Cuda rear rims offset 15x8 #1390390
02/19/13 02:00 PM
02/19/13 02:00 PM
Milwaukee WI
R_Blaha Offline OP
R_Blaha  Offline OP
Milwaukee WI
I'm looking at going day 2 on my 70 cuda, I want to mount a set of cragar SS with L60x15 Formula Super Stock tires, what offset would fit nicely in the wheel wells. Thanks in advance.
LOOKING FOR THE 68 GTS IN THE AVATAR SPOT
1969 Dodge Superbee post coupe 383
1969 Dodge Superbee hardtop 472 hemi
1989 Mustang GT
1993 mustang lx 5.0
2004 screaming yellow cobra
2013 CVO Roadglide
Re: Cuda rear rims offset 15x8 [Re: R_Blaha] #1390391
02/19/13 02:11 PM
02/19/13 02:11 PM
Midwestern Indiana
duster2 Offline
duster2  Offline
Midwestern Indiana
Don't worry about the offset , backspace is what you want .... 15 x 8 with a 4 1/2 backspace will put the wheel dead center. Just in case you want to know , that is 0 offset.
Frank
Re: Cuda rear rims offset 15x8 [Re: duster2] #1390392
02/19/13 04:55 PM
02/19/13 04:55 PM
Milwaukee WI
R_Blaha Offline OP
R_Blaha  Offline OP
Milwaukee WI
Thanks, so a 15x8 wheel with a 4 1/2 inch back space will fit nicely in the rear wheel wells with no problems? Thanks!
1989 Mustang GT
1993 mustang lx 5.0
2013 CVO Roadglide
Re: Cuda rear rims offset 15x8 [Re: R_Blaha] #1390393
02/19/13 05:21 PM
02/19/13 05:21 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
On the '70 Barracuda I had, 15x8 Rallyes with 4.5" BS were just a bit too much, and would rub the wheelwells on bumps using a 275/60R15 tire. I remember thinking I should have used 4.25" BS.
Re: Cuda rear rims offset 15x8 [Re: R_Blaha] #1390394
02/19/13 08:03 PM
02/19/13 08:03 PM
STL
cdstl Offline
cdstl  Offline
STL
I have 15x8, 4.5 backspace Rallyes with M/T L 60s. They will rub.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Cuda rear rims offset 15x8 [Re: cdstl] #1390395
02/20/13 01:04 AM
02/20/13 01:04 AM
Upstate, NY
sixpack4spd Offline
sixpack4spd  Offline
Upstate, NY
You need more backspacing, not less. How much room till the tire rubs on springs?
Re: Cuda rear rims offset 15x8 [Re: sixpack4spd] #1390396
02/20/13 11:19 AM
02/20/13 11:19 AM
Milwaukee WI
R_Blaha Offline OP
R_Blaha  Offline OP
Milwaukee WI
A 5 inch back spacing should move the wheels closer to the rails than a 4 1/2 back spacing correct?
1989 Mustang GT
1993 mustang lx 5.0
2013 CVO Roadglide
Re: Cuda rear rims offset 15x8 [Re: R_Blaha] #1390397
02/20/13 12:35 PM
02/20/13 12:35 PM
GEORGIA
barracuda7199 Offline
GEORGIA
4.5 backspace fit a 275 60 perfect on my car with a 8" wheel but my lips are rolled so i had zero problems with rubbing.
Re: Cuda rear rims offset 15x8 [Re: barracuda7199] #1390398
02/20/13 01:40 PM
02/20/13 01:40 PM
Midwestern Indiana
duster2 Offline
duster2  Offline
Midwestern Indiana
I tell you what , remove a rear wheel from your car , lay a straight edge across the drum where the wheel mounts, Measure from the edge to the spring , in front of the drum and behind the drum.
You need 1 inch for tire buldge and at least 1/2 inch clearance.
Also the backspace on a wheel is measured to the back edge of the actual rim , not where the tire sits on the bead.
And yes , a 5 inch backspace will move it closer to the spring. Also include the extra cost per rim to do a custom backspace that most places are charging now.
Frank
Re: Cuda rear rims offset 15x8 [Re: topside] #1390399
02/20/13 01:51 PM
02/20/13 01:51 PM
Midwestern Indiana
duster2 Offline
duster2  Offline
Midwestern Indiana
Factory 15 x 7 ralleys have 4 1/4 backspace , so you say put the full extra 1 inch of a 15 x 8 wheel to the outside , I don't think so.
Frank
Re: Cuda rear rims offset 15x8 [Re: cdstl] #1390400
02/20/13 01:54 PM
02/20/13 01:54 PM
Midwestern Indiana
duster2 Offline
duster2  Offline
Midwestern Indiana
So is this the car in the picture you posted , with those wheels that rub on the rear , that is not a 4 1/2 backspace on those wheels.
Frank
Re: Cuda rear rims offset 15x8 [Re: duster2] #1390401
02/20/13 02:18 PM
02/20/13 02:18 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Sorry, brain fart. 4.75" BS. Didn't post a photo. Car was a stock, 32,000-mile 318 car, rubbing was up in the wheelhouse on corner of the tire.
Re: Cuda rear rims offset 15x8 [Re: duster2] #1390402
02/20/13 05:01 PM
02/20/13 05:01 PM
STL
cdstl Offline
cdstl  Offline
STL
Frank
My bad and you are correct. Those are 10" wide Centerlines. I forgot that I backed it out and took pictures after I got the Rallyes on the front but not the back. I don't have a picture with the Rallyes on my computer but I still need to keep the shocks aired up or the tire will rub.
Re: Cuda rear rims offset 15x8 [Re: cdstl] #1390403
02/20/13 11:35 PM
02/20/13 11:35 PM
NC, USA
davenc Offline
davenc  Offline
NC, USA
First, remember that every vehicle is different. You really need to take measurements on both sides of the car to be sure what will fit.
4.5" backspace for a 15 X 8 is common with many wheel vendors. However, I tried a American Racing Torque Thrust II with 4.5" backspace and did not like how it looked. I changed to a custom 5" backspace wheel and was much more happy with the look. HOWEVER, I also made some changes to the spring location (bolt-in only) to increase the tire to spring clearance. The 5" BS might be OK with the stock spring location, but it would be tight. Again every vehicle will be different. If you search the archives, you should be able to find a post I made on this.
Re: Cuda rear rims offset 15x8 [Re: R_Blaha] #1390404
02/21/13 05:42 PM
02/21/13 05:42 PM
STL
cdstl Offline
cdstl  Offline
STL
15x8, 4.5 backspace with a Mickey L-60.
