High temp engine paint #1386111
02/12/13 12:32 PM
02/12/13 12:32 PM
United States
tee-john Offline OP
tee-john  Offline OP
United States
I am using high temp Dupli-Color enamel to paint my engine, but I don't see any high temp primer. Is high temp primer or any primer needed prior to paint my engine?
Re: High temp engine paint [Re: tee-john] #1386112
02/12/13 05:36 PM
02/12/13 05:36 PM
scratchnfotraction Offline
I degreese it with simple green degreeser/cleaner,use brush to remove heavy deposits,rinse with water,airhose dry it,shoot it with 3 cans of the deplicolor hemi orange.
always looks good and last a good while if you dont have oil leaks.
I like to use the rustoleum hemi orange and use a small paint gun with it reduced 4/1 with mineral spirts.( I will post the paint# later)
when the engine is on the stand for painting I spray a can on and wait 15-20 mins then another can,wait 15-20 mins,then last can goes on. i save some of the 3rd can for touch ups as I install it and dress the engine while working my way out from under the hood.
good luck
Re: High temp engine paint [Re: tee-john] #1386113
02/12/13 10:36 PM
02/12/13 10:36 PM
USA
Hooligan Offline
Hooligan  Offline
USA
I agree with SFT on the rustoleum with no primer method. I used it on an engine in my Dart, and 70,000 miles later, none of it peeled off. It did lose a lot of the gloss, but I didn't mind.
Re: High temp engine paint [Re: Hooligan] #1386114
02/12/13 11:43 PM
02/12/13 11:43 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
I used Plastikote with no primer.
Key is getting as much of the old paint off as possible and DEGREASE DEGREASE DEGREASE!
Still looks almost perfect 5 years later.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: High temp engine paint [Re: wingman] #1386115
02/13/13 12:57 AM
02/13/13 12:57 AM
IN
ahy Offline
ahy  Offline
IN
Mostly the engine does not get hot enough to bother paint. Many folks have used car paint without problem. Agree prep/cleaning is the key. I did use an etching primer as first coat (Eastwood) with MP spray bomb finish coat. The primer helps adhesion with various aluminum parts. It has held up well.
Re: High temp engine paint [Re: ahy] #1386116
02/13/13 01:01 AM
02/13/13 01:01 AM
I like raw un painted aloony-um with my hemi orange.
Re: High temp engine paint [Re: ahy] #1386117
02/13/13 05:30 PM
02/13/13 05:30 PM
Modesto CA
BFASTER Offline
BFASTER  Offline
Modesto CA
I just used regular single-stage car paint on mine and 3 years later no problems at all.
1969 Dodge Super Bee Hardtop 2007 Nissan Altima 3.5SE
Re: High temp engine paint [Re: wingman] #1386118
02/13/13 05:34 PM
02/13/13 05:34 PM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
x99 ....PLUS after dEgrease .. I spray it down with carb-spray or brake-clean.
Re: High temp engine paint [Re: dOOc] #1386119
02/16/13 12:16 PM
02/16/13 12:16 PM
west kentucky
gomangoRTSE Offline
gomangoRTSE  Offline
west kentucky
If the engine is currently unpainted, I would first put 3 or so fine coats of epoxy primer. THis will provide the better foundations and fill up gaps in and around the intake manifold area. It will also help the finish coat keep its sheen and resistance to heat.
