Were the 1970 383 A/C blue or orange? #1386867
02/13/13 01:20 PM
02/13/13 01:20 PM
Pewaukee, WI
Airgrabber Offline OP
Pewaukee, WI
I've seen the topic in regards to the 69's and understand that the A/C cars had the blue motors. Is this true for 1970 also? Thanks
Re: Were the 1970 383 A/C blue or orange? [Re: Airgrabber] #1386868
02/13/13 01:22 PM
02/13/13 01:22 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Two bbl is blue, four barrel is Orange...
Re: Were the 1970 383 A/C blue or orange? [Re: 1_WILD_RT] #1386869
02/13/13 02:37 PM
02/13/13 02:37 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Are 383 4bbl N codes Orange in a 70 Sport Satellite, 70 Challenger, 70 Barracuda, 70 Coronet 500, etc or blue?
In other words, non 383 4bbl with A/C in non Challenger R/T, Super Bee, Road Runner, 'Cuda models.
Would it matter above if the car was a 383 4bbl A/C with 4 speed?
Re: Were the 1970 383 A/C blue or orange? [Re: autoxcuda] #1386870
02/13/13 03:26 PM
02/13/13 03:26 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Re: Were the 1970 383 A/C blue or orange? [Re: NachoRT74] #1386871
02/13/13 04:33 PM
02/13/13 04:33 PM
Vicksburg, MI
coffeeman383 Offline
Vicksburg, MI
What is that table from? The asterisk notes about "...engines...were found" implies some after-the-fact historical table as opposed to a Chrysler document.
Re: Were the 1970 383 A/C blue or orange? [Re: NachoRT74] #1386872
02/13/13 04:47 PM
02/13/13 04:47 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
In 1970 the "performance" 383HP HOLLEY 4bbl engines were orange the "non-performance" 383 CARTER 4bbl engines were blue. All were coded "N" in the VIN & E63 on the fender tag.
C-bodies were all blue - there is no such thing as a high performance 383HP engine in a '70 c-body. ALL '70 c-body 383 4bbl engines were originally equipped with a Carter AVS carb & BLUE.
The "performance" b & e-bodies with 383HP 4bbl are all orange, this includes ALL: Chargers, Super Bees, Road Runners, Challenger R/Ts and 'Cudas. ALL '70 "performance" b & e-body 383HP 4bbl engines were originally equipped with a Holley carb & ORANGE.
The "non-performance" b & e-bodies ordered with a 383 4bbl engine and a 3 or 4-speed manual transmission received the 383HP 4bbl orange engine equipped with a HOLLEY carb. Those with automatic transmissions received the Carter AVS equipped blue 383 4bbl engine.
Is it possible something was built that does NOT follow the above? SURE, but be sure to bring PROOF!
Re: Were the 1970 383 A/C blue or orange? [Re: 6bblgt] #1386873
02/13/13 04:57 PM
02/13/13 04:57 PM
Texas, Dallas
G_T Offline
G_T  Offline
Texas, Dallas
Interesting... no 318 listed.
My 70 came with the original 318 - it was blue... not even sure if an orange 318 was ever made...
1970 Charger - V10, 6spd, Alterkation, Street Lynx 4 Link, Moser Dana 60, Wilwood 14" disks, Forgeline 18" Wheels (Rear:335's), ISIS Multiplexing Wiring http://www.v10mopar.com 2012 Charger SRT8
Re: Were the 1970 383 A/C blue or orange? [Re: G_T] #1386874
02/13/13 06:59 PM
02/13/13 06:59 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No orange 318's , The table above is for the HP engines , 318 doesn't qualify within the confines of the U.S. during the muscle car era.
Re: Were the 1970 383 A/C blue or orange? [Re: JohnRR] #1386875
02/13/13 07:50 PM
02/13/13 07:50 PM
Pewaukee, WI
Pewaukee, WI
I still thought when you added A/C to the 70 383 Road runner line up the horse dropped from335 to 330 and the motor was then blue.
Re: Were the 1970 383 A/C blue or orange? [Re: Airgrabber] #1386876
02/13/13 08:26 PM
02/13/13 08:26 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Had a '70 Satellite 383 4bbl A/C A/T wagon - bought umolested & totally original from original owner - with a turquoise engine, AVS carb & silenced (dual-snorkel) air cleaner. St. Louis car. Also had 11" drum brakes. Known history from Day 1, original everything.
