Page 1 of 5 1 2 3 4 5
SB aftermarket main caps, waste of money? *UPDATE* #1401844
03/13/13 12:07 PM
03/13/13 12:07 PM
Guitar Jones Online laugh2 OP
Trying to figure things out on my new LA SB, are aftermarket main caps woth it or should I just stick with the stock caps. We've all heard the 4 bolt caps weaken the block but does anyone have any actual experience with this? Any help is appreciated.
Jerry at SD Concepts is willing to run these caps off at a very reasonable price, $450 a set or if he can run off at least 5 sets the price drops to $350.
Re: SB aftermarket main caps, waste of money? [Re: Guitar Jones] #1401845
03/13/13 12:46 PM
03/13/13 12:46 PM
Q
Quicktree Offline
Quicktree  Offline
Q
what power level? was Good to meet you,stop by sometime when you have more time. just my opinion but when you get into the 600hp area an X block or R3 type block would be good insurance.
Re: SB aftermarket main caps, waste of money? [Re: Guitar Jones] #1401846
03/13/13 12:58 PM
03/13/13 12:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have 1 340 stock block with big 4 bolt steel main
caps.. the outer bolts are 3/8 but I still feel it
helps spread the load... but at a point its not the
main caps that are the weak point... I've had more
blocks crack a cyl wall than hurt stock caps
Re: SB aftermarket main caps, waste of money? [Re: Quicktree] #1401847
03/13/13 01:35 PM
03/13/13 01:35 PM
It was good to meet you too Tony. I'm not sure when I'll be up that way again but I may see you at G'ville sometime this year. Yeah I know an X or R would be best but it's just not in the cards right now and yes it should make over the 600hp mark.
MrP, I've been told this block sonic checked good to 4.100 bore, it's only 4.030 now and has been tall filled. It would be nice to see one of those caps and where exactly it goes into the main web.
Re: SB aftermarket main caps, waste of money? [Re: Guitar Jones] #1401848
03/13/13 01:40 PM
03/13/13 01:40 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
hope some of these help...
Re: SB aftermarket main caps, waste of money? [Re: DJVCuda] #1401849
03/13/13 02:56 PM
03/13/13 02:56 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
With stock 340 and 360 blocks there is not much material to thread into.With the 6-pack and R blocks the thick casting has enough material to support the extra bolts.
Re: SB aftermarket main caps, waste of money? [Re: B G Racing] #1401850
03/13/13 03:59 PM
03/13/13 03:59 PM
Minnesota
Coldart Offline
Coldart  Offline
Minnesota
This ^
Your going to be flirt'n with that stock block anyway - I think you already know that
Just put an ARP stud kit in it and run it
Re: SB aftermarket main caps, waste of money? [Re: B G Racing] #1401851
03/13/13 04:13 PM
03/13/13 04:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Or use a AAR block... they had full webs at the rail...
I've got one of them left but it needs new caps
Re: SB aftermarket main caps, waste of money? [Re: Coldart] #1401852
03/13/13 04:28 PM
03/13/13 04:28 PM
This ^
Yeah, I know I'm flirtin' with a grenede, just trying to get by for awhile 'til the economy gets better.
MrP, PM sent
Re: SB aftermarket main caps, waste of money? [Re: Guitar Jones] #1401853
03/13/13 05:15 PM
03/13/13 05:15 PM
Has any one ever tried using a tubular dowel for the cap like the H beam rods use? I have access to a Bridgeport so it would just be time and the cost of the dowels, or make my own.
Re: SB aftermarket main caps, waste of money? [Re: Guitar Jones] #1401854
03/13/13 05:54 PM
03/13/13 05:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
my 4 bolt caps have 1/4" dowel pins in each(1 on
each side)
Re: SB aftermarket main caps, waste of money? [Re: MR_P_BODY] #1401855
03/13/13 05:57 PM
03/13/13 05:57 PM
each side)
I'm thinking that would be a little harder for me to locate it properly into the cap. The tubular dowel would be centered right off the bolt holes.
Re: SB aftermarket main caps, waste of money? [Re: Guitar Jones] #1401856
03/13/13 06:37 PM
03/13/13 06:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
each side)
It was easy.... locate the caps with the bearings just
like you would when you check for the clearance on
the crank... then drill straight through the cap
into the block(use a undersize bit then size it with
a ream)
Re: SB aftermarket main caps, waste of money? [Re: MR_P_BODY] #1401857
03/13/13 06:49 PM
03/13/13 06:49 PM
each side)
a ream)
That may be alright with an aftermarket steel or billet cap but I didn't want to put a hole all the way through a stock cast cap, even if it was small.
Re: SB aftermarket main caps, waste of money? [Re: Guitar Jones] #1401858
03/13/13 07:10 PM
03/13/13 07:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
No I wouldnt do that on stock caps
Re: SB aftermarket main caps, waste of money? [Re: MR_P_BODY] #1401859
03/13/13 07:17 PM
03/13/13 07:17 PM
So now we're back to the original question, are aftermarket caps worth the money and effort? Will it buy me more time, help some, or other wise am I better off just leaving it and crossing my fingers until I can get a better block?
Re: SB aftermarket main caps, waste of money? [Re: Guitar Jones] #1401860
03/13/13 07:23 PM
03/13/13 07:23 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Why put the money and effort if your going an R3?
Run it stock and hope for the best. It would be a shame to put caps on along with the machining expense if something were to go boom.
Re: SB aftermarket main caps, waste of money? [Re: Guitar Jones] #1401861
03/13/13 07:27 PM
03/13/13 07:27 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Not sure about the small block stuff but I`ve been beatin on the stock caps in my 470 w/ARP studs for 13+ years and Jason Pettis said he`s seen way worse cap walk on other motors and these studs even spent years in my 360..........
Re: SB aftermarket main caps, waste of money? [Re: MattW] #1401862
03/13/13 07:30 PM
03/13/13 07:30 PM
Because except for the line bore I can do it all myself. I have no idea how long I'll need to use this block because the economy isn't getting better and there is a change in ownership here at the dealership waiting in the wings. In the meantime it looks like a ghost town here. Just trying to get by the best I can for now.
Re: SB aftermarket main caps, waste of money? [Re: Thumperdart] #1401863
03/13/13 08:06 PM
03/13/13 08:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've never had cap walk on any of my small blocks
