Ammeter Gauge - Needle Position ....
#1395289
02/28/13 10:58 PM
02/28/13 10:58 PM
Posts: 238 Florida, US
72ls5fla
Florida, US
hey --
Some background ... 440+6 Challenger, stock restored 38 amp alternator. New NOS regulator All new wiring throughout car. No ground issues - I ran one from the bellhousing to the firewall.
I ran a 10 gauge wire from the back of alternator to starter relay - to help take some current away from the bulkhead and ammeter gauge
When running car during the day - rpm above 1000 the neddle is dead center. When running after cranking - needle swings to far right and gradually to center. If rpm drops below 1000, then needle swings to left - soon as rpm goes up, it moves to right then to center.
Question: Is it normal for the gauge needle to sit just a hair to the left of center at nightime (lights on etc)?
I checked the voltage at the alternator durring the day - 14.20 it was 14.1 at the battery. Turned on the lights and it dropped to 13.7 -> 13.8. At night even with the slight needle offset to left - head lights and dash light don't dim.
Expertise appreciated ....
Thanks in advance..
Bill
Got me a NEW Project 1970 GTX 440+6, 4 spd, 4.10 Dana and N96 FE5 (top/bottom) and black bucket interior. Original transmission and Dana - Engine is a service replacement block.
Body has all stamped #s + VIN/TRIM tag and door sticker. Been hunting like all hell to find the Build Sheet.
garage find, only had 41,850 miles on ODO.
Re: Ammeter Gauge - Needle Position ....
[Re: 72ls5fla]
#1395290
02/28/13 11:31 PM
02/28/13 11:31 PM
My 69 Charger does the same thing with factory stock wiring. Pretty much the same numbers too.
[Re: ]
#1395291
02/28/13 11:38 PM
02/28/13 11:38 PM
72ls5fla
Florida, US
thanks for the info - I am feeling much better now about it...
