rollbar main hoop, can it be angled? #1397723
03/05/13 03:57 PM
03/05/13 03:57 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
Installing a rollbar into a 72 scamp and with the seat back enough to get leg room it hits the main hoop bar . I am keeping the back seat so i cant really move the bottom of the bar back at the floor because it would be in the seat but if i angle it back 10° it clears the seat and helmit.
I didnt see anything in the nhra rules about this main hoop being angled or not.
Any experience with this?
Thanks, kenny
Re: rollbar main hoop, can it be angled? [Re: dirt] #1397724
03/05/13 04:10 PM
03/05/13 04:10 PM
Az
Crizila Offline
Crizila  Offline
Az
s long as the top of the bar is not more than 6" to the rear of the drivers helmet you should be ok.
Fastest 300
Re: rollbar main hoop, can it be angled? [Re: Crizila] #1397725
03/05/13 05:33 PM
03/05/13 05:33 PM
It must be above the helmet with you in the seat also Roll bars and rear seats do not mix well
Re: rollbar main hoop, can it be angled? [Re: dirt] #1397726
03/05/13 07:53 PM
03/05/13 07:53 PM
Coon Rapids, Minn.
MW Racecraft Offline
Coon Rapids, Minn.
Has to be less than 20 degrees
set back. Just when thru this
redoing a roll cage in a Monza.
Tube chassis car built for a 5'2
driver. Car was sold to 5'10
driver.
Re: rollbar main hoop, can it be angled? [Re: dirt] #1397727
03/06/13 01:22 PM
03/06/13 01:22 PM
Nor-Cal
loaderpro Offline
loaderpro  Offline
Nor-Cal
I have built quite a few chassis cars and I always put 15 degrees in them, then I also add a dropped style seatback brace, This allows for maximum driver setback and as the other members noted it helps to keep the helmet within the 6 inch tolerance. Hope this helps.
Re: rollbar main hoop, can it be angled? [Re: loaderpro] #1397728
03/06/13 04:24 PM
03/06/13 04:24 PM
Indiana
Scott58 Offline
Scott58  Offline
Indiana
Maybe a dumb question, but what's a "dropped style" seatback brace? Got a picture?
Re: rollbar main hoop, can it be angled? [Re: Scott58] #1397729
03/06/13 08:00 PM
03/06/13 08:00 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Yup, no problem with an angled bar. Mine also has a bent cross bar for maximum seat travel while still keeping the bar close to your head.
Re: rollbar main hoop, can it be angled? [Re: dizuster] #1397730
03/06/13 10:27 PM
03/06/13 10:27 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
mine is angled back slightly, i use all my stock seats. A body
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: rollbar main hoop, can it be angled? [Re: 68 HEMI GTS] #1397731
03/07/13 12:46 AM
03/07/13 12:46 AM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
thanks for the pictures. i set it at 10 degrees and it fits good. and matches the angle of the side glass chrome strip with the seal on it.
Re: rollbar main hoop, can it be angled? [Re: Scott58] #1397732
03/07/13 03:47 PM
03/07/13 03:47 PM
Nor-Cal
loaderpro Offline
loaderpro  Offline
Nor-Cal
No such thing as a dumb question Scott! I always figured if your adding a cage or doing a chassis car you try to build it with a larger pct on the rear tires. And the driver is no exception!
