moparts engine builder, help settle a bet
#1388335
02/16/13 01:09 PM
02/16/13 01:09 PM
Posts: 4,732 Watertown, WI
MikeyT
Watertown, WI
Ok folks.
I want you to be completely truthful on this build and see what some of the engine builders come up with for Hp numbers/ torque numbers.
No need to inflate or sand bag, just honest opinions.
Build 367 cubic inch engine 10:1 compression ration 340X heads 240ish .520 lift solid roller comp cam holley street dominator intake 750 proform carb 1 5/8 headers. thru 2.5 exhaust.
I know this isn't an exact science, just give me guesses thanks, Mikey
1969 Dodge Dart Swinger
Re: moparts engine builder, help settle a bet
[Re: MikeyT]
#1388336
02/16/13 01:12 PM
02/16/13 01:12 PM
Posts: 20,680 in a cattle trailer down by th...
Guitar Jones
I'm thinking about 400/450.
[Re: MikeyT]
#1388339
02/16/13 03:27 PM
02/16/13 03:27 PM
Posts: 43,321 Bend,OR USA
Cab_Burge
Are you wanting numbers for a engine dyno or a chassis dyno? If on a chasis dyno which trans and converter combination or is it a stick shift set up?
[Re: MikeyT]
#1388340
02/16/13 03:32 PM
02/16/13 03:32 PM
Posts: 952 Stockholm, Sweden
MrSixpack
Stockholm, Sweden
Is the heads stock or ported? If stock I would guess 375-400 HP. I know the Stock guy's with 340's make more power, but I don't know if the ARE Stock. As long as they don't pour the heads for cc's I don't trust them ![](/ubbthreads/images/graemlins/grin.gif) I built a 366 for a friend with a TIGHT budget(he is poor as he!!) I've used std J heads with 2.02 intake valves and no porting, a Edelbrock RPM, Lunati voodo cam, and a Thermoquad. Car is a original 62 4dr Dart with 8 3/4 3.23 and pushbutton 727 and Streetfighter converter. Best et 13.02@104mphDon't know the HP but we are happy as it's a NO money budget.
1970 Super Stock Challenger ex. Paul Rossi 1968 Dodge Dart GT 340 1968 Dodge Charger /6 3 speed manual 1966 Chrysler 300 Loaded 1968 Dodge Charger R/T 440
1968 Mini Cooper
[Re: MrSixpack]
#1388341
02/16/13 03:48 PM
02/16/13 03:48 PM
MikeyT
Watertown, WI
Mild porting and engine dyno.
Mike
[Re: MikeyT]
#1388342
02/16/13 06:57 PM
02/16/13 06:57 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Ok folks.
425 hp.....same exact bullet....only 11:1...that I ran back in the mid 80's in a 72 Challenger 3000lb race weight 727 not enough converter 4.56 ran a best of 11.2 @ 117 ![](/ubbthreads/images/graemlins/Twocents.gif)
Rickster
[Re: rickstershemi]
#1388343
02/16/13 07:10 PM
02/16/13 07:10 PM
dartman366
Mt. Vernon, Ohio
Ok folks.
Rickster
Thats pretty much where mine run,having a little less compression and I would say 11.30's-11.40's with this one. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: MikeyT]
#1388348
02/16/13 08:43 PM
02/16/13 08:43 PM
Posts: 52,972 Romeo MI
MR_P_BODY
With the exhaust on the dyno.. 385hp/410tq but it will vary on which muffs.... this is a wild guess since your leaving a LOT of info out of the equation ![](/ubbthreads/images/graemlins/wave.gif)
[Re: moparguy7074]
#1388349
02/16/13 09:00 PM
02/16/13 09:00 PM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
Stock 340X heads? 425HP, 430, (maybe 440) ft/lbs of torque. Ported: 460HP, 460-480 ft/lbs torque. All depends on the machining, balancing, assembly, initial and final tuning of ALL components together. Not much cr, but I'm wondering if it's EFFECTIVE or static measured cr. ![](/ubbthreads/images/graemlins/2245452-furysmiley.gif)
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
[Re: MikeyT]
#1388353
02/16/13 11:12 PM
02/16/13 11:12 PM
Posts: 549 Bristol, Va
fasteddie
Bristol, Va
Very similar to my combo. 360 with stock cast crank, Scat I beams, Flat top SRP pistons, calculated 11.5:1 comp ratio, old school "purple shaft" .509 cam, "J" heads with 2.02 valves, untouched ports, and shaved .100 to get .045 quench. 3500 stall PTC converter, 4.30 gears. Car is heavy at 3500 lbs with me in it.
Runs 11.80 in good air, high 11.90s in the heat.
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
