Flywheel Bolts, How much clearance needed?
#1391846
02/21/13 10:51 PM
02/21/13 10:51 PM
Posts: 755 Oregon
moparmedic
I bolted up my flywheel with the bolts that came with it and torqued them. I noticed that the bolts protrude through the back of the crank a little, maybe 2 or 3 threads and come very close to the back of the block. The clearance is a little more than a sheet of paper. Is that normal? If not, is it safe to use grade 8 washers with the bolts to compensate?
1968 Coronet 1968 Charger 1966 A100 Pickup 1967 Barracuda 1970 Challenger 1972 Challenger 1973 Barracuda 2021 Ram 2500
Re: Flywheel Bolts, How much clearance needed?
[Re: moparmedic]
#1391847
02/21/13 11:24 PM
02/21/13 11:24 PM
Posts: 21,843 Kirkland, Washington
Pacnorthcuda
A sheet of paper??? I wouldn't run it! Just grind a thread or two off (carefully) clean up with a die and sleep well
[Re: Pacnorthcuda]
#1391848
02/21/13 11:37 PM
02/21/13 11:37 PM
Posts: 755 Oregon
moparmedic
Well now that is a good idea, why didn't I think of that? Thanks!
[Re: Cab_Burge]
#1391850
02/22/13 11:49 AM
02/22/13 11:49 AM
Posts: 755 Oregon
moparmedic
I didn't use any washers because the bolts didn't come with any. Just figured that was the way it was supposed to be.
[Re: kloyiod]
#1391853
02/24/13 01:48 PM
02/24/13 01:48 PM
Posts: 755 Oregon
moparmedic
Flywheel to crank bolts. I did as suggested and used hardened washers and locktite.
