11 inch drum ? #1402549
03/14/13 10:23 PM
03/14/13 10:23 PM
templeton,ma
coro500net Offline OP
templeton,ma
Going with 11 inch rear drums on a 8.75 and was wondering if any other rear axles with 11 inch drums will fit the 8.75 (9.25,8.25,Dana 60,ect).
Re: 11 inch drum ? [Re: coro500net] #1402550
03/14/13 11:10 PM
03/14/13 11:10 PM
Ohio, USA
Dr-Dave2 Offline
Dr-Dave2  Offline
Ohio, USA
I used 11" Brakes from a 8-3/4 C-body wagon on a dana 60& fit fine. My 9-1/4 B-Body looked the same but didnt actually try to switch them
Re: 11 inch drum ? [Re: coro500net] #1402551
03/15/13 09:12 AM
03/15/13 09:12 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
As long as you keep the correct drums with the correct backing plates they will interchange. Had a guy tell me all 11" C body stuff was junk. He was trying to use 11x2 B Body backing plates with 11x2.5 drums. Another 20 yr old know it all....
...FAFO...
Re: 11 inch drum ? [Re: skicker] #1402552
03/15/13 11:35 AM
03/15/13 11:35 AM
Lubbock, TX
E
Erics5th Offline
UsedtobeSatellite6
Erics5th  Offline
UsedtobeSatellite6
E
Lubbock, TX
11" drum/backing plates from an 8 1/4" rear will also work on an 8 3/4.
Eric
Re: 11 inch drum ? [Re: Dr-Dave2] #1402553
03/15/13 11:47 AM
03/15/13 11:47 AM
St. John's Newfoundland
440newport Offline
440newport  Offline
Very nice Coronet!
Re: 11 inch drum ? [Re: skicker] #1402554
03/15/13 01:08 PM
03/15/13 01:08 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
As long as your not putting them on an A body 8-3/4.
8-1/4, 8-3/4, 9-1/4, DANA, all should interchange.
I've even used F body 7-1/4 rear brakes on an 8-3/4.
Re: 11 inch drum ? [Re: nomore65BelvJim] #1402555
03/15/13 01:17 PM
03/15/13 01:17 PM
templeton,ma
templeton,ma
Switching to bbp on a 8.75,I have 8.75 11in backing plates.So will only 8.75 drums work with my backing plates? Or do they all interchange?
Re: 11 inch drum ? [Re: coro500net] #1402556
03/15/13 01:32 PM
03/15/13 01:32 PM
Are you changing axles?
A body 8-3/4's have a couple unique characteristics...backing plate offset, drum flange, center register, etc.
Re: 11 inch drum ? [Re: coro500net] #1402557
03/15/13 01:33 PM
03/15/13 01:33 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
A Body 8 3/4 housing? A body backing plates won't work, you will need a set of B,C, or E body. You need to know which 11" backing plates you have to get the correct drums.
...FAFO...
Re: 11 inch drum ? [Re: skicker] #1402558
03/15/13 01:50 PM
03/15/13 01:50 PM
templeton,ma
templeton,ma
The housing is from an Abody and I got the 11in x 2 1/2 bp from a Cbody,I will be getting bbp axle shafts also.
Re: 11 inch drum ? [Re: coro500net] #1402559
03/15/13 09:58 PM
03/15/13 09:58 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
If they were together on a C body and you change the bolt pattern on the A body to bbp you shouldn't have any issues.
...FAFO...
Re: 11 inch drum ? [Re: coro500net] #1402560
03/15/13 10:30 PM
03/15/13 10:30 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
11x3 all around.
Re: 11 inch drum ? [Re: nomore65BelvJim] #1402561
03/16/13 12:28 AM
03/16/13 12:28 AM
Silsbee,Tx
-Cuda Offline
-Cuda  Offline
Silsbee,Tx
So a 7-1/4 setup from an ebody would work on a 8-3/4? If so I need to pull the brake setup before the junk man hauls it off.
Re: 11 inch drum ? [Re: -Cuda] #1402562
03/16/13 02:17 AM
03/16/13 02:17 AM
They should fit.
I never scrap brakes unless they are worn out.
At least a dozen sbp and lbp sets on the shelves.
Re: 11 inch drum ? [Re: nomore65BelvJim] #1402563
03/16/13 10:02 PM
03/16/13 10:02 PM
templeton,ma
templeton,ma
I think I may have confused everyone,what I have is a 8.75 and am wondering if 11inch drums from any other mopar axle will work on it. Or do they only work with there own backing plates,shoes,hardware,ect?
Re: 11 inch drum ? [Re: coro500net] #1402564
03/16/13 11:08 PM
03/16/13 11:08 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Brake drums are not specific to the axle. If you have 11 x 2 1/2" backing plates, you can run any '65 and newer Mopar 11 x 2 1/2" drum with the same bolt pattern.
Re: 11 inch drum ? [Re: DoctorDiff] #1402565
03/17/13 10:42 AM
03/17/13 10:42 AM
templeton,ma
templeton,ma
Got it
