Re: cam timing?
[Re: quickd100]
#1403271
03/16/13 04:49 PM
03/16/13 04:49 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
The cam's so small I think whatever you might see won't be much regardless of what you do...lol.
Re: cam timing?
[Re: Cab_Burge]
#1403277
03/17/13 03:37 PM
03/17/13 03:37 PM
Posts: 16,928 NC
440Jim
NC
Buy a three way adjustable timing set and check the LSA, most small blocks respond to cam timing changes Just like all the other Mopar V8 do I'll bet it will like the cam advanced (intake lobes)4 to 6 degrees more than it will like straight up or 2 degrees retarded
I agree. Try to install it with the intake lobe center 104-106 ATC (assuming the 110 LSA is correct).
