Re: Does your 4wd truck sit even at all 4 corners?
[Re: 76dodgeboy]
#1400607
03/14/13 05:26 AM
03/14/13 05:26 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
NEVER reuse u-bolts.
I am surprised to read this. I see used u bolts on racks at wrecking yards. You'd think that they wouldn't sell them if there was a risk of liability from failure. I'll readily admit that I am relatively inexperienced with 4 wheel drive stuff. I had a 2006 Ram 1500 4wd and now the Trail Duster and then this beater. I have far more experience with cars. Still, in 31 years of being a gearhead, I have used new U bolts only twice. No failures or anything close to it. I have never had a 10 second car or a 4wd on 37" tires, so maybe I just haven't tried hard enough to break anything. The nuts that come on OEM U-bolts have a pinch/interference fit pressed into them, so I'd think that if the u-bolts aren't cut or bent and if the nuts hold tension, where am I going wrong?
[Re: Kern Dog]
#1400608
03/14/13 09:40 AM
03/14/13 09:40 AM
Posts: 15,487 Florida
scratchnfotraction
the u-bolts on my 88-440 truck came from my 68Dart,went on my 85 truck,then moved to my 88 truck. I have always reused the u-bolts if they are long enuff to fit the bill. and when too long I have cut them down. only time I use new ones are when i need longer ones for a lift or something. then just have the spring shop make up new ones. I have had them rust up and the nut seize up and twist till they broke..I did/would not use those again.
[Re: Triggerfish]
#1400612
03/29/13 02:30 AM
03/29/13 02:30 AM
Kern Dog
Granite Bay CA
Before spending any money, I thought I'd try a few different zero dollar tweaks. The first idea was to swap the spring packs from side to side. I figured that the job should take a few hours total. The previous owner had installed longer shackles at the rear eye many years ago and mounted the springs in the center bolt hole. On a whim, I decided to move the LH (Low side) leaf to the lowest hole. The holes are spaced 1 1/2" apart. I figured if it made no difference, I'd go ahead with the side to side swap. The truck now sits only 1/4" lower on the left. The fix lifted the left corner almost an inch. Thats close enough for me and it didn't cost anything.
