Vacuum Advance Or Not?
#1405692
03/20/13 10:39 PM
03/20/13 10:39 PM
Posts: 12,861 Gloucester,VA STOP MOVING HERE
RangerDan440
Mild 68 440, .509, etc
Just rebuilt the carb and gave it a super tune and it had a slight hesitation when stomping on it. New power valve, clean jets, accelerator pump, etc. I normally dont run a vacuum advance, its always run better without but I decided to try it again and see if that cured the hesitation.
It did, it revved smoothly and quickly but when I drove it, the timing was retarded enough so that it was noticeably down on power and pinging terribly when I put it on a load.
Re: Vacuum Advance Or Not?
[Re: RangerDan440]
#1405693
03/20/13 10:54 PM
03/20/13 10:54 PM
Posts: 12,074 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
What is the correlation between hooking up the vacuum advance and the retarded timing? Did you mean over advanced?
Was the hesitation there before you tore the carb down? Or did it appear afterward?
Master, again and still
[Re: RangerDan440]
#1405697
03/20/13 11:38 PM
03/20/13 11:38 PM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
so did too much timing cause the hesitation before I hooked up the vacuum advance?
what is your initial and your total advance without the vac advance hooked up ? what distributor are you running ?
[Re: RangerDan440]
#1405699
03/21/13 12:55 AM
03/21/13 12:55 AM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
Are you running it to manifold or ported vacuum?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
