Radiator Cap for Truck #140106
10/22/08 03:54 PM
10/22/08 03:54 PM
Anonymous OP
Anonymous OP
My current radiator cap is not high enough pressure. It is leaking to much air. Does anyone know a good PSI/Ft lbs to use?
87' 318
Re: Radiator Cap for Truck #140107
10/22/08 03:58 PM
10/22/08 03:58 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
What are you using now?
Re: Radiator Cap for Truck #140108
10/22/08 03:59 PM
10/22/08 03:59 PM
Omaha,Nebraska
johncambridge Offline
super gas
super gas
Omaha,Nebraska
The factory shipped it with a 16 lb. cap.
BAXTER CHRYSLER JEEP DODGE - OMAHA,NEBRASKA 800-642-1524 - 402-493-0116 - PARTS@PERFORMANCEAUTO.COM MOPAR PERFORMANCE, RESTORATION PARTS TTi HEADERS AND EXHAUST DISTRIBUTOR LEGENDARY INTERIORS DEALER AR ENGINEERING DEALER
Re: Radiator Cap for Truck [Re: stumpy] #140109
10/22/08 04:02 PM
10/22/08 04:02 PM
Anonymous OP
Anonymous OP
It is too worn out and corroded to tell. Would anyone suggest perhaps going a little higher then 16?
Re: Radiator Cap for Truck #140110
10/22/08 04:29 PM
10/22/08 04:29 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I wouldn't go any higher. Just replace the one you have with a new one. It's worn out that's why it won't hold pressure.
Re: Radiator Cap for Truck [Re: stumpy] #140111
10/22/08 06:29 PM
10/22/08 06:29 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
They maker higher pressure caps, but they are for specialized applications.
16 is plenty for an 87 318. If a new 16lb keeps blowing off, then you have other problems
