Help ID small block #1404867
03/19/13 04:15 PM
03/19/13 04:15 PM
San Antonio, TX
CurYellowBird Offline OP
San Antonio, TX
Im looking at buying a 72 swinger that was given to a kid. He doesnt know anything about the engine. I decoded the vin as being a slant 6 car. I got the intake cast # which is 4095090. Can anyone tell me what this intake is from? It is a spreadbore design and is chrysler blue, which has me thinking its a possible early 70s 340. Any help is appreciated.
Project War Bird: 1971 Plymouth Roadrunner 383 4 speed with air conditioning GY3 Curious yellow All original
Re: Help ID small block [Re: CurYellowBird] #1404868
03/19/13 04:41 PM
03/19/13 04:41 PM
Columbus, GA
Michael Ecks Offline
Columbus, GA
Manifold swaps are probably the most common modification out there, best that number will get you is an ID on the intake itself.
There should be a small pad on the block, right under the front of drivers side head (I think drivers side). Take a wire brush to that area and see if you can't make out the stamped block number there. Also may be cast into the driver-side side of the block above the freeze plugs.
Pretty sure on the locations, others will probably confirm. Its been a decade since I looked, so go easy on me guys.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Help ID small block [Re: CurYellowBird] #1404869
03/19/13 05:27 PM
03/19/13 05:27 PM
Yes look on the front face of the V8 block on the DR side just under the head gasket junction & the cubic inch displacement will be stamped there very small & on one of the block sides there will be large cast numbers/letters & 3 of those numbers will be the cubic inch displacement
Re: Help ID small block [Re: CurYellowBird] #1404870
03/19/13 07:54 PM
03/19/13 07:54 PM
Locomotion Offline
Locomotion  Offline
! believe it's a later '70's 360 intake. Sure it's not 4095080?
Check the balancer. If it has a big counterweight or a deep recess around part of the front of the outer ring, it's a 360. If it's flat, it could be a 318. 340 is a longshot.
