Re: Anyone run a auto?
[Re: joshking440]
#1400530
03/11/13 12:09 PM
03/11/13 12:09 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
Do these clubs frown on traction control
No.
All those new SRT8 cars live by it. But I think that active? traction control might more involved that what you plan on running. I know there's some new guys that come out with us that are sort of re-learning thier cars with the traction control turned off.
[Re: jcc]
#1400531
03/11/13 12:21 PM
03/11/13 12:21 PM
autoxcuda
So Cal
On a fast road course with not a lot of slow tight parts and with that motor, not as big a deal as with other motors. Not 100% optimal, but it's not going to blow up and explode with an automatic.
You mentioned "not a lot of slow tight turns" seems like an auto would be OK with that, or is your concern braking?
A little, but also the avoiding the many up and down shifts. It's a bigger deal with something say a 4 cly Neon that would needs to be in the revs.
What is your feelings on this MS68EFI?
[Re: autoxcuda]
#1400532
03/11/13 01:15 PM
03/11/13 01:15 PM
Posts: 780 Woodinville, WA
Viol8r
Woodinville, WA
I agree completely. So many factors go into this decision. I personally have had no issues with this set-up. We make 600 ft.lbs of torque, so my RPM range is lower and allows for minimal issues between shifts. There will always be a certain amount of driver skill needed to really take a car hard into a corner, manual or auto. I really use my Gear Vendors to my advantage on road course, even under braking. I suggest running your brake bias contols into the cockpit area, it helps on longer runs with a big car.
[Re: Viol8r]
#1400533
03/11/13 02:32 PM
03/11/13 02:32 PM
autoxcuda
So Cal
... I really use my Gear Vendors to my advantage on road course, even under braking. I suggest running your brake bias contols into the cockpit area, it helps on longer runs with a big car.
So do you gear split on upshifts and downshifts?
[Re: autoxcuda]
#1400534
03/11/13 02:56 PM
03/11/13 02:56 PM
Viol8r
Woodinville, WA
Yes, as much as possible. It does take some getting used to but if you are on a part of the course where 2nd gear is optimun you are basically just turning the unit off and on.
I run a button on my Cheetah shifter, right in my thumb position. It's like a Sunday drive!
[Re: Billy B Bad]
#1400538
03/11/13 11:10 PM
03/11/13 11:10 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
During a med-speed typical pylon lot autocross, you want to avoid shifting so you won't disrupt the driving and transition of the car. On a hi-speed road course you have more time in the straights (although some may still be curved straights) to aford the shifting. A manual trans will allow more power to be used, whereas the automatic does take some away. Regardless which type of course you're on (med-speed r hi-speed), and which type of trans you have, you want to avoid disrupting the flow and steadiness of the car if/when ever shifted... try to concentrate on being smooth. My 727 has been bullet proof and it shifts fully automatic or manual up/down... I can trail brake more easily with an automatic, but manuals take more skill to master their advantages. Winners can be either trans (auto or manual)... the nut behind the wheel makes the final decision on how well the car finishes.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#1400539
03/11/13 11:23 PM
03/11/13 11:23 PM
Posts: 22,696 Bitopia
jcc
Bitopia
So is a well set-up auto smooth enough? Seems like a quick change rear end is the real answer for different tracks. And to the OP, I'd put a deposit on the passon 5 spd and call it a day, run anything in the meantime to sort out car and driver first.
