Page 3 of 5 1 2 3 4 5
Re: SB aftermarket main caps, waste of money? [Re: J_BODY] #1401884
03/14/13 09:58 PM
03/14/13 09:58 PM
Guitar Jones Offline OP
I've been talking with Jerry about it so I guess we'll see what happens.
On another note is Pro-Gram Engineering still in business? The website is useless and emails are returned as undeliverable.
Re: SB aftermarket main caps, waste of money? [Re: Guitar Jones] #1401885
03/14/13 10:02 PM
03/14/13 10:02 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Yes - It's best to call them
Re: SB aftermarket main caps, waste of money? [Re: DJVCuda] #1401886
03/14/13 10:39 PM
03/14/13 10:39 PM
Ok, thanks.
I've been talking with Jerry at SD Concepts about making a modified BCR cap that is flat all the way across the cap to use with a Hughes girdle to provide a full contact across the width of the cap without shims. Similiar to the caps MRL was making. Anyone else interested in a set?
Re: SB aftermarket main caps, waste of money? [Re: Guitar Jones] #1401887
03/15/13 10:15 AM
03/15/13 10:15 AM
OK, Jerry just gave me pricing for the caps, $450 a set. If he can run at least 5 sets the price drops to $350 per set. 360 or 340 main size. Anyone else want a set?
Re: SB aftermarket main caps, waste of money? [Re: Guitar Jones] #1401888
03/15/13 10:38 AM
03/15/13 10:38 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
i'd be interested at 350 a set. i'm expecting 650-700hp after my next rebuild on my 71 360. my block is much like yours with block fill. would the 350 be just for the caps or are you getting the girdle also?
Re: SB aftermarket main caps, waste of money? [Re: mopar dave] #1401889
03/15/13 10:42 AM
03/15/13 10:42 AM
Just the caps, mains 1 through 4. The girdle is $279 from Hughes.
Re: SB aftermarket main caps, waste of money? [Re: Guitar Jones] #1401890
03/15/13 10:52 AM
03/15/13 10:52 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
ok. do the girdles really hold everything in place? some believe with a girdle,if one main moves the rest will move with it because their all tied together. I have a machinest in Detroit that think their the best,if ya know what I meen. they don't believe in girdles,say girdles are for little old ladies. i'm using studs right now and thinking i'll just add the aluminum caps without girdle,unless someone can convince me girdles work on small blocks.
Re: SB aftermarket main caps, waste of money? [Re: mopar dave] #1401891
03/15/13 11:01 AM
03/15/13 11:01 AM
Dave, MRL has had an engine making 700 HP running since 2009 with a similiar cap and girdle setup. He says it's still going strong. The 4140 material is steel not aluminum. I would believe that with the girdle, since they are all tied together the others would help stop movement of the main and not cause the others to move with it.
Re: SB aftermarket main caps, waste of money? [Re: mopar dave] #1401892
03/15/13 11:03 AM
03/15/13 11:03 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
don't get me wrong here. not sayin they don't work. just sayin I have a guy that builds hundreds of performance motors telling me girdles don't work in small blocks. does anyone have proof that they do work? i'd like to be convinced they do help.
Re: SB aftermarket main caps, waste of money? [Re: mopar dave] #1401893
03/15/13 11:08 AM
03/15/13 11:08 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
My thought is that if the "girdle" was that good, we would have seen it incorporated into race blocks long ago. Invest your money elsewhere is what I've heard from a couple builders.
Re: SB aftermarket main caps, waste of money? [Re: mopar dave] #1401894
03/15/13 11:08 AM
03/15/13 11:08 AM
Unless you built an engine without a girdle and had cap walk then built it again with a girdle and it didn't how could you prove they did or didn't work? I certainly don't believe they would hurt but as proof? I don't know. You could use these caps with or without a girdle though.
Re: SB aftermarket main caps, waste of money? [Re: mopar dave] #1401895
03/15/13 11:09 AM
03/15/13 11:09 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
yeah i'v talked to mike about those before. he lives close to me. maybe its the design of the girdle that determines if it does its job or not. I know the one mike had was thick,looked very strong.
Re: SB aftermarket main caps, waste of money? [Re: mopar dave] #1401896
03/15/13 11:15 AM
03/15/13 11:15 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
its been 5 years since i'v talked with the Detroit shop about the girdle. maybe they changed their mind since then. you could give them a call and get their opinion now.
best machine (248) 987-6038. ask for chuck
Re: SB aftermarket main caps, waste of money? [Re: mopar dave] #1401897
03/15/13 11:26 AM
03/15/13 11:26 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I LOVE it when someone says they have had one in an engine since 2009. A good Friend of mine has the same 454 big block, alcohol injected Chevy in his dragster since 1995. It never leaves the garage but its the same engine.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: SB aftermarket main caps, waste of money? [Re: pittsburghracer] #1401898
03/15/13 11:43 AM
03/15/13 11:43 AM
Who knows? I'm just looking to see if anyone else would be interested in a set. I'm not reselling them, this is the price straight from SD Concepts whom you would order from. I'm going to do it anyway whether or not anyone else is interested. This engine came with a girdle on it already so it won't cost me anymore money.
Re: SB aftermarket main caps, waste of money? [Re: Guitar Jones] #1401899
03/15/13 12:09 PM
03/15/13 12:09 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
i'm interested for $350.
Re: SB aftermarket main caps, waste of money? [Re: mopar dave] #1401900
03/15/13 12:29 PM
03/15/13 12:29 PM
OK, I have a total of 3 guys so far.
Re: SB aftermarket main caps, waste of money? [Re: Guitar Jones] #1401901
03/15/13 12:47 PM
03/15/13 12:47 PM
canada
jp15 Offline
jp15  Offline
canada
Have ran a Hughes girdle on my 408 stroked 360ci for past 4 years, stock caps. I think it along with a 3/4 block fill has kept this 360 from gernading. shifted it @ 7,200 and crossed @ 8,000 ,around 700 H.P.( 8.85 @ 150 mph,N.A - 2,600 lbs)
Jim,
Re: SB aftermarket main caps, waste of money? [Re: jp15] #1401902
03/15/13 12:52 PM
03/15/13 12:52 PM
dogdays Offline
dogdays  Offline
My SHO motors, designed by Yamaha, have the main caps tied together by a girdle. Yamaha makes some pretty good engines, I'd say that is one vote in favor. The girdle is a casting.
R.
Re: SB aftermarket main caps, waste of money? [Re: dogdays] #1401903
03/15/13 01:54 PM
03/15/13 01:54 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
sounds good 700hp and 8000rpm. the [Edited by Moparts - Family Friendly Site - Keep it clean] build a good motor. just sold a 08 gsxr 750,ran flawlessly. very impressed with their motors. redlined at 14,500rpm.
best rated my 408 at 680hp@7500 with just studs and stock caps and block fill as the max on block.
aluminum main caps will be alittle insurance.
