see ya ss springs #1389650
02/18/13 01:13 PM
02/18/13 01:13 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
ordered some espo 2" over for the duster.should be a lot more street friendly than the ss springs.they were quite stiff.now for some bilsteins
Re: see ya ss springs [Re: mcmopars] #1389651
02/18/13 05:19 PM
02/18/13 05:19 PM
the house on the left.
cogen80 Offline
cogen80  Offline
2" over? at that point ya may as well kept the ss springs. lol
Re: see ya ss springs [Re: mcmopars] #1389652
02/18/13 09:57 PM
02/18/13 09:57 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Then handling won't be much better with the 2" over, should have gotten the regular one's. One of my cars are 1" over and I don't like them. My other car with reg springs handles better and rides better.
I started this post hours ago, before seeing the above post just now got back to it.
Re: see ya ss springs [Re: Challenger 1] #1389653
02/19/13 08:37 PM
02/19/13 08:37 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
say it aint so.i didnt just waist $300.00.they wont ride any softer than the ss springs????
Re: see ya ss springs [Re: mcmopars] #1389654
02/19/13 10:39 PM
02/19/13 10:39 PM
Cincinnati, Ohio
Cincinnati, Ohio
I do believe that they will ride better than your old SS springs because they have a longer front segment than do the SS and that should help the ride. Having the azz end up in the air destroys the handling is all.
My gold 71 is sitting on EPSO 1" over springs and my black 74 is on stock height springs.
Re: see ya ss springs [Re: Challenger 1] #1389655
02/20/13 01:11 PM
02/20/13 01:11 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Agreed. I think the stock style XHD spring are around 130-140# rate. I seem to recall SS springs are 160ish, so the ride will soften up some. But the 2" over ride height creates greater side laoding of the spring pack, so they are not as stable for cornering as a flatter spring. However, at 2," they may be flatter than SS springs, so you'll just have to wait and see. Last set of SS springs I isntalled were more like a +3 and there is some on on here who installed an SS set that resulted in a radical +6, but that isn't the norm.
Re: see ya ss springs [Re: TC@HP2] #1389656
02/20/13 06:41 PM
02/20/13 06:41 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
i need the 2" to clear the 275/60/15 tires,didnt want to go the air shock route.
Re: see ya ss springs [Re: mcmopars] #1389657
02/21/13 04:41 PM
02/21/13 04:41 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
On just about ANY rwd Mopar I believe a 275-60-15 mounted on a 7 or 8 rim having proper bs (4" for 7, 4.5" for 8) should fit a-ok w/o ANY rear fender or fender lip clearance problems... the key factor is the back-space.
Re: see ya ss springs [Re: Mopar Mitch] #1389658
02/21/13 06:58 PM
02/21/13 06:58 PM
Renton Washington
Triple Threat Offline
Renton Washington
Put on a smaller tire and stock or less springs. My car has -1's on it.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: see ya ss springs [Re: mcmopars] #1389659
02/21/13 07:50 PM
02/21/13 07:50 PM
Indiana
MonGoo$e Offline
MonGoo$e  Offline
Indiana
2"ers will settle down after a couple months. It'll be okay, had them on a Challenger and a Duster and with rear sway bars did great.
Re: see ya ss springs [Re: MonGoo$e] #1389660
02/21/13 08:02 PM
02/21/13 08:02 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
yea i got what i got,cant send em back.they wont be as high as the ss and should be less harsh.which is ok by me
Re: see ya ss springs [Re: mcmopars] #1389661
02/24/13 11:37 PM
02/24/13 11:37 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
If they are too high you could try flipping the front hanger and you'll loose about 3/4".
