Correct Road Wheels #1405667
03/20/13 10:33 PM
03/20/13 10:33 PM
Jackson, Mississippi
CornDogsCharger Offline OP
What is the correct size Road Wheels for my Lynch Rd built '69 Super Bee 383/4spd? I know the car had 14s on it but should they be 5.5, 6, 7 inches wide? Thanks
Justin
"CornDog"
1966 Dodge Charger
1968 Plymouth Satellite (Un-Restored "Survivor")
1969 Dodge Charger (W.B. General Lee)
1969 Dodge Charger (Future DMCL Clone)
1969 Dodge Super Bee, 383 4spd
Re: Correct Road Wheels [Re: CornDogsCharger] #1405668
03/20/13 10:40 PM
03/20/13 10:40 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
14x5.5...
Re: Correct Road Wheels [Re: ph23vo] #1405669
03/20/13 11:23 PM
03/20/13 11:23 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
14x5.5" (all* 383 4bbl & 440 4bbl '69 MOPAR b-body musclecars had 14x5.5" wheels)
* except for the few that were originally OPTIONED with the infamous 15x6.0" "recall" wheels
Re: Correct Road Wheels [Re: 6bblgt] #1405670
03/20/13 11:38 PM
03/20/13 11:38 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
A12's?
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: Correct Road Wheels [Re: 69CoronetRT] #1405671
03/20/13 11:49 PM
03/20/13 11:49 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
A12's?
Are not 383 4bbl or 440 4bbl '69 MOPAR b-body's...
Re: Correct Road Wheels [Re: 1_WILD_RT] #1405672
03/21/13 12:49 AM
03/21/13 12:49 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
A12's?
I went brain dead and couldn't remember what wheels the A12s had. Instead of trying to clean litter boxes AND post, I should have done one or the other and not used shorthand.....
Seeking:
Re: Correct Road Wheels [Re: 69CoronetRT] #1405673
03/21/13 09:46 AM
03/21/13 09:46 AM
Thanks for the info guys. I was pretty sure it was 5.5 but I wasn't completely positive. Now I just need to find a set at a reasonable price.
Justin
"CornDog"
1966 Dodge Charger
Re: Correct Road Wheels [Re: CornDogsCharger] #1405674
03/21/13 05:47 PM
03/21/13 05:47 PM
Justin,
Don't forget that the 69 Road Wheel used a one year only trim ring that attached with 4 clips to the outside edge like a wheel weight would. It also had a little lip where the spoked part of the rim met the trim ring.
Re: Correct Road Wheels [Re: ] #1405675
03/22/13 09:52 AM
03/22/13 09:52 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
They are also not all chrome. They are a two piece wheel outside is just black metal.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Correct Road Wheels [Re: MOPARMIKE69] #1405676
03/22/13 11:18 AM
03/22/13 11:18 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
That is the correct wheel posted by Mike but a replacement trim ring.
As Brian stated above 1969 trim ring is very unique and a 1 year piece.
Re: Correct Road Wheels [Re: RJS] #1405677
03/22/13 12:11 PM
03/22/13 12:11 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
You are right, and you know why it is?????? You can't find originals!!!
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: Correct Road Wheels [Re: ] #1405678
03/22/13 11:06 PM
03/22/13 11:06 PM
Justin,
Interesting! I didn't know this. So let me make sure that I'm understanding this right... the '69-only trim ring actually hooks over the edge of the wheel instead of using the sharp teeth that scratch the inside of the wheel? Do you have a close-up picture of the backside of the trim ring?
As for the wheel itself... other than the date stamps, are they the same as other year model Road Wheels?
Justin
"CornDog"
1966 Dodge Charger
Re: Correct Road Wheels [Re: CornDogsCharger] #1405679
03/23/13 12:29 AM
03/23/13 12:29 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Correct (1) and incorrect (2) rings. See how the 69 ring has a slight 'lip' or overhang in the center circle?
Seeking:
Re: Correct Road Wheels [Re: 69CoronetRT] #1405680
03/23/13 12:37 AM
03/23/13 12:37 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
A little closer
Seeking:
Re: Correct Road Wheels [Re: CornDogsCharger] #1405681
03/23/13 12:46 PM
03/23/13 12:46 PM
Justin,
Justin
"CornDog"
1968 had the chrome outer part with no trim ring. Im pretty sure that 69 and up road wheels were all similar in the fact that they used a trim ring (69 - one year only as stated before) and had the rims painted black with the only thing being shiny was the satin chrome on the spoked part of the rim.
As for trying to find the 69 only trim rings, that is hard. I have actually started stock piling them and plan on restoring them when I get a chance to. They can be restored but area a major pain to do.
Re: Correct Road Wheels [Re: ] #1405682
03/23/13 02:42 PM
03/23/13 02:42 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
Brian, got a close up pic of them installed on your rim for reference?
1MYTGTX
Re: Correct Road Wheels [Re: 1MYTGTX] #1405683
03/23/13 05:03 PM
03/23/13 05:03 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Here's the "good stuff"
Re: Correct Road Wheels [Re: RJS] #1405684
03/23/13 05:54 PM
03/23/13 05:54 PM
radials...
Re: Correct Road Wheels [Re: ] #1405685
03/23/13 05:54 PM
03/23/13 05:54 PM
repro bias ply......
Re: Correct Road Wheels [Re: ] #1405686
03/23/13 05:56 PM
03/23/13 05:56 PM
before I restored them.....
