Vacuum Advance Or Not? #1405692
03/20/13 10:39 PM
03/20/13 10:39 PM
Gloucester,VA STOP MOVING HERE
RangerDan440 Offline OP
Mild 68 440, .509, etc
Just rebuilt the carb and gave it a super tune and it had a slight hesitation when stomping on it. New power valve, clean jets, accelerator pump, etc. I normally dont run a vacuum advance, its always run better without but I decided to try it again and see if that cured the hesitation.
It did, it revved smoothly and quickly but when I drove it, the timing was retarded enough so that it was noticeably down on power and pinging terribly when I put it on a load.
Re: Vacuum Advance Or Not? [Re: RangerDan440] #1405693
03/20/13 10:54 PM
03/20/13 10:54 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
What is the correlation between hooking up the vacuum advance and the retarded timing? Did you mean over advanced?
Was the hesitation there before you tore the carb down? Or did it appear afterward?
Master, again and still
Re: Vacuum Advance Or Not? [Re: DaveRS23] #1405694
03/20/13 11:01 PM
03/20/13 11:01 PM
oops, yeah I meant to say with the Vac Adv hooked up that it was too far advanced that it ran terrible.
And no, before the rebuild I didnt have the hesitation problem, it ran great. The reason for the rebuild was the old gas tank was rusting from the inside and there was rust all in the filter and carb so I R&R'd the entire fuel system from the tank forward.
Re: Vacuum Advance Or Not? [Re: RangerDan440] #1405695
03/20/13 11:12 PM
03/20/13 11:12 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
The timing should be set with the vacuum advance disconnected. For that combo. about 38o at full advance, 2200-2500 rpm (centrifical and static). Then hook the vacuum up, this will probably take the advance to 52o or so, probably too much. If it is knocking under light load then the vacuum advance can be dialed out a few degrees at a time until knock disappears.
Re: Vacuum Advance Or Not? [Re: 469runner] #1405696
03/20/13 11:18 PM
03/20/13 11:18 PM
so did too much timing cause the hesitation before I hooked up the vacuum advance?
Re: Vacuum Advance Or Not? [Re: RangerDan440] #1405697
03/20/13 11:38 PM
03/20/13 11:38 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what is your initial and your total advance without the vac advance hooked up ? what distributor are you running ?
Re: Vacuum Advance Or Not? [Re: RangerDan440] #1405698
03/21/13 12:48 AM
03/21/13 12:48 AM
If nothing was altered but the carb I would start back there for the hesitation cause. For the timing I would set the initial with the "vacuum gauge method" starting with 15BTDC then shorten the slots to get 36-38 (depends on octane/quench) then play with springs & toss the heavy spring with the elongated loop on one end & sub in a mr gasket or MP light spring & keep the OE light spring for a starting combo & staying just under the pinging point at WOT up thru the gears on your hottest/driest day then hookup the vac adv & solder strips of feeler gauges on the back side to limit the notched arms' travel into the pod staying just under the pinging point at a steady interstate cruise (high vacuum) speed at an RPM at or above the point where the mech slots are maxed out (full advance) then in everyday driving stay just under the pinging point & adj with a 3/32" allen wrench in the pod nipple & CCW slows the onset of the curve. Alot of work but ALOT of gain to be had. Must be done IN ORDER. Note that vacuum advance will alter rotor phasing & can contribute to misfiring if the rotor tip gets far enough away from the underside of the metal cap terminal. NAPA offers an Echlin MO3000 rotor that has an .060" longer blade for $8 & change out the door & there's several ways to alter rotor phasing. Drill a 1/2" hole in the top flat of your dist cap 2/3 of the way between the center terminal and the #1 terminal & freeze the rotor by shining your timing light straight down in there when running & note that ONLY the vac adv (from eng load change) changes rotor phasing position.
Re: Vacuum Advance Or Not? [Re: RangerDan440] #1405699
03/21/13 12:55 AM
03/21/13 12:55 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Are you running it to manifold or ported vacuum?