Re: Were the 1970 383 A/C blue or orange? [Re: Airgrabber] #1386877
02/13/13 08:26 PM
02/13/13 08:26 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
There was an 335 horse orange manual transmission a/c application in B bodies for 1970. IIRC, it was engine assembly 084.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: Were the 1970 383 A/C blue or orange? [Re: 69CoronetRT] #1386878
02/13/13 10:17 PM
02/13/13 10:17 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I've got a 70 Challenger SE 383 4 bbl carter, 330 horse, A/C auto and it's blue. It has HP manifolds. I may have a picture.
Re: Were the 1970 383 A/C blue or orange? [Re: fastmark] #1386879
02/14/13 01:23 AM
02/14/13 01:23 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
As it should!!
Re: Were the 1970 383 A/C blue or orange? [Re: topside] #1386880
02/14/13 01:30 AM
02/14/13 01:30 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Old (cooked/dirty/oily) '70 & newer blue engines often look turquiose from age.
NO stock/factory turquoise engines after 1969 model year.
compare the blue ground cable to the original blue valve covers on this '70 383 2bbl
Re: Were the 1970 383 A/C blue or orange? [Re: 6bblgt] #1386881
02/14/13 10:29 AM
02/14/13 10:29 AM
Vicksburg, MI
Vicksburg, MI
As it should!!
Just when I think I understand....
I've seen both the 330 HP and 335 HP listed in a plymouth guide where it explains the RR gets the 335 because of camshaft, windage tray, etc. In the Challenger guide I only see 1 383-4bbl listed, a 335 HP (standard in Challenger R/T). So the SE Challenger is considered 'non performance' and gets the 330 HP blue engine? And an R/T AC Challanger would get the orange 335 HP (yes, I think). Is it as simple as SE is 'non-performance' just like a 383-4bbl Sport Satellite is 'non-performance'? Yet all 4 bbls are N code. It's the build sheet that gives the engine and carb (my 70 AC orange 383 is 084 engine with 036 Holly Carb). How'd I do?
Re: Were the 1970 383 A/C blue or orange? [Re: coffeeman383] #1386882
02/14/13 10:31 AM
02/14/13 10:31 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I had a 70 383 Charger SE 4 speed A/C car and it was Orange and had the Holley 4160 from the factory.
WIZE
In Car:
Re: Were the 1970 383 A/C blue or orange? [Re: coffeeman383] #1386883
02/14/13 02:45 PM
02/14/13 02:45 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
How'd I do?
Pretty well.
Printed and online guides do not have the time or space to explan the nuances of which cars actually recieved which version of the 383-4bbl engine and there are few sweeping guidelines.
Which cars actually received the 335 HP engine varies by each year (68-69-70). Factors you may or may not have to take into account for each year include model, A/C or not and transmission. What applied in 68 may or not be the same for 69 and/or 70.
The best determination of what actually came in the car is the engine assembly code from the broadcast sheet or the code on a Lynch Road fender tag.
Seeking:
Re: Were the 1970 383 A/C blue or orange? [Re: coffeeman383] #1386884
02/14/13 03:31 PM
02/14/13 03:31 PM
AZ.
696pack Offline
696pack  Offline
AZ.
As it should!!
In the example you give above there is a lot of potential confusion.
It is confusing in itself about the SE designation. It was an option package on the CHARGERS but it is a MODEL designation on the CHALLENGER. There is a JH29 for the SE and a JS23 for the R/T and a JS29 for the R/TSE model. The JH29 with a 383-2 would be a 290 h.p. and both the JS23 and the JS29 would have the R/T (standard) 383-4 335 h.p. engine. SO, you could have an SE model Challenger with either engine.
Now there is MORE confusion. Look closely at this:
http://www.hamtramck-historical.com/dealerships/1970DealershipDataBook-05.shtml
When you look at engine options for the Challenger with the engine pictures it shows the 383-4 TWICE and the first one has a twin snorkle air cleaner which is usually a sign of a 330 h.p. the the second picture shows the 383-4 with the unsilenced air cleaner which is usually a sign of the 335 h.p. BOTH are listed as Magnum engines and both are rated at 335 h.p. HOWEVER, the descriptions are clearly different and they are two different engines and I believe a mis print for the h.p. rating.
