Keith Black oil pressure take off point #1398298
03/06/13 09:49 PM
03/06/13 09:49 PM
London, England
mopar_mark Offline OP
London, England
For those running a Keith Black block, where are you taking or feeding oil pressure gauge from ?
Re: Keith Black oil pressure take off point [Re: mopar_mark] #1398299
03/06/13 10:23 PM
03/06/13 10:23 PM
If I'm remembering correctly, it was around ten yrs ag0, I used the last(#5) main oil feed galley plug to take the reading from
Re: Keith Black oil pressure take off point [Re: mopar_mark] #1398300
03/07/13 10:21 AM
03/07/13 10:21 AM
an8sec70cuda Offline
Driver's side oil galley right behind the motor mount. Only place I could get to it w/ my headers and stock front suspension. My block doesn't have lifter oil galleys...not sure if there'd be somewhere else to take pressure from if your block is drilled.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Keith Black oil pressure take off point [Re: mopar_mark] #1398301
03/07/13 10:40 AM
03/07/13 10:40 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Why not take it from your remote oil filter mount
Re: Keith Black oil pressure take off point [Re: MR_P_BODY] #1398302
03/07/13 02:09 PM
03/07/13 02:09 PM
CALIFORNIA, USA
KB RACING ENG Offline
CALIFORNIA, USA
All correct answers above for all but the latest KB STREET HEMI/440 blocks. We have now added two oil pressure/feed locations to the top of the bellhousing area, just like the stock iron HEMI/440 blocks. These are fed from behind the #5 cam bearing via a groove cut in the block. We delayed doing this because it meant changing the pattern at the foundry and a slight program change for the CNC process. Those of you that have received blocks from us know that it takes awhile to receive your order...OK a lot more than "awhile", and we didn't want to make this even longer but we had a lot of requests for this feature so we made the change. Production is picking up and delivery times are getting shorter but we have a ways to go yet before we get to where we want to be....blocks on the shelf ready to ship. Thanks for your support
Ken Black
Re: Keith Black oil pressure take off point [Re: an8sec70cuda] #1398303
03/08/13 04:15 PM
03/08/13 04:15 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Hi Mark. As above but we had two accessible since its a wedge motor. One for the gauge and one for spraybar feed.
Re: Keith Black oil pressure take off point [Re: Tig] #1398304
03/08/13 07:06 PM
03/08/13 07:06 PM
Smithfield, Rhode Island
Mulehead Offline
Mulehead  Offline
Take off point
Ain't nuthin like a HEMI !
Re: Keith Black oil pressure take off point [Re: Mulehead] #1398305
03/08/13 08:35 PM
03/08/13 08:35 PM
London, England
London, England
Thanks everyone
