84 d150 360 build question #1394709
02/28/13 11:57 AM
02/28/13 11:57 AM
north ridgeville
kyle0667 Offline OP
kyle0667  Offline OP
north ridgeville
hey everyone hows it going, im trying to build a 360 for my truck and not sure what cam would be good for power to weight ratio . I found this cam on ebay what do you guys think http://www.ebay.com/itm/140920673100
im building the truck for street and strip and I want something with a nice chop to it
thanks ,
kyle j.
Re: 84 d150 360 build question [Re: kyle0667] #1394710
02/28/13 12:08 PM
02/28/13 12:08 PM
north ridgeville
kyle0667 Offline OP
kyle0667  Offline OP
north ridgeville
some pics
Re: 84 d150 360 build question [Re: kyle0667] #1394711
02/28/13 12:10 PM
02/28/13 12:10 PM
north ridgeville
kyle0667 Offline OP
kyle0667  Offline OP
north ridgeville
Re: 84 d150 360 build question [Re: kyle0667] #1394712
02/28/13 11:38 PM
02/28/13 11:38 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
With hardly any details on your setup, it's really hard to recommend a cam at all. That said, the cam you linked to looks like a good street/strip cam in general.
It's Swifty! Swifty, you toad sucker!
Re: 84 d150 360 build question [Re: zrxkawboy] #1394713
03/01/13 12:52 AM
03/01/13 12:52 AM
north ridgeville
kyle0667 Offline OP
kyle0667  Offline OP
north ridgeville
Re: 84 d150 360 build question [Re: kyle0667] #1394714
03/01/13 02:31 PM
03/01/13 02:31 PM
dogdays Offline
dogdays  Offline
Good luck with that. Valvesprings and retainer-to-valve guide need to be checked.
R.
Re: 84 d150 360 build question [Re: dogdays] #1394715
03/01/13 11:44 PM
03/01/13 11:44 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
If your planning on driving your truck on the street a lot, you would be a lot happier with the 1st cam. The 2nd one is pushing normal street use. Gene
Re: 84 d150 360 build question [Re: poorboy] #1394716
03/02/13 12:23 AM
03/02/13 12:23 AM
north ridgeville
kyle0667 Offline OP
kyle0667  Offline OP
north ridgeville
yeah ill prolly end up getting a DD anyway
Re: 84 d150 360 build question [Re: kyle0667] #1394717
03/02/13 10:45 AM
03/02/13 10:45 AM
Lehigh Acres, Florida
rickstershemi Offline
Comp Cams XE268H in our old D150 Basically stock motor with weiand intake, edelbrock 650 & headers....slight choppy idle....great power....I was very pleased
Stock valve springs as well
Rickster
Re: 84 d150 360 build question [Re: rickstershemi] #1394718
03/02/13 02:06 PM
03/02/13 02:06 PM
north ridgeville
kyle0667 Offline OP
kyle0667  Offline OP
north ridgeville
what was it running on the track ?
Re: 84 d150 360 build question [Re: kyle0667] #1394719
03/02/13 07:29 PM
03/02/13 07:29 PM
Never had a chance to run it at the track once we had it finished....??? But Mike (Scratch) can vouch for how it ran
Rickster
Re: 84 d150 360 build question [Re: rickstershemi] #1394720
03/02/13 09:05 PM
03/02/13 09:05 PM
scratchnfotraction Offline
Rickster
that would be true,and yes I can vouch for the performance.
unless you build the rest of the 360 to go with the thumper cam, adding comp ratio/stall/gears it will not perform like the sales add said.
I would have went with a hughes whiplash in a stock 360 engine myself.
idels like a funny car,smooths out around 1800-2000 rpm for red light to red light action and is a nice cruzing cam for the street.
3 of my buddys run this cam,2-318s 1-360, my 349 stroker is up next with a whiplash 318 roller cam.
Re: 84 d150 360 build question [Re: rickstershemi] #1394721
03/02/13 09:39 PM
03/02/13 09:39 PM
Stockbridge, GA
7D9LRE Offline
7D9LRE  Offline
Stockbridge, GA
I've got the XE268H in my truck, very happy with the sound and performance. Runs 14.7@95mph weighing 4100 pounds.
Re: 84 d150 360 build question [Re: 7D9LRE] #1394722
03/02/13 10:08 PM
03/02/13 10:08 PM
I've got the XE268H in my truck, very happy with the sound and performance. Runs [Email]14.7@95mph[/Email] weighing 4100 pounds.
Rickster
Re: 84 d150 360 build question [Re: rickstershemi] #1394723
04/05/13 02:08 AM
04/05/13 02:08 AM
north ridgeville
kyle0667 Offline OP
kyle0667  Offline OP
north ridgeville
well this build gets more and more pricey .. got the cam , bought new timing setup , getting ready to buy all new bearings and lifters , had the crank cleaned up at a local shop k&b engine and machine .
