Header extentions? #1398984
03/08/13 12:00 PM
03/08/13 12:00 PM
N.Y.
sixpacksteve Offline OP
N.Y.
maybe this was asked before, does anyone know how much better performance this will give you? if you paint a line on it,and cut off where it stops.curious if someone has stats.
Hell Hath No Fury Like Mine
Re: Header extentions? [Re: sixpacksteve] #1398985
03/08/13 12:07 PM
03/08/13 12:07 PM
Jamie McGrath Offline
I remember years ago that 18in seemed too work best and the gain was something in the order of 15-20ftlbs, HP was unchanged. FWIW
Re: Header extentions? [Re: sixpacksteve] #1398986
03/08/13 12:11 PM
03/08/13 12:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Being that I was in the exhaust lab at Chrysler for
YEARS I played that game... its not a good way to do
it.. just for info.... it doesnt know if the engine
is fat or lean and different colors burn at different
temps... but i you make them 16" to 18" from rhe end
of the primaries you will be real close
Re: Header extentions? [Re: sixpacksteve] #1398987
03/08/13 03:13 PM
03/08/13 03:13 PM
This is one of the tests that need to be doen at the track on a back to back basis, hard to do in todays world unless your at a test and tune day where you can do run real close to each other We use to use a 18 inch, 12 inch and 6 ich colleteor extensions on both of the Hemi Stockers, 727 and 4 speeds, and the 18 inch was always faster After discusing our results with a SS/A 4 speed racer he had some big, 4 inch diameter, 18 inch long H pipe and extenions made up for his car, it went faster also
Re: Header extentions? [Re: Cab_Burge] #1398988
03/08/13 03:18 PM
03/08/13 03:18 PM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
Now there are these............ http://www.perfweldheaders.com/compmerg.html
Re: Header extentions? [Re: 10.90 Racer] #1398989
03/08/13 05:07 PM
03/08/13 05:07 PM
Ohio
Todd Offline
Todd  Offline
Ohio
I had a similar question a while back. Here is the link.
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
Re: Header extentions? [Re: Todd] #1398990
03/09/13 12:47 PM
03/09/13 12:47 PM
N.Y.
N.Y.
cab burge, what were the results,big-small? i guess its like indexing plugs, guys are not sure but still do it!
Re: Header extentions? [Re: sixpacksteve] #1398991
03/09/13 02:11 PM
03/09/13 02:11 PM
.12 to .18 ET pick up in the 1/4
Re: Header extentions? [Re: Cab_Burge] #1398992
03/09/13 03:20 PM
03/09/13 03:20 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
That's pretty close to what I found in running them on a Hemi.
Re: Header extentions? [Re: 52savoy] #1398993
03/09/13 03:29 PM
03/09/13 03:29 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Does a header extention have any value if its curved... say 45*
Re: Header extentions? [Re: emarine01] #1398994
03/09/13 03:33 PM
03/09/13 03:33 PM
Try it and see
Re: Header extentions? [Re: Cab_Burge] #1398995
03/09/13 03:37 PM
03/09/13 03:37 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Cheep answer Cab... I'm talkin theory here
Re: Header extentions? [Re: emarine01] #1398996
03/10/13 01:49 AM
03/10/13 01:49 AM
I have new car that has a set if short 90 degree turn outs, the fomer onwer put them on to get away from blowing dust and dirt up under the car from the straight out headers, he siad his motor slowed down by adding them years ago I put a set of 14x 3.5 inch Bullit racing mufflers on my old 440 Dart that had a set of Hooker 1 7/8 inch fenderwell headers on it, no extensions, those muffs slowed that combination down I had convinced myself that they would act just like collector extensions, they didn't Test, test and tset some more for real world results
Re: Header extentions? [Re: emarine01] #1398997
03/10/13 10:43 AM
03/10/13 10:43 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Normally we talk centerline length but on a curve you
might want to take the outside radius as the length
and try that... so if you figure the outside radius
you would be long, so try figuring that in
