Change valve seals w/out pulling heads? #1397809
03/05/13 06:27 PM
03/05/13 06:27 PM
SW FL
dodgedartgt Offline OP
SW FL
How is it done, what tool or tools are needed? Engine is a mid '60's B-block, 361.
Thnx, Mike in FL
Re: Change valve seals w/out pulling heads? [Re: dodgedartgt] #1397810
03/05/13 06:41 PM
03/05/13 06:41 PM
USA
rftroy Offline
rftroy  Offline
USA
You need this.
KD part number 901. $6.80 on Amazon.
You also need an air compressor, and an air fitting for the KD tool.
Screw tool into spark plug tube and turn up air pressure. This holds valves in place when you remove the valve springs.
You will also need a valve spring compressor.
KD has a couple. Model # 2078 is on Amazon for $27.92.
Bob
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: Change valve seals w/out pulling heads? [Re: rftroy] #1397811
03/05/13 06:44 PM
03/05/13 06:44 PM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
The air compressor trick is needlessly complex and risky - if any part of the chain fails, you've dropped a valve. The rope trick works just as well and is more reliable - feed some rope into the spark plug hole, turn the crank until it stops, etc. I did both sides of my engine this way with no trouble.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Change valve seals w/out pulling heads? [Re: Secret Chimp] #1397812
03/05/13 06:48 PM
03/05/13 06:48 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Valid point! I did some valve work on a motor once...I'd hate to think what would have happened if the hose on the air compressor blew apart when I had the springs off!
**Photobucket sucks**
Re: Change valve seals w/out pulling heads? [Re: 70Cuda383] #1397813
03/05/13 06:52 PM
03/05/13 06:52 PM
California
mickm Offline
mickm  Offline
California
if the engine is at TDC, how far can the valve drop in?
rope version is simpler, and if you don't have an air compressor, than it's a moot point, but dropping a valve inside the engine isn't an issue.
Re: Change valve seals w/out pulling heads? [Re: 70Cuda383] #1397814
03/05/13 06:54 PM
03/05/13 06:54 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
Done it with the air compressor 100's of times. Never even heard of that process failing. If your equipment is in that bad a shape, maybe you shouldn't be working on cars.
Re: Change valve seals w/out pulling heads? [Re: mickm] #1397815
03/05/13 06:55 PM
03/05/13 06:55 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
When you use air, the piston is forced to BDC.
Re: Change valve seals w/out pulling heads? [Re: drew72] #1397816
03/05/13 07:10 PM
03/05/13 07:10 PM
California
mickm Offline
mickm  Offline
California
if you set it at exactly TDC, like doing a leakdown test, then you are fine. of course, you do have to be precise, just like doing a leakdown.
Re: Change valve seals w/out pulling heads? [Re: mickm] #1397817
03/06/13 07:48 AM
03/06/13 07:48 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ive also done a bunch with air.I use a compression tester type hose for the air hook up.I have the KD tool and it works but if you have heavy springs its tough.Also at a PB booster can be hard to get to.My kid bought the tool that bolts to the head and levers the spring down.had the heads done on his 413 in about an hour with it.Mancini has them for about 60 bucks.I think someone had on for sale in the parts section also.Rocky
Chrysler Firepower
Re: Change valve seals w/out pulling heads? [Re: therocks] #1397818
03/06/13 08:49 AM
03/06/13 08:49 AM
tboomer Offline
tboomer  Offline
Did mine with rope and the Mancini tool!
Re: Change valve seals w/out pulling heads? [Re: therocks] #1397819
03/06/13 08:52 AM
03/06/13 08:52 AM
London, England
Gavin Offline
Gavin  Offline
London, England
Sleazy and very effective lo-buck route is to use the rope trick, and get an old rocker arm and weld a pipe to it. Grind out the contact area to leave two arms and you have a shaft mounted removal tool for cents.....
Re: Change valve seals w/out pulling heads? [Re: drew72] #1397820
03/06/13 10:12 AM
03/06/13 10:12 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
It's not about the quality of my equipment. it's about me having the luck that I do, and Murphy always seeming to be on "the other guy's side"
I'm the guy who does something a hundred times and never has a problem. never even imagined a problem could happen...then some wise guy comes along and says "you shouldn't do that, you might ____________" I respond with "meh, I've done it a hundred times and never had a problem" and at that exact moment, what I was just warned about happening, happens.
Re: Change valve seals w/out pulling heads? [Re: 70Cuda383] #1397821
03/06/13 10:25 AM
03/06/13 10:25 AM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
Sorry, I wasn't implying anything about your equipment specifically. Just a general thought.
Re: Change valve seals w/out pulling heads? [Re: 70Cuda383] #1397822
03/06/13 10:38 AM
03/06/13 10:38 AM
scratchnfotraction Offline
I have had the valve slip down enuff in the guide i could not get a hold of it to pull it back up.
and you got to remember to whack the retainer/spring to unlock it before your air trick. with the spring compressed,retainer stuck to valve tip,head on engine, air compressor holding valve up... thats before I droped the valve in the cyl.
after the retainer/spring was off. air holding the valve up, I lost it putting the plastic sleeve on the valve tip
someone spoke and it sliped right down below the guide.
I am a shadtree parts changer so I will use the shadtree rope in the cyl trick every time.
Re: Change valve seals w/out pulling heads? [Re: scratchnfotraction] #1397823
03/06/13 11:03 AM
03/06/13 11:03 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Did alot here also, never with rope. If you try to compress first without giving top of retainer a whack first, you may get that air rushing sound as the retainer is pushing valve down with it as it's stuck to the locks. Never dropped a valve in cyl.
Re: Change valve seals w/out pulling heads? [Re: buildanother] #1397824
03/06/13 01:42 PM
03/06/13 01:42 PM
SW FL
SW FL
Thnx for the replies everyone. I'm off to the parts store for the KD style compressor at the top of the list, under $20 in stock. This is a stock 361 with single springs, so I'm sure it will do the trick.
Mike in FL
Re: Change valve seals w/out pulling heads? [Re: dodgedartgt] #1397825
03/06/13 03:35 PM
03/06/13 03:35 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Get a small telescoping magnet also.Helps to get the locks off and on.They can be slippery.Rocky
Chrysler Firepower
Re: Change valve seals w/out pulling heads? [Re: therocks] #1397826
03/15/13 10:35 PM
03/15/13 10:35 PM
North Austin
KnuckleDuster Offline
North Austin
What kind of rope works best for this trick? Need to install inner springs after cam break in.
Re: Change valve seals w/out pulling heads? [Re: therocks] #1397827
03/16/13 12:56 AM
03/16/13 12:56 AM
Eugene, Oregon
Eugene, Oregon
Absolutely this too. Also handy for getting them started back on easier too.
Re: Change valve seals w/out pulling heads? [Re: dodgedartgt] #1397828
03/16/13 11:18 AM
03/16/13 11:18 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Ummm... Am I the only one left that's old school?
If you need seals, you might as well pull the heads and do a valve job.
