Lube Guard Cool it #1399445
03/09/13 10:54 AM
03/09/13 10:54 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Has anybody used this coolant additive?
http://www.lubegard.com/SearchByCategory...lant+Treatment#
Re: Lube Guard Cool it [Re: Scamp408] #1399446
03/10/13 04:14 AM
03/10/13 04:14 AM
Cab_Burge Online work
Cab_Burge  Online Work
Sounds like marketing hype to me
Re: Lube Guard Cool it [Re: Cab_Burge] #1399447
03/10/13 04:21 AM
03/10/13 04:21 AM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
I was about to make a post asking whats NHRA legal and effective for stopping rust in a cast iron block..
Re: Lube Guard Cool it [Re: Jeepmon] #1399448
03/10/13 04:44 AM
03/10/13 04:44 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Our Nascar sanctioned track has a no Anti Freeze rule too. No rust in our ZZ1 cast iron motor blocks.
And Anti Freeze does not cool as well at water and coolant additive. Here in So Cal, I run Justice Brothers Super Radiator Cooler and Reverse Osmosis (RO) water in my Barracuda for the last couple years. I also put in Justice Brothers Cooling System Protectant for added anti rust and electrolysis protection.
Very complete test of coolant additives:
http://www.turbomagazine.com/features/0703_turp_cooling_system_additives/viewall.html
"Justice Brothers' Radiator Cooler gave us the lowest temperature during our testing - 177 F - and provided the lowest average temperatures overall when mixed with water alone."
You should have less than 300mV (.3 volts) in you coolant system. Test with a multimeter ground and one side dangling in the coolant.
Re: Lube Guard Cool it [Re: autoxcuda] #1399449
03/10/13 04:00 PM
03/10/13 04:00 PM
Texas
U
UOP Offline
UOP  Offline
U
Texas
I've fought cooling issues since the day I put my car back on the road. I've tried several name brand water wetters and the one I had the best luck with was DEI's Radiator Relief. There was a noticeable difference over the Redline and Royal Purple products, and all were used with 100% water.
Also, I believe using a water pump lube or water wetter is ok for NHRA. It's the glycol in antifreeze they don't want.
Re: Lube Guard Cool it [Re: autoxcuda] #1399450
03/10/13 08:53 PM
03/10/13 08:53 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Where do you get reverse osmosis water?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Lube Guard Cool it [Re: Scamp408] #1399451
03/10/13 09:26 PM
03/10/13 09:26 PM
tn
robnbird Offline
robnbird  Offline
tn
how funny I was just asking my brother about this cooling and rust preventative today and just came on here to ask what everyone uses.. funny how things happen..
Re: Lube Guard Cool it [Re: robnbird] #1399452
03/10/13 09:42 PM
03/10/13 09:42 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
whats the deal with water I heard use distilled Rev OS water and soft water.
Re: Lube Guard Cool it [Re: Scamp408] #1399453
03/10/13 11:05 PM
03/10/13 11:05 PM
tn
robnbird Offline
robnbird  Offline
tn
thanks I mabe try some distilled with the cool it lube guard or the JB coolant additive... Be blessed
Re: Lube Guard Cool it [Re: robnbird] #1399454
03/10/13 11:19 PM
03/10/13 11:19 PM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
Where can I buy that JB coolant additive?
Re: Lube Guard Cool it [Re: 1967dartgt] #1399455
03/11/13 12:33 AM
03/11/13 12:33 AM
Texas
U
UOP Offline
UOP  Offline
U
Texas
Reverse osmosis water is just purified water. On the jug it'll say "drinking water" instead of spring or distilled.
Re: Lube Guard Cool it [Re: robnbird] #1399456
03/11/13 02:48 PM
03/11/13 02:48 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
....thanks I mabe try some distilled with the cool it lube guard or the JB coolant additive... Be blessed
robnbird, moparguy7074, and others:
If anyone is looking for Justice Brothers products in thier area, please contact domcontact@justicebrothers.com or 626-359-9174 and you will receive a personal (not automated) response with the appropriate area sales distributor. Any inquires can be handled through that contact.
