Page 2 of 5 1 2 3 4 5
Re: SB aftermarket main caps, waste of money? [Re: MR_P_BODY] #1401864
03/13/13 09:03 PM
03/13/13 09:03 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
After seeing a stock 360 block at Bob Georges that had the extra two bolts added I wouldn't even do it if someone offered to do it for free. It still gives me a good laugh.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: SB aftermarket main caps, waste of money? [Re: MR_P_BODY] #1401865
03/13/13 09:07 PM
03/13/13 09:07 PM
mid-mich
turboplymouth Offline
mid-mich
Little off topic, but why aren't aluminum caps utilized on the sb like many use on the bb's?
'72 Scamp, 3500#, 440, S400, blowthrough, meth. inj. 9.78 @ 139 so far at 12 psi, 11.00 @ 131 on real street tires.
Re: SB aftermarket main caps, waste of money? [Re: turboplymouth] #1401866
03/13/13 09:24 PM
03/13/13 09:24 PM
Indy
moparman89 Offline
moparman89  Offline
Indy
Because the cylinders fall out before the caps walk/distort.
School of Automotive Machinists Racing
Re: SB aftermarket main caps, waste of money? [Re: Guitar Jones] #1401867
03/13/13 09:34 PM
03/13/13 09:34 PM
BPE Offline
BPE  Offline
Take this for what it is, but I would not put 4 bolt caps on a stock block. I just don't think it's worth the time or money spent for actual strength gain. However, I would put billet 2 bolt caps (2 through 4) on a stock block if I thought it was needed for the application. How was your last block done?
Rod
Re: SB aftermarket main caps, waste of money? [Re: Guitar Jones] #1401868
03/13/13 10:12 PM
03/13/13 10:12 PM
Az
Crizila Offline
Crizila  Offline
Az
Trying to figure things out on my new LA SB, are aftermarket main caps woth it or should I just stick with the stock caps. We've all heard the 4 bolt caps weaken the block but does anyone have any actual experience with this? Any help is appreciated.
Got about 16 runs on mine so far with no problems (probably in the 650HP range). Block is filled though.
Fastest 300
Re: SB aftermarket main caps, waste of money? [Re: Crizila] #1401869
03/14/13 12:28 AM
03/14/13 12:28 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I've got a set of two bolt caps that BCR did many moons ago. They aren't pretty, but our main bearing looked really good in our 340 stroker everytime we tore it down.
Re: SB aftermarket main caps, waste of money? [Re: J_BODY] #1401870
03/14/13 04:00 AM
03/14/13 04:00 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
These were from the original company. The holes were crooked in a couple caps and we had to ream and elongate a couple holes for proper fitment. Pain in the butt, but other than that they seemed pretty stout.
Re: SB aftermarket main caps, waste of money? [Re: J_BODY] #1401871
03/14/13 06:15 AM
03/14/13 06:15 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Mike makes a set of 2 bolt caps FYI.
Link here
Re: SB aftermarket main caps, waste of money? [Re: DJVCuda] #1401872
03/14/13 09:07 AM
03/14/13 09:07 AM
Guitar Jones Online laugh2 OP
Link here
They look nice, thanks for the info.
Re: SB aftermarket main caps, waste of money? [Re: Guitar Jones] #1401873
03/14/13 10:05 AM
03/14/13 10:05 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Link here
I think that is your answer for a stock block.Looks good with the gridle.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: SB aftermarket main caps, waste of money? [Re: pittsburghracer] #1401874
03/14/13 10:50 AM
03/14/13 10:50 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
That's the point,it's wortlhless on a stock webbed block.There is no material to hold the bolts and sometime adding the 3/8 outer bolt can crack the block webbing.I used the four bolt caps on another block with out using the bolts and that engine ran 9.50s with no issues.
Re: SB aftermarket main caps, waste of money? [Re: 1967dartgt] #1401875
03/14/13 11:02 AM
03/14/13 11:02 AM
Link here
If that would make the block safe to 700hp that should be good for quite awhile then. I'm thinking this engine should make at least 650 and maybe 675 but I'm not going to turn it over 7500 and more likely only about 7000.
Thanks to all for the info and suggestions.
Re: SB aftermarket main caps, waste of money? [Re: B G Racing] #1401876
03/14/13 11:03 AM
03/14/13 11:03 AM
PA.
"Little"John
"Little"John
PA.
Same issue trying to do it to a stock 440 block. Just not enough meat there to do any good.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: SB aftermarket main caps, waste of money? [Re: pittsburghracer] #1401877
03/14/13 11:10 AM
03/14/13 11:10 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Re: SB aftermarket main caps, waste of money? [Re: pittsburghracer] #1401878
03/14/13 12:03 PM
03/14/13 12:03 PM
Az
Crizila Offline
Crizila  Offline
Az
I went along with my machinists opinion, which was opposite the above - over 600HP on a stock block he suggested it along with a filled block, forged rotating assembly. He was not a fan of girdles for sm blks based on what was available. As I said, I only have about 16 runs on it so the verdict is still out IMO. Screamed it up to 7700 once and 7500 several times. Have since switched to different gears as I was running out of motor too soon - obviously .
Fastest 300
Re: SB aftermarket main caps, waste of money? [Re: Crizila] #1401879
03/14/13 01:59 PM
03/14/13 01:59 PM
So I messaged Mike at MRL about those main caps and this was his response.
We no longer make them. The company I was working with has since gone under and I can not find anyone who will make them for a reasonable price, as of yet. Sorry.
BTW, they have been field tested to 700hp in a stock 360 block, and its still going strong to this day. That was back in 2009.
So that idea is out the window.
Re: SB aftermarket main caps, waste of money? [Re: Guitar Jones] #1401880
03/14/13 02:14 PM
03/14/13 02:14 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
not necessarily. we can turn out a few sets reasonably. let me know what you need, what material, 2 bolt probably.
Jerry
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: SB aftermarket main caps, waste of money? [Re: Jerry] #1401881
03/14/13 03:38 PM
03/14/13 03:38 PM
Jerry
Thanks Jerry, I sent you a PM, you may even want to talk to Mike at MRL.
Re: SB aftermarket main caps, waste of money? [Re: BPE] #1401882
03/14/13 08:00 PM
03/14/13 08:00 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Rod
2 bolt program caps on apr studs... well over 600 passes to 7500 and mains look new...all the oil mods and bushed lifters
Re: SB aftermarket main caps, waste of money? [Re: Guitar Jones] #1401883
03/14/13 09:11 PM
03/14/13 09:11 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
....and as I've pointed out in previous posts on this subject. Jerry's "BCR" product and my originals are two different pieces all together. Personally I think the two bolt cap is what you're after.
