had any issues without it
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Engine to Transmission brace on 340/360 [Re: 62maxwgn] #1825499
05/13/15 09:04 AM
05/13/15 09:04 AM
Troy,MI
Siba Offline
Siba  Offline
Troy,MI
Evidently they were put there for a reason,doubt they (Chrysler) would have went to the expense otherwise . <img src="/ubbthreads/images/graemlins/Twocents.gif" alt="" />
They are put there to raise the natural frequency of the powertrain bending mode. On modern engines (take a look at a 5.7l hemi) the structure is incorporated into the dust cover.
Re: Engine to Transmission brace on 340/360 [Re: 11secaarcuda] #1825506
05/13/15 09:35 AM
05/13/15 09:35 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
If you have two short ones just slice the two together, trim till they fit tight, tack then tig it, grind till smooth. Nobody will notice when painted. I would use them.
The new 5.7s trans are bolted to the oil pan which will be a pita with an aftermarket pan.
Re: Engine to Transmission brace on 340/360 [Re: 11secaarcuda] #1825513
05/13/15 09:57 AM
05/13/15 09:57 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
my car hasnt had that brace installed since 1982. never had a problem
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
Re: Engine to Transmission brace on 340/360 [Re: 11secaarcuda] #1825565
05/13/15 11:04 AM
05/13/15 11:04 AM
BDW Online content
BDW  Online Content
Still can't visualize where they go,
Can some please post a pic of them installed?