However AGAIN, if you go to the standard and optional equipment page and look at the available engines it only list two 383s, the 383-2 290 h.p. and the 383-4 335. h.p. obviously a mistake SOMEWHERE in all of this.
There has been difficulty identifing 383-4s since 1968 because the V.I.N. designation and the fender tag engine codes were the same regardless of it being a 330 h.p. or a 335 h.p.
Are you TOTALLY confused now?
Re: Were the 1970 383 A/C blue or orange? [Re: 69CoronetRT] #1386885
02/14/13 04:27 PM
02/14/13 04:27 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
for 1970:
If you have an original b'cast sheet (or Lynch Rd. fender tag) the 3-digit ENGINE number and 2-digit CARB number can be used to determine which engine is correct for a particular car.
383 manual - E & B-body - with ECS (N95)
orange HP engine 335hp
---------- Holley R4217-A ---------- part number 3418 537 on b'cast 37
383 manual - E & B-body - w/o ECS
orange HP engine 335hp engine on b'cast 084 with A/C & 087
---------- Holley R4367-A ---------- part number 3418 536 on b'cast 36
383 manual - E & B-body - w/o ECS & with "fresh air" (N96).
---------- Holley R4736-1A ---------- part number 3512 964 on b'cast 64
383 manual - E & B-body - with ECS (N95) & with "fresh air" (N96).
---------- Holley R4738-1A ---------- part number 3512 974 on b'cast 74
383 automatic - E, C & B-body - w/o A/C & w/o ECS
blue engine 330hp
---------- Carter 4736S ---------- part number 3418 538 on b'cast 38
383 automatic - E, C & B-body - with A/C (H51) & w/o ECS
blue engine 330hp
---------- Carter 4732S ---------- part number 3418 540 on b'cast 40
383 automatic - E, C & B-body - with ECS (N95)
blue engine 330hp
---------- Carter 4734S ---------- part number 3418 541 on b'cast 41
383 automatic - E & B-body - w/o A/C & w/o ECS
orange HP engine 335hp engine on b'cast 088
---------- Holley R4368-A ---------- part number 3418 542 on b'cast 42
383 automatic - E & B-body - w/o A/C & with "fresh air" (N96).
---------- Holley R4737-1A ---------- part number 3512 965 on b'cast 65
383 automatic - E & B-body - with ECS (N95)
---------- Holley R4218-A ---------- part number 3418 543 on b'cast 43
383 automatic - E & B-body - with A/C (H51) & w/o ECS
orange HP engine 335hp engine on b'cast 089
---------- Holley R4369-A ---------- part number 3418 562 on b'cast 62
383 automatic - E & B-body - with ECS (N95) & with "fresh air" (N96).
---------- Holley R4739-1A ---------- part number 3512 975 on b'cast 75
Re: Were the 1970 383 A/C blue or orange? [Re: 6bblgt] #1386886
02/14/13 05:06 PM
02/14/13 05:06 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
1970 383 4bbl "non-performance" b & e-bodies would include: (orange engined 383HP cars of these models are "RARE" and would be the "insurance beaters" & "street sleepers" of the day)
Coronet Deluxe
Coronet 440
Coronet 500
Belvedere
Satellite
Sport Satellite
Barracuda
Gran Coupe
Challenger
Challenger SE
GG's "white book" US Spec. numbers:
Coronet Deluxe ~ w/383 4bbl auto = 39 (blue) & 383HP 4bbl manual = 12 (orange)
Coronet 440 ~ w/383 4bbl auto = 561 (blue) & 383HP 4bbl manual = 32 (orange)
Coronet 500 ~ w/383 4bbl auto = 909 (blue) & 383HP 4bbl manual = 107 (orange)
Belvedere ~ ??
Satellite ~ w/383 4bbl auto = 325 (blue) & 383HP 4bbl manual = 99 (orange)
Sport Satellite ~ w/383 4bbl auto = 562 (blue) & 383HP 4bbl manual = 225 (orange)
Barracuda ~ w/383 4bbl auto = 501 (blue) & 383HP 4bbl manual = 680 (orange)
Gran Coupe ~ w/383 4bbl auto = 794 (blue) & 383HP 4bbl manual = 376 (orange)
Challenger ~ w/383 4bbl auto = 1036 (blue) & 383HP 4bbl manual = 572 (orange)
Challenger SE ~ w/383 4bbl auto = 644 (blue) & 383HP 4bbl manual = 170 (orange)
