name of the company remaking the early volt regulators #140393
10/23/08 11:46 AM
10/23/08 11:46 AM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
what was the name of the company remaking the early style voltage regulators. They were taking the contacts out and putting modern guts in them. This is the little black box unit used from 61-69 that I am looking for.
thanks scott
I went to real time engeering website and I guess it's not them.
Re: name of the company remaking the early volt refulators [Re: maxie] #140394
10/23/08 12:12 PM
10/23/08 12:12 PM
Dallas, TX
70challrtse Offline
super gas
70challrtse  Offline
super gas
Dallas, TX
Allmost NOS.
Re: name of the company remaking the early volt refulators [Re: 70challrtse] #140395
10/23/08 06:38 PM
10/23/08 06:38 PM
new york
badsixpack Offline
badsixpack  Offline
new york
they ain't cheap!
Re: name of the company remaking the early volt refulators [Re: badsixpack] #140396
10/23/08 06:44 PM
10/23/08 06:44 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Re: name of the company remaking the early volt refulators [Re: gtx6970] #140397
10/23/08 09:57 PM
10/23/08 09:57 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: name of the company remaking the early volt refulators [Re: maxie] #140398
10/23/08 10:20 PM
10/23/08 10:20 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Scott, I think you can buy an electronic version and swap the guts into your '69 style case. One guy mentioned JC Whitney as having the electronic version that he used for his conversion.
Re: name of the company remaking the early volt refulators [Re: AZ_A12_BEE] #140399
10/23/08 10:24 PM
10/23/08 10:24 PM
USA
Rollin Hand Offline
Rollin Hand  Offline
USA
A few issues ago in mopar action e berg took a wells brand voltage regulator that has modern electronics in it and removed the cover and put on the cover from the old style regulator said it fit right on. May not look 100% but sounds cheaper to do.
Re: name of the company remaking the early volt regulat [Re: gtx6970] #140400
10/23/08 11:10 PM
10/23/08 11:10 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Bill,
I couldn't locate this on your website. How about posting a link.
Re: name of the company remaking the early volt refulators [Re: Snoopy] #140401
10/24/08 12:28 AM
10/24/08 12:28 AM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
I have a mopar constant out put on the shelf in the garage.
Would I be better to run it?
Msd, battery in the trunk, and run an electric pump about 50 percent of the time
Thanks Scott
Re: name of the company remaking the early volt refulators [Re: badsixpack] #140402
10/24/08 12:45 AM
10/24/08 12:45 AM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
they ain't cheap!
how much is not cheap?
I found them on the net for $25
Re: name of the company remaking the early volt refulators [Re: maxie] #140403
10/24/08 05:06 AM
10/24/08 05:06 AM
IN
polaraholic Offline
polaraholic  Offline
IN
they ain't cheap!
Do you have a link for those?
Re: name of the company remaking the early volt refulators [Re: polaraholic] #140404
10/24/08 06:49 AM
10/24/08 06:49 AM
Upstate NY
Big_John Offline
Big_John  Offline
Upstate NY
I used a Duralast VR706 regulator from Autozone. I cut the ears off an old regulator cover then just epoxied it directly over the cover of the new one. It fits perfectly without removing the cover on the new regulator.
Re: name of the company remaking the early volt refulators [Re: Big_John] #140405
10/24/08 10:49 AM
10/24/08 10:49 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I did the same as Big John. got mine at autozone or murrys for around $20 put the old cover on the new base, and painted the base and cover, got new bolts from Bill at http://www.amhightechauto.com/ . Then went to a local sign shop and had the script on the cover made into stickers, they gave me 4 sets for $40. looks ok works great.
Re: name of the company remaking the early volt refulators [Re: ademon] #140406
10/24/08 10:54 AM
10/24/08 10:54 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
another
Re: name of the company remaking the early volt refulators [Re: maxie] #140407
10/24/08 10:58 AM
10/24/08 10:58 AM
GMP440 Offline
GMP440  Offline
maybe someone can scan the front of their original
voltage regulator and post it on the board so we can duplicate the letterings.
Re: name of the company remaking the early volt regulat [Re: GMP440] #140408
10/24/08 03:00 PM
10/24/08 03:00 PM
Snoopy Offline
Snoopy  Offline
Bill at A+M Hightech Automotive has them for $25. They are "Not" listed on his website.
Re: name of the company remaking the early volt refulators [Re: Snoopy] #140409
10/24/08 03:18 PM
10/24/08 03:18 PM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Semi thread jack, my bee was switched to the dual field alt and new style regulator, is it possible to keep the dual field and use this type of regulator?
I can't afford this. mark
Re: name of the company remaking the early volt regulat [Re: a12superbee] #140410
10/24/08 03:30 PM
10/24/08 03:30 PM
Snoopy Offline
Snoopy  Offline
Ground one of the field connectors. The arrow shows you which one to ground.
Re: name of the company remaking the early volt refulators [Re: Snoopy] #140411
10/24/08 03:45 PM
10/24/08 03:45 PM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Thanks.
Re: name of the company remaking the early volt refulators [Re: a12superbee] #140412
10/24/08 07:34 PM
10/24/08 07:34 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
FBO has them. i have an FBO on my 65 coronet; works good.
