Engine to Transmission brace on 340/360
#1406005
03/21/13 08:57 AM
03/21/13 08:57 AM
Posts: 2,403 WASHINGTON, PA
11secaarcuda
WASHINGTON, PA
Is the engine to transmission brace that goes from the bellhousing to the drivers side of the engine different for 340 engines and 360 engines? I have a 78 360 block I am putting in my Cuda that originally had a 340 and now this brace seems to short.
67 Dart GT 340 4 speed 70 AAR Cuda 408 6 barrel 96 Indy Ram original owner 2011 Hemi Durango
Re: Engine to Transmission brace on 340/360
[Re: MoparforLife]
#1406007
03/21/13 10:43 AM
03/21/13 10:43 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
In the late model trucks, magnum V8s have a brace on each side from the motor mount boss to the bell, but only on automatics. Manuals did not have them.
Must not be THAT critical?
**Photobucket sucks**
[Re: MoparforLife]
#1406011
03/21/13 11:35 AM
03/21/13 11:35 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Personally wouldn't worry about it. Seen many put together with out and no evil effects. I personally have left them off many times on engines that have no way to put them on past headers etc and not had any problems. IMO they are overkill
Evidently they were put there for a reason,doubt they (Chrysler) would have went to the expense otherwise .
[Re: 62maxwgn]
#1406012
03/21/13 02:06 PM
03/21/13 02:06 PM
Posts: 25,747 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The unsupported portion of the SB bellhousing extends further below the block than the BB does, that's why the braces are there...to support the lower part of the bellhousing.
[Re: BDW]
#1823473
05/10/15 02:57 PM
05/10/15 02:57 PM
Posts: 4,707 Florida
BDW
Anyone have a pic of it installed? Never seen that, is it both sides on the old cars?
Thx Still looking for a pic, wondering if I should add these. Not clear on where they attach.
[Re: GO_Fish]
#1824111
05/11/15 01:16 PM
05/11/15 01:16 PM
RapidRobert
same here (318 to 360), one fit one did not. I'd want em on there
[Re: RapidRobert]
#1825321
05/12/15 11:46 PM
05/12/15 11:46 PM
Posts: 3,344 Central TX
roe
Central TX
If it's just barely too short what about using some grade 8 washers as spacers? I have headers on mine so it came off. Never had any issues without it
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
[Re: 62maxwgn]
#1825499
05/13/15 09:04 AM
05/13/15 09:04 AM
Posts: 128 Troy,MI
Siba
Troy,MI
Personally wouldn't worry about it. Seen many put together with out and no evil effects. I personally have left them off many times on engines that have no way to put them on past headers etc and not had any problems. IMO they are overkill Evidently they were put there for a reason,doubt they (Chrysler) would have went to the expense otherwise . <img src="/ubbthreads/images/graemlins/Twocents.gif" alt="" /> They are put there to raise the natural frequency of the powertrain bending mode. On modern engines (take a look at a 5.7l hemi) the structure is incorporated into the dust cover.
[Re: 11secaarcuda]
#1825513
05/13/15 09:57 AM
05/13/15 09:57 AM
Posts: 15,478 the boonies
aarcuda
the boonies
my car hasnt had that brace installed since 1982. never had a problem
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
