440 source oil pick up #1392385
02/23/13 11:51 AM
02/23/13 11:51 AM
hiding in illinois
slax69gts Offline OP
hiding in illinois
when i first started getting involved with moparts forums a few monthes ago (ive viewed moparts for about a decade) i put something on the general forum called "swingers only" about 440 sources bb swinging oil pick ups. i caution using their parts but amassed alot of static parts from them as i talked about in a recent post on them. i never got a reply about the part itself but i would like to know if anyone has ever used their swinging oil pick up with sucess. yes, ive done my research on external oil systems and i am running the this system. finding out about this part is the last of the research. i hate to save 50 bux on this part and do 2000 bux of damage later. i only what to build this engine once. ive already got most of the parts from milodon, maybe would be wise to just stick with them.
Re: 440 source oil pick up [Re: slax69gts] #1392386
02/24/13 08:49 AM
02/24/13 08:49 AM
pa
572charger Offline
572charger  Offline
pa
i use a indy pick up on my external oiling system only because its bigger opening, milodon works great also !!!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: 440 source oil pick up [Re: 572charger] #1392387
02/24/13 10:39 AM
02/24/13 10:39 AM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
the 440 source one looks like an exact copy of the indy without the pretty anodizing. ive used both.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: 440 source oil pick up [Re: slax69gts] #1392388
02/24/13 11:28 AM
02/24/13 11:28 AM
hiding in illinois
hiding in illinois
sure is alot of questions about big block oiling. i use the the big block performance book put out a few years ago as a general guide for my big block 470 and it is amazing all the little tricks you can do just to the oil system, which is something i do not want to skimp on. a few years ago i was bass fishing and second guessed a knot i tied a hooked at least a seven pounder only to lose it because of the knot. sure hate to lose a 2500 dollar recipricating assembily because of a second guessed oil pick up. i will scrap together the few extra bux instead of scraping up my big block. thanx
Re: 440 source oil pick up [Re: slax69gts] #1392389
02/24/13 12:23 PM
02/24/13 12:23 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
there pretty simple, don't really see what makes it a seconded guessed oil pick up. now if the milodon or the indy pickup had a o-ring where the pickup goes in the body (they don't) then it wouldn't be an argument which was better.
