Header extentions?
#1398984
03/08/13 12:00 PM
03/08/13 12:00 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
maybe this was asked before, does anyone know how much better performance this will give you? if you paint a line on it,and cut off where it stops.curious if someone has stats.
Hell Hath No Fury Like Mine
Re: Header extentions?
[Re: sixpacksteve]
#1398986
03/08/13 12:11 PM
03/08/13 12:11 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Being that I was in the exhaust lab at Chrysler for YEARS I played that game... its not a good way to do it.. just for info.... it doesnt know if the engine is fat or lean and different colors burn at different temps... but i you make them 16" to 18" from rhe end of the primaries you will be real close
[Re: Todd]
#1398990
03/09/13 12:47 PM
03/09/13 12:47 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
cab burge, what were the results,big-small? i guess its like indexing plugs, guys are not sure but still do it!
[Re: Cab_Burge]
#1398992
03/09/13 03:20 PM
03/09/13 03:20 PM
Posts: 4,253 State of Fascism
52savoy
State of Fascism
.12 to .18 ET pick up in the 1/4
That's pretty close to what I found in running them on a Hemi.
[Re: emarine01]
#1398997
03/10/13 10:43 AM
03/10/13 10:43 AM
MR_P_BODY
Does a header extention have any value if its curved... say 45*
Normally we talk centerline length but on a curve you might want to take the outside radius as the length and try that... so if you figure the outside radius you would be long, so try figuring that in
