440 intake height SD vs M1 sp #1396577
03/03/13 12:50 PM
03/03/13 12:50 PM
Colorado
Dirt Slinger Offline OP
Colorado
Does anybody know the height difference between a Holley street dominator and a Mopar M1 single plane? for a 440, Thanks.
Re: 440 intake height SD vs M1 sp [Re: Dirt Slinger] #1396578
03/03/13 03:32 PM
03/03/13 03:32 PM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
Well I have a m1 single plane on a 69 charger and can not use any spacer under the carb it's to close the hood.
I had to order a 1.5" drop base and use a 1.5" filter to with KN extreme top to make it just barely fit under a stock hood and have a air cleaner on it.
Also tried a 1/2" spacer under carb hood would hit vent tubes, this is with 850 Mighty Demon Carb.
The SD is more like a Torquer height so you should be able to use a 1/2" to 1" spacer most i have seen do.
1969 Dodge Charger 1969 Dodge Superbee
Re: 440 intake height SD vs M1 sp [Re: cjs69mope] #1396579
03/03/13 08:37 PM
03/03/13 08:37 PM
Colorado
Colorado
Bump,
have the m1 with a adapter and a 1050 on last 10 years, I need about an 1 1/2" for a air cleaner, so I can put in back on the street, Dont want a dominator flange intake unless its a ch440 and I havent seen one in years. Thought I would buy a street dominator if it would help.
Re: 440 intake height SD vs M1 sp [Re: Dirt Slinger] #1396580
03/03/13 11:28 PM
03/03/13 11:28 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
All I can tell you is the Street Dominator is a good intake and is not as tall as the M1. Ron
Re: 440 intake height SD vs M1 sp [Re: 383man] #1396581
03/03/13 11:52 PM
03/03/13 11:52 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
According to a 1998 Year One catalog, the SD is 7/8" taller than stock and the M1 is 1-7/8" taller than stock 4-barrel manifold. This is for the 440.
Ron
Re: 440 intake height SD vs M1 sp [Re: Ronnman] #1396582
03/04/13 05:08 AM
03/04/13 05:08 AM
Australia
big_wedge Offline
big_wedge  Offline
Australia
the M1 is a tad taller than a SD with a 1" spacer if that helps
Re: 440 intake height SD vs M1 sp [Re: big_wedge] #1396583
03/04/13 07:52 PM
03/04/13 07:52 PM
Colorado
Colorado
Thanks for the replies thats the info I needed.
