Ammeter Gauge - Needle Position .... #1395289
02/28/13 10:58 PM
02/28/13 10:58 PM
Florida, US
72ls5fla Offline OP
72ls5fla  Offline OP
Florida, US
hey --
Some background ...
440+6 Challenger, stock restored 38 amp alternator. New NOS regulator
All new wiring throughout car. No ground issues - I ran one from the bellhousing to the firewall.
I ran a 10 gauge wire from the back of alternator to starter relay - to help take some current away from the bulkhead and ammeter gauge
When running car during the day - rpm above 1000 the neddle is dead center.
When running after cranking - needle swings to far right and gradually to center.
If rpm drops below 1000, then needle swings to left - soon as rpm goes up, it moves to right then to center.
Question:
Is it normal for the gauge needle to sit just a hair to the left of center at nightime (lights on etc)?
I checked the voltage at the alternator durring the day - 14.20 it was 14.1 at the battery. Turned on the lights and it dropped to
13.7 -> 13.8.
At night even with the slight needle offset to left - head lights and dash light don't dim.
Expertise appreciated ....
Thanks in advance..
Bill
Got me a NEW Project
1970 GTX 440+6, 4 spd, 4.10 Dana and N96 FE5 (top/bottom) and black bucket interior.
Original transmission and Dana - Engine is a service replacement block.
Body has all stamped #s + VIN/TRIM tag and door sticker. Been hunting like all hell to find the Build Sheet.
garage find, only had 41,850 miles on ODO.
Re: Ammeter Gauge - Needle Position .... [Re: 72ls5fla] #1395290
02/28/13 11:31 PM
02/28/13 11:31 PM
My 69 Charger does the same thing with factory stock wiring. Pretty much the same numbers too.
Re: Ammeter Gauge - Needle Position .... [Re: ] #1395291
02/28/13 11:38 PM
02/28/13 11:38 PM
Florida, US
72ls5fla Offline OP
72ls5fla  Offline OP
Florida, US
thanks for the info -
I am feeling much better now about it...
Re: Ammeter Gauge - Needle Position .... [Re: 72ls5fla] #1395292
03/01/13 04:19 AM
03/01/13 04:19 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
If your ammeter is off, it can have that, you can get it calibrated to fix that problem. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Ammeter Gauge - Needle Position .... [Re: 72ls5fla] #1395293
03/01/13 06:36 PM
03/01/13 06:36 PM
Ft.Myers,Florida
Hemiruss Offline
Hemiruss  Offline
Ft.Myers,Florida
my Superbee does the same thing with new harness,alt.and voltage reg. You should be OK.....
