moparts engine builder, help settle a bet #1388335
02/16/13 01:09 PM
02/16/13 01:09 PM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Ok folks.
I want you to be completely truthful on this build and see what some of the engine builders come up with for Hp numbers/ torque numbers.
No need to inflate or sand bag, just honest opinions.
Build 367 cubic inch engine
10:1 compression ration
340X heads
240ish .520 lift solid roller comp cam
holley street dominator intake
750 proform carb
1 5/8 headers. thru 2.5 exhaust.
I know this isn't an exact science, just give me guesses thanks,
Mikey
1969 Dodge Dart Swinger
Re: moparts engine builder, help settle a bet [Re: MikeyT] #1388336
02/16/13 01:12 PM
02/16/13 01:12 PM
Guitar Jones Offline
I'm thinking about 400/450.
Re: moparts engine builder, help settle a bet [Re: Guitar Jones] #1388337
02/16/13 01:56 PM
02/16/13 01:56 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Similar 340 with ede's and a victor 340 made 455
Stock x heads, probably 420ish hp on the high side and same TQ.
Re: moparts engine builder, help settle a bet [Re: RobX4406] #1388338
02/16/13 02:16 PM
02/16/13 02:16 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
Agree 400-430
Re: moparts engine builder, help settle a bet [Re: MikeyT] #1388339
02/16/13 03:27 PM
02/16/13 03:27 PM
Are you wanting numbers for a engine dyno or a chassis dyno? If on a chasis dyno which trans and converter combination or is it a stick shift set up?
Re: moparts engine builder, help settle a bet [Re: MikeyT] #1388340
02/16/13 03:32 PM
02/16/13 03:32 PM
Stockholm, Sweden
MrSixpack Offline
MrSixpack  Offline
Stockholm, Sweden
Is the heads stock or ported?
If stock I would guess 375-400 HP.
I know the Stock guy's with 340's make more power, but I don't know if the ARE Stock.
As long as they don't pour the heads for cc's I don't trust them
I built a 366 for a friend with a TIGHT budget(he is poor as he!!)
I've used std J heads with 2.02 intake valves and no porting, a Edelbrock RPM, Lunati voodo cam, and a Thermoquad.
Car is a original 62 4dr Dart with 8 3/4 3.23 and pushbutton 727 and Streetfighter converter.
Best et 13.02@104mph
Don't know the HP but we are happy as it's a NO money budget.
1970 Super Stock Challenger ex. Paul Rossi
1968 Dodge Dart GT 340
1968 Dodge Charger /6 3 speed manual
1966 Chrysler 300 Loaded
1968 Dodge Charger R/T 440
1968 Mini Cooper
Re: moparts engine builder, help settle a bet [Re: MrSixpack] #1388341
02/16/13 03:48 PM
02/16/13 03:48 PM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Mild porting and engine dyno.
Mike
Re: moparts engine builder, help settle a bet [Re: MikeyT] #1388342
02/16/13 06:57 PM
02/16/13 06:57 PM
Lehigh Acres, Florida
rickstershemi Offline
Ok folks.
340X heads
750 proform carb
Mikey
425 hp.....same exact bullet....only 11:1...that I ran back in the mid 80's in a 72 Challenger 3000lb race weight 727 not enough converter 4.56 ran a best of 11.2 @ 117
Rickster
Re: moparts engine builder, help settle a bet [Re: rickstershemi] #1388343
02/16/13 07:10 PM
02/16/13 07:10 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Ok folks.
340X heads
750 proform carb
Mikey
Rickster
Thats pretty much where mine run,having a little less compression and I would say 11.30's-11.40's with this one.
Re: moparts engine builder, help settle a bet [Re: MikeyT] #1388344
02/16/13 07:13 PM
02/16/13 07:13 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Not sure what mild porting is, but I'll guess 435HP?
Re: moparts engine builder, help settle a bet [Re: 451Mopar] #1388345
02/16/13 07:31 PM
02/16/13 07:31 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
That's close to a combo I ran several years ago; mine was a .030-over 340, bigger headers & open exhaust, Holley Strip Dominator intake, and it made 440HP and ran 11.40s in my Duster with a 4400-stall converter 904, 5.38s & 13x31 tire at about 3,000 lbs foot-braking.
Re: moparts engine builder, help settle a bet [Re: MikeyT] #1388346
02/16/13 08:01 PM
02/16/13 08:01 PM
Az
Crizila Offline
Crizila  Offline
Az
407 HP.
Fastest 300
Re: moparts engine builder, help settle a bet [Re: Crizila] #1388347
02/16/13 08:20 PM
02/16/13 08:20 PM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
400-410 hp. 420-430 tq.
Re: moparts engine builder, help settle a bet [Re: MikeyT] #1388348
02/16/13 08:43 PM
02/16/13 08:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
With the exhaust on the dyno.. 385hp/410tq but it
will vary on which muffs.... this is a wild guess since
your leaving a LOT of info out of the equation
Re: moparts engine builder, help settle a bet [Re: moparguy7074] #1388349
02/16/13 09:00 PM
02/16/13 09:00 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
Stock 340X heads? 425HP, 430, (maybe 440) ft/lbs of torque. Ported: 460HP, 460-480 ft/lbs torque.
All depends on the machining, balancing, assembly, initial and final tuning of ALL components together. Not much cr, but I'm wondering if it's EFFECTIVE or static measured cr.
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: moparts engine builder, help settle a bet [Re: HYPER8oSoNic] #1388350
02/16/13 09:57 PM
02/16/13 09:57 PM
campbell river B.C
mopartoby Offline
mopartoby  Offline
campbell river B.C
What fuel? With open chamber x heads and 10:1 compression...... Uhhhhmmmm 375-400.
Re: moparts engine builder, help settle a bet [Re: mopartoby] #1388351
02/16/13 10:12 PM
02/16/13 10:12 PM
Az
Crizila Offline
Crizila  Offline
Az
Hey, you are supposed to guess with the info supplied. Thats why it's called a guess. Any more guesses after my guess based on additional info supplied by the OP DON'T COUNT!!!
Fastest 300
Re: moparts engine builder, help settle a bet [Re: Crizila] #1388352
02/16/13 10:43 PM
02/16/13 10:43 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
400 tops with good heads
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: moparts engine builder, help settle a bet [Re: MikeyT] #1388353
02/16/13 11:12 PM
02/16/13 11:12 PM
Bristol, Va
fasteddie Offline
fasteddie  Offline
Bristol, Va
Very similar to my combo. 360 with stock cast crank, Scat I beams, Flat top SRP pistons, calculated 11.5:1 comp ratio, old school "purple shaft" .509 cam, "J" heads with 2.02 valves, untouched ports, and shaved .100 to get .045 quench. 3500 stall PTC converter, 4.30 gears. Car is heavy at 3500 lbs with me in it.
Runs 11.80 in good air, high 11.90s in the heat.
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
Re: moparts engine builder, help settle a bet [Re: mopartoby] #1388354
02/16/13 11:54 PM
02/16/13 11:54 PM
Desert Tracker
Desert Tracker
Didn't say what fuel, so I going with pump gas premium w/ octane booster to be sure. Fiddle with the cam intake and lobe center angles (degree cam), optimize ignition timing to the combo and make sure the EFFECTIVE cr IS 10 to 1, otherwise with the "advertised" cr level at 10 to 1, you are looking at 50-70hp less (maybe more!) than with EFFECTIVE cr.
