turn signal switch return #1385462
02/11/13 11:15 AM
02/11/13 11:15 AM
Carson City, NV
babarracuda Offline OP
Carson City, NV
I have never had a column that the signal arm would return. Below is a picture. What am I missing and where can I find it? The picture is too big so I can't load it
Re: turn signal switch return [Re: babarracuda] #1385463
02/11/13 11:22 AM
02/11/13 11:22 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
You need to replace the turn signal switch itself. There are two plastic extensions that break off easily and they are what click the signal into the return position.
Re: turn signal switch return [Re: babarracuda] #1385464
02/11/13 03:58 PM
02/11/13 03:58 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
There's a good chance you don't need to replace an expensive turn signal switch - just repair it. Cancel cam needs to be replaced. You can pick up a switch repair kit at Napa. Don't know what you're woking on but an Echlin EL6126 is one example for Chryslers.
The 'whiter' colored plastic in the pic below is what's needed.
Re: turn signal switch return [Re: 70Duster440] #1385465
02/11/13 04:20 PM
02/11/13 04:20 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Re: turn signal switch return [Re: Challenger 1] #1385466
02/11/13 04:27 PM
02/11/13 04:27 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Ted..
I can still send you that complete set up..went I get home from hawaii...lol
Tony
70 AARCuda Vitamin C
Re: turn signal switch return [Re: 70AARcuda] #1385467
02/11/13 06:51 PM
02/11/13 06:51 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If you go with the cancel cam repair, which is easiest and cheapest, pay close attention to the whisker trimming instructions.
