Whats everyone using for a EFI fuel line? #1394222
02/27/13 03:13 AM
02/27/13 03:13 AM
spokane/pullman Wa
ryanf Offline OP
ryanf  Offline OP
spokane/pullman Wa
I plan on running an external fuel pump (Walbro GSL392) and am wondering what everyone is running for a fuel line. Hard line steel? Braided stainless steel with PTFE? What tools are needed? never built a fuel line before, any tips/hints would be great.
Ryan
Re: Whats everyone using for a EFI fuel line? [Re: ryanf] #1394223
02/27/13 05:36 AM
02/27/13 05:36 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
3/8 steel line, a pipe cutter and an inverted flare kit is what you need. Use a couple short pieces of efi rubber hose at the pump, engine, regulator, etc. While doing those parts with braided stainless hoses with nice factory crimped ends looks nicer, it's not necessary.
Re: Whats everyone using for a EFI fuel line? [Re: DaytonaTurbo] #1394224
02/27/13 11:46 AM
02/27/13 11:46 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I'm scratching my head wondering why FAST says you "must" use rubber line all the way ?!?!?! (for their system)
Re: Whats everyone using for a EFI fuel line? [Re: Stanton] #1394225
02/27/13 11:55 AM
02/27/13 11:55 AM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
You always want to use as much hard line as possible. When you need hose, use EFI hose. It's stronger, plus it holds up with "modern" pump blended fuels like E10 and E15 if they decide to ram that down our throats. Blended fuels are murder on rubber.
If you are unsure of some product's recommendations, give them a call.
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: Whats everyone using for a EFI fuel line? [Re: VincentVega] #1394226
02/27/13 02:41 PM
02/27/13 02:41 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
Some efi retrofit setups call for all rubber to absorb the pulsing of the fuel pump and even out the pressure. I had aluminum lines on my electric pump/carb setup, then stainless braided rubber, now stainless 3/8" tube. The aluminum was getting eaten up by the gasohol and having a full run of soft line didn't make my PA street car inspection guy real happy.
Re: Whats everyone using for a EFI fuel line? [Re: VincentVega] #1394227
02/27/13 06:29 PM
02/27/13 06:29 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
some of the 4.7 V8s were E85 rated, as were some 3.3 V6s, i wonder what was used for those fuel lines
i have wondered if an
E85 rated fuel line from a 2001 4.7 Ram
would fit in place of the original fuel line of a
1995 Ram 360 V8.
It would be nice if the fitting on both ends had remained the same.
Re: Whats everyone using for a EFI fuel line? [Re: 360view] #1394228
02/27/13 07:11 PM
02/27/13 07:11 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
EFI hose has a viton-type inner liner, which is totally rated for that
Re: Whats everyone using for a EFI fuel line? [Re: 360view] #1394229
02/28/13 03:14 AM
02/28/13 03:14 AM
Manitoba, Canada
Manitoba, Canada
Stainless steel I think.
