Correct Road Wheels
#1405667
03/20/13 10:33 PM
03/20/13 10:33 PM
Posts: 412 Jackson, Mississippi
CornDogsCharger
What is the correct size Road Wheels for my Lynch Rd built '69 Super Bee 383/4spd? I know the car had 14s on it but should they be 5.5, 6, 7 inches wide? Thanks
Justin "CornDog"
1966 Dodge Charger 1968 Plymouth Satellite (Un-Restored "Survivor") 1969 Dodge Charger (W.B. General Lee) 1969 Dodge Charger (Future DMCL Clone) 1969 Dodge Super Bee, 383 4spd
Re: Correct Road Wheels
[Re: ph23vo]
#1405669
03/20/13 11:23 PM
03/20/13 11:23 PM
Posts: 17,517 Las Vegas, NV
6bblgt
Las Vegas, NV
14x5.5" (all * 383 4bbl & 440 4bbl '69 MOPAR b-body musclecars had 14x5.5" wheels) * except for the few that were originally OPTIONED with the infamous 15x6.0" "recall" wheels
[Re: 69CoronetRT]
#1405673
03/21/13 09:46 AM
03/21/13 09:46 AM
CornDogsCharger
Thanks for the info guys. I was pretty sure it was 5.5 but I wasn't completely positive. Now I just need to find a set at a reasonable price.
Justin "CornDog"
[Re: CornDogsCharger]
#1405674
03/21/13 05:47 PM
03/21/13 05:47 PM
Justin,
Don't forget that the 69 Road Wheel used a one year only trim ring that attached with 4 clips to the outside edge like a wheel weight would. It also had a little lip where the spoked part of the rim met the trim ring.
[Re: ]
#1405675
03/22/13 09:52 AM
03/22/13 09:52 AM
Posts: 2,636 Nashville, TN
MOPARMIKE69
Nashville, TN
They are also not all chrome. They are a two piece wheel outside is just black metal.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: MOPARMIKE69]
#1405676
03/22/13 11:18 AM
03/22/13 11:18 AM
Posts: 6,224 JERSEY
RJS
JERSEY
That is the correct wheel posted by Mike but a replacement trim ring. As Brian stated above 1969 trim ring is very unique and a 1 year piece.
#1405679
03/23/13 12:29 AM
03/23/13 12:29 AM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
Correct (1) and incorrect (2) rings. See how the 69 ring has a slight 'lip' or overhang in the center circle?
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
#1405681
03/23/13 12:46 PM
03/23/13 12:46 PM
Justin,
Interesting! I didn't know this. So let me make sure that I'm understanding this right... the '69-only trim ring actually hooks over the edge of the wheel instead of using the sharp teeth that scratch the inside of the wheel? Do you have a close-up picture of the backside of the trim ring?
As for the wheel itself... other than the date stamps, are they the same as other year model Road Wheels?
Justin "CornDog"
1968 had the chrome outer part with no trim ring. Im pretty sure that 69 and up road wheels were all similar in the fact that they used a trim ring (69 - one year only as stated before) and had the rims painted black with the only thing being shiny was the satin chrome on the spoked part of the rim.
As for trying to find the 69 only trim rings, that is hard. I have actually started stock piling them and plan on restoring them when I get a chance to. They can be restored but area a major pain to do.
[Re: ]
#1405682
03/23/13 02:42 PM
03/23/13 02:42 PM
Posts: 3,967 S.I. N.Y.
1MYTGTX
S.I. N.Y.
Brian, got a close up pic of them installed on your rim for reference?
1MYTGTX
[Re: 1MYTGTX]
#1405683
03/23/13 05:03 PM
03/23/13 05:03 PM
Posts: 6,224 JERSEY
RJS
JERSEY
Here's the "good stuff"
[Re: RJS]
#1405684
03/23/13 05:54 PM
03/23/13 05:54 PM
[Re: ]
#1405685
03/23/13 05:54 PM
03/23/13 05:54 PM
[Re: ]
#1405686
03/23/13 05:56 PM
03/23/13 05:56 PM
before I restored them.....
